Question about Symbol MC9090 Barcode Scanner
The MC9090 is forzen cannot select any icon. help
  • 97 Answers
Have you tried performing a cold boot? release battery half way, press and release trigger and power button at the same time and put the battery back in.
Posted on Mar 26, 2009
Is it possible to place icons (shortcuts) on the MC9090 to gain quick-access to programs? If so, how is it done?
Hope this answers your question. First go to the .EXE file you want to be on the desktop. Touch and hold to pull open the sub-menu of that app. Select "Copy". Now go to the desktop. Find an empty section. Touch and hold down to open the sub-menu. Now select "Paste Shortcut". This will put a shortcut on the desktop for you. It will show the word "Shortcut" at the beginning of the title now, which is kind of a pain. A simple "Rename" can fix that though. That should do it!
Feb 25, 2013 | Symbol Motorola MC9090 Mobile Computer
Permanent Desktop icon removal for Symbol MC9090 scanner
Right click the icon. Hold the shift button while left clicking the delete option in the menu. Click ok on the permanent delete.
Oct 19, 2012 | Symbol MC9090 Barcode Scanner
How do you enable Wireless on MC9090
If there is an 'X' on the radio icon not a '!' then it has been disabled.
To switch it on hit the wireless icon in the taskbar and select [enable radio].
If the radio fails to switch on then try a warm boot:-
Hold down the power button for approximately 10 seconds until the splash screen is shown.
If it still fails proceed with a cold boot:-
Partially remove the battery, hold down the On/Off button, the trigger and reinsert the battery. When the orange light on the keyboard flashes release the on/off button and the trigger.
If the on/off button or trigger is held down longer than required this occasionally causes the terminal to get caught in a warm boot cycle
If the fault is still not rectified then the device requires repair. Which we can help with as we have a specialised repair centre.
If there is an '!' on the radio icon not a 'X' then the radio cannot associate to an AP due to regulatory issues.
Hit the wireless icon in the taskbar and select [options], a pop up is then display, select [Regulatory] from the pull down menu. Then select your country and switch of 802.11d if not required. Save and exit
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jul 13, 2012 | Symbol Motorola MC9090 Mobile Computer
MC 9090 doesnt keep Wlan profile
You can make your profile cold boot persistent by following these steps. Create the profile. Once saved click on your wireless icon and select options. Scroll down to export. Select the export all profiles and press ok to finish creating the .reg file.
Tech Support Barcoding Technical Support
Jun 04, 2012 | Symbol MC9090 Barcode Scanner
How do I get Symbol / Motorola MC9090 wireless settings to be
This is an old post but I'll give my solution anyway!
I anticipate that you're not exporting the connections:
Open the Wireless Menu icon on the task bar (Close "Manage Profiles" if it is open, select "options".
Select from the drop down "Regulatory" and select your country of operation (e.g USA), de-select "Enable 802.11 d", click Save.
Select from the drop down "Export", click "Export Options", click OK top right, click "Export All Profiles", click OK top right.
Now if a cold boot is performed the device will retain the added network profiles.
Cheers!
Apr 27, 2012 | Zebra Symbol Technologies Mc9090 Moble...
I cannot set the static IP for my MC9090. I went into Network Connections and have tried to Specify a valid IP address, Subnet and Gateway. I press ok. Then when I run cmd, I then type ipconfig and it...
Hi Jim,
I remember having the exact same problem when I first used the MC9090. It works on such other devices like the Datalogic Viper, but not the MC9090.
The IP is set within the wireless profile.
On the radio icon in the task bar select Wireless Profiles. This box then holds all your wireless profiles, including the default Motorola "out of box". Hold down the stylus on the screen and select "Add New" follow the prompts. When you get to IP Address from the pull down menu select static and then next this will take you to another screen where you can add your details.
Now you want to make them persist through either a cold boot or when the terminal has been left without a battery for a substantial amount of time.
This can be done 2 ways. When the profile has been set up highlight it by holding down the stylus on it and from the menu select export. This saves the registry key to the Application folder; a folder which persist through a cold boot. When it does cold boot it takes all the registry keys from the Application folder and builds 1 complete key.
The other way is to close the WLAN profile and selection options, from the pull down menu select export and save all profiles.
Hope this helps.
or TEL 01202 620955
Jan 14, 2010 | Symbol MC9090 Barcode Scanner
I cannot set a static IP on my MC9090 scanner but
Hi Jim,
Hope this helps.
or TEL 01202 620955
Jan 14, 2010 | Symbol Motorola MC9090 Mobile Computer
Connecting to the internet
Hi there, this one might help since the OS is Windows mobile 5. the settings on your handheld might be quite different but still this may work. Please turn on wi-fi. There is a small icon below for wireless simply tick that and it will turn on wi-fi. Once you turn it on it will detect available wireless networks or you may simply go to Start menu and select settings. Go to connections and select network. It will give you available wireless networks. If prompted for the pass key or encryption, use the encryption set to the wireless network you're trying to connect with. Once you input the correct key you should be good to go.
Hope this helps
May 15, 2009 | Symbol MC9090 Barcode Scanner
Cant activate PCCARD-PHOTON1 in Symbol MC9090
First thing is to run the wireless utility.
Start >> Programs >> Fusion >> WCLAUNCH
Once thats running an icon will apear in the task bar.
Click the icon and select "Enable Radio"
helpdesk@biastechnology.com or TEL 01202 620955
Dec 10, 2008 | Symbol MC9090 Barcode Scanner
Connect MC9090-G to an Intermec 2100 Access Point
Make sure that the ESS ID and security features match the ones on the AP.
Also, from the MC9090, you will need to click on the radio icon, select options and in the top drop down menu, choose regulatory. select the country where you are and uncheck the box named enable 802.11d.
This should have the terminal connected on to the network.
Jul 11, 2008 | Symbol MC9090 Barcode Scanner
Symbol MC9090 Barcode Scanner Logo
228 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
