Question about HP LaserJet 3055 All-In-One Printer
HP Laserjet 3055 does not fax. when thefax printer is selected I recieve a error message stating that the device is offline.
  • 75 Answers
Sounds like your printer is not properly installed try downloading latest drivers from hp
Posted on Mar 04, 2009
How to reset internal memory of hp laserjet 3055
Perform the following to clear the fax memory:
Press the menu/enter button on the control panel.
Press the > button once to select Fax functions , and then press menu/enter .
Press < or > to select Clear saved faxes , and then press menu/enter .
Press menu/enter to confirm deletion.
Dec 27, 2013 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 .fax not working
Direct Line:
1.Check telephone line.2.Make sure telephone line is connected in line in port not in extension.3.connect extension telephone phone to the device & check for the dial tone.
Dial the number and observe weather extension phone is ringing?
A. *If extension phone is ringing check display is there any message like "ringing".. wait till fax tone comes,if not check "basic fax settings"... if setting are OK .. Replace formatter
B. *Extension phone is ringing no message displayed on device replace "LIU" card..
If extension telephone is not ringing check telephone line..
No out going faxess:
*Check line is connected though EPABX , if connected Check..prefix setting..
*Check out going..
Best of luck...
Sep 06, 2011 | HP LaserJet 3055 All-In-One Printer
I have Hp Laser jet 3055 can install only the printer under windows 7, but unable to install the fax facility.Please help.
Then please navigate to www.hp.com, click on support and type the model details e.g HP Laserjet 3055 all in one printer and select your computer operating system type to download the full drive for all your printer facilities.
Thanks
May 18, 2011 | HP LaserJet 3055 All-In-One Printer
Scanner on HP Laserjet 3055 won't run - message on screen reads "Scanner error 6, turn off then on". I have tried that several times without any new result. Any ideas?
Suggest you to perform a restore factory default settings on the printer.
To restore the factory-set defaults
On the all-in-one control panel, press Menu.
Use the < or the > button to select Service, and then press .
Use the < or the > button to select Restore defaults, and then press .
The all-in-one automatically restarts.
CAUTION: This procedure clears fax numbers and names that are associated with one-touch keys and speed-dial codes, and deletes any pages that are stored in the memory. The procedure then automatically restarts the all-in-one.
Jan 31, 2011 | HP LaserJet 3055 All-In-One Printer
My LaserJet 3055 All-in-one can print, fax and copy, but can not scan, when run the scanning software, the scan pub can move but when scanning data send to pc, the display of printer show "cannot...
"Power off" printer > Press & hold 'ENTER' > 'Power on'. Continue to hold 'ENTER' key only till "Program storage intt." (or similar nsg.) appears.
Wait & Let the unit boot to "Ready" message in the screen. Reload PC with device driver. Try to scan. If error persists Formatter PCB may need replacement.
Jan 25, 2011 | HP LaserJet 3055 All-In-One Printer
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't print...it says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
Hi I am getting an error message 232 on my HP Laserjet 3055 - it says on the screen that it is low on memory but I can't find where to reset the memory if this is the problem. Thank you
  1. Press the menu/enter button on the control panel.
  2. Press the > button once to select Fax functions , and then press menu/enter .
  3. Press < or > to select Clear saved faxes , and then press menu/enter .
  4. Press menu/enter to confirm deletion.
As far as I know, there is no option to turn this Fax Caching option off.
Dec 15, 2009 | HP LaserJet 3055 All-In-One Printer
Our fax machine is displaying the incorrect fax number for our company on the report. How do I change it? We have a laserjet model 3055 all in one printer. Thanks Jenneka
Go to www.hp.com, select support & drivers, select "see support and troubleshould........", fill out your product and you'll find "setup, install and configure".
Gerrit Jan
Nov 04, 2009 | HP LaserJet 3055 All-In-One Printer
Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Apr 12, 2009 | HP LaserJet 3055 All-In-One Printer
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
169 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
