Question about Acer AL1916B 19" LCD Monitor
Acer AL1916 LCD monitor is getting darker!!
Suddenly one day the monitor was darker. I can't turn up the brightness it says that it's 100% but it's still very dark..
Please help!
  • 75 Answers
Sounds like backlight is failing,contact acer and see if its under warranty.
Posted on Mar 04, 2009
How to change monitor aspect ratio for acer AL1916
The aspect ratio is expressed as two numbers separated by a colon (x:y). and they actually represent the relation between width and height of (in your case) your monitor.
Did you mean to change the resolution of your monitor? Could you please explain your problem in more detail? What is it exactly you want to achieve?
Oct 22, 2013 | Acer AL1916 A (Black, Silver) 19 inch LCD...
IH252 inc monitor bottom half darker than top.
Thin screen LCD monitor brightness controls operate several fluorescent lamps called "backlights" that are positioned behind the LCD display. Typically, they're located around the edges of the screen - sometimes just at the top and bottom, and other times at the left and right edges and others still at all 4 edges.
Fluorescent "backlight" lamp, inverter & connection wiring.
The lamps are miniature versions of those sold in stores. They require a support circuitry called an inverter that convert & boosts the level of DC to AC voltage performing the functions of a ballast in a traditional fluorescent fixture.
The reason a part of your screen remains dark is because one or more of the components in the picture above has failed and will not allow the lamp to shine. Replacement lamps and inverters aren't expensive - but requires patience and the ability to disassemble / assemble the monitor (which is usually harder to do than it appears) and solder. They are available various lengths and color temperatures (you must get a lamp that is identical or it will be noticed). If this is a new monitor - you ought to return it for replacement. If used, consider the cost of purchasing a replacement (new or used) vs. repair.
I hope this helps & good luck!
Jul 29, 2013 | Computers & Internet
Acer AL175 TFT monitor is coming on but its very dim
The screen itself is starting to go bad which is why your having to turn up the brightness to 100% just to see something. Replacing the screen would cost more then the whole lcd monitor itself so its best to get a new one.
Dec 10, 2009 | Acer AL1715 17" LCD Monitor
Acer AL1916 monitor wont turn on
normally along the number keys are cymbals, you must look for one that is a wireless sign, then i think you must press a key with this key to enable it, normally its a fn key
Nov 29, 2009 | Acer AL1916W 19" LCD Monitor
Acer al1916 monitor, yellow picture
If your menu button is not working then you cant to do anything. I adviced to you pls check it from service center.
Oct 15, 2009 | Acer AL1916W 19" LCD Monitor
Acer moniter model AL1916
Check the cables and the computer connection VGA outlet.
If doesn't work and your monitor is under warranty ACER will repair your monitor for free.
If not, the better option is get a new one instead of repair due the high cost.
Oct 14, 2008 | Acer AL1917W LCD Monitor
Al 1916 problem
really? here's the thing..try to check the display settings manually.press the menu button of your monitor then try adjust the contrast, brightness and colors as well to your desired level..if your'e using LCD monitors, these are very sensitive and can be easily damaged if don't handle it very well..don't press the auto button always because it will automatically adjust the settings every now and then..
Jan 27, 2008 | Acer AL1916W 19" LCD Monitor
Brightness issue
hi, try recycling the power, unplug the power and vga cable and leave it out for some time, then check.. let me know
Dec 05, 2007 | Acer AL1916W 19" LCD Monitor
Monitor won't turn on
capacitor has shorted in the main board. Try to look for any buldging capacitor and change it. It will be ok then.
Nov 14, 2007 | Acer AL1916B 19" LCD Monitor
Acer AL1916B 19" LCD Monitor Logo
289 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
