Question about Microsoft Computers & Internet
I need the turbo c++ program for sum of sub sets!!
  • Microsoft Master
  • 4,806 Answers
Hi there.
Get Turbo C++ here >>>>>
http://cplus.about.com/od/learnc/ss/tcsharpins_2.htm
Good luck and thanks for using FixYa!!!
Posted on Mar 04, 2009
Does a Toyota Avensis 1998 GSTD have a turbo
Hi, I would imagine the letters GTSD, sum it up, ie, the TD bit means Turbo Diesel. not sure.
Hope this helps, you could look for pictures of turbos on web, basically its a fan, driven by exaust gases, that turns a fan that forces more air into engine,= more speed.so its going to be between exaust manifold and air intake, I have fitted them, but cant really explain them in simplistic terms.
Sep 20, 2014 | Toyota Avensis Cars & Trucks
Sir i have been working to c++ but before sum days i have run endless loop program by mistake something got deleted from iostream.h file after that it is showing linker error pass2
iostream.h file input output header file for c++ by which we can use input/output data.
So you must reinstall the c++ to your system and after that linker error would not go on.
Aug 26, 2011 | Borland Turbo C++ 3.0 Full Version...
Write a program to sum of all even integer numbers
#include <iostream>
using namespace std;
int main ()
int num = 0, i = 1, sum = 0;
cout << "Enter a positive integer: ";
cin >> num;
while (i <= num)
sum += i;
i++;
cout << "The sum is " << sum << endl;
return 0;
Oct 30, 2010 | Compaq Visual Fortran Professional Edition...
Program of matrix multiplication
In FORTRAN:
PROGRAM MATMULT
PARAMETER (N=3)
DIMENSION X(N,N), Y(N,N), Z(N,N)
DOUBLE PRECISION SUM
READ, X
READ, Y
DO 200 J=1, N
DO 100 K=1, N
SUM = 0.0
DO 50 L=1, N
SUM = SUM + X(J,L) * Y(L,K)
50 CONTINUE
Z(J,K) = SUM
100 CONTINUE
200 CONTINUE
WRITE, Z
END
Aug 04, 2010 | Computers & Internet
How i make calculator by using source code in c++?
hi,
here is the code u looking for
#include <iostream.h>
float sub (float a, float b)
float dif;
dif=a - b;
return dif;
float addition (float c, float d)
float sum;
sum=c+d;
return sum;
float divi (float e, float f)
float quo;
quo = e/f;
return quo;
float multi (float f, float g)
float pro;
pro=f * g;
return pro;
int main ()
float a;
float b;
float opt;
cout << "Welcome to the calculator" << endl;
cout << "There are four options " << endl;
cout << "Option 1 is subtraction, Option 2 is addition, option 3 is division, and option 4 is multiplication " << endl;
cout << "Enter your option and two digits " << endl;
cin >> opt >> a >> b;
if (opt == 1)
float temp= sub (a, b);
cout << "Your difference is " << temp << endl;
else
if (opt==2)
float temp2= addition (a, b);
cout << "Your sum is " << temp2 << endl;
else
if (opt == 3)
float temp3= divi (a,b);
cout << "Your quotient is " << temp3 << endl;
else
if (opt == 4)
float temp4= multi (a,b);
cout << "Your product is " << temp4 << endl;
else
cout << "That function is not supported in calculator!" << endl;
cout << "Thank you for using calculator" << endl;
return 0;
Thanks!
Mar 19, 2009 | Microsoft Computers & Internet
Pls. help me
Q.2#  Dim n, sum as Double
Dim i as Integer
n=100
sum=0
for i=1 to n
sum=sum+1/n
next i
Q.3#  Dim sum as Double
sum=0
for i=1 to 99
if i%2 <> 0 then sum=sum+i end if
next i
Sep 16, 2008 | Microsoft AccRepair DS2 2004 for Fr...
Subwoofer installation
no jack =no sub audio signal so you would have to get some kind of summing filter. this would sum (mix) the two signals together and extract the sub audio from both channels in order to drive the powered sub woofer you have. could be expensive dont know.
Apr 24, 2008 | Audio Players & Recorders
Turbo c source code
#include<stdio.h>
float add(float,float);
float sub(float,float);
float product(float,float);
float divide(float,float);
void main()
float n1,n2;
char sym,choice;
printf("This Program is a program for calculator\n\n");
scanf("%f%c%f",&n1,&sym,&n2);
if(sym=='+')
printf("\n%f",add(n1,n2));
if(sym=='-')
printf("\n%f",sub(n1,n2));
if(sym=='*')
printf("\n%f",product(n1,n2));
if(sym=='/')
printf("%f",divide(n1,n2));
printf("\nDo you wish to continue[y/n]");
scanf("%s",&choice);
if(choice=='y'||choice=='Y')
main();
float add(float m1,float m2)
return(m1+m2);
float sub(float m1,float m2)
return(m1-m2);
float product(float m1,float m2)
return(m1*m2);
float divide(float m1,float m2)
return(m1/m2);
Feb 21, 2008 | Computers & Internet
Automatic garbage value taking in turbo c++
When you are define the parameters you should initial them with zero. unless you do so the system will initial, then they will receive random number or minimum number.
Aug 23, 2007 | Borland Turbo C++ Suite 1.0...
Open Questions:
What is Microsoft office applications? Microsoft office is a set of interrelated desktop applications, servers, and services, collectively referred to as an office suite, for Microsoft Word: a word processor included in Microsoft Office and some editions of the now-discontinued Microsoft Works Microsoft Windows and macOS operating systems. Microsoft Excel: a spreadsheet. Microsoft released the first version of Excel for the Mac OS in 1985, and the first Windows version (numbered 2.05 to line up with the Mac) in November 1987. Microsoft PowerPoint: a presentation program used to create slideshows composed of text, graphics, and other objects, which can be displayed on-screen and shown by the presenter or printed out on slides. Microsoft Access: a database management system for Windows that combines the relational Microsoft Jet Database Engine with a graphical user interface and software development tools. Microsoft Access stores data in its own format based on the Access Jet Database Engine. Microsoft Outlook: a personal information manager that replaces Windows starting in Office 97, it includes an e-mail client, calendar, task manager and address book. Microsoft OneNote: a notetaking program that gathers handwritten or typed notes, drawings, and audio commentaries. Notes can be shared with other OneNote users over the Internet or a network. Microsoft Publisher: a desktop publishing app for Windows mostly used for designing brochures, labels, calendars, greeting cards, business cards, newsletters, website, and postcards. Microsoft Project: a project management app for Windows to keep track of events and to create network charts and Gantt charts, not bundled in any Office suite. Microsoft Visio: a diagram and flowcharting app for Windows not bundled in any Office suite
Dec 28, 2017 | Microsoft Computers & Internet
Computers & Internet Logo
138 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
