Question about Toastmaster 1148X FastBake Bread Maker
Toastmaster Bread Machine 1171 shaft breaking apart
I just read that many people are posting the same problem I have with this machine for quite sometime. The blade doesn't come out. I didn't care much because I am always making the same kind of bread and have not risk of mixing flavors. I do not know if these had cause the shaft to be coming apart. It looks like it burned, the pieces are just like charcoal. I called the number given on the manual but they don't have the parts any longer because the model is discontinue. Any suggestions on where to look for the shaft and paddle parts? Thanks for your site. BTW I had tried every trick that people are mentioned and nothing worked to remove the paddle.
2 Suggested Answers
KMusselmann
  • 247 Answers
SOURCE: Want to buy a kneading blade. Toastmaster bread maker 1171
Hi. You can get it here. Pls rate the answer
Kurt
http://breadmakerguru.com
Posted on Apr 22, 2009
Looking for the mixing blade for a Toastmaster 1195 Bread machine.
The part number you are looking for is WB3-16-C-00.You can find this part at eCrater.com. Follow the link below:
http://www.ecrater.com/p/11268871/toastmaster-bread-machine-paddle-wb3-16-c-001
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 10, 2011 | Toastmaster 1193 Bread Maker
Toastmaster 1171 Manual
Here you go,
The link and many tips are on this page to help you.
http://www.bread-making.org/bread-machine-manual.html
Best wishes,
TF
Jun 03, 2011 | Toastmaster Kitchen Appliances - Others
Toastmastter breadmachine model 1186. I used it two days ago, worked fine. Today the drive belt will not turn. It makes a small clicking noise. Can you oil the shaft or are the bearing gone?
Hi, Take the bread pan out of the machine and see if it still makes the noise when you start a kneading cycle. If it still makes the noise then the belt may be loose or a gear has chipped. If everything is normal then it could be the bread pan. There is a sealed bearing on the bottom of it and when that breaks or freezes then the paddle won't turn and it's time for a new bread pan Be sure to unplug the machine when checking belts. They are located in the base of the machine. Hank
Jan 24, 2011 | Toastmaster 1183N Bread Maker
Paddle for toastmaster bread machine
See post for WILLIAMS SONOMA paddle needed
Oct 07, 2008 | Kitchen Appliances - Others
Toastmaster Platinum Bread and Butter Maker
I found a toastmaster platinum bread and butter maker at a thrift store and it still had a sticker attached encouraging users to call 1-800-947-3744 for troubleshooting. Good luck!
Oct 21, 2007 | Toastmaster TBR15 Bread Maker
Toastmaster 1148X FastBake Bread Maker Logo
290 people viewed this question
Top Toastmaster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Are you a Toastmaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
