Called the company, they said to make sure vent holes weren't blocked. Did that, still the same problem. Frig is only 7 mths old. Didn't have the problem the first 4 months. I've tried moving the little crisper vents each way and waiting a few days, but no matter what position they are in, I have standing water. I put a towel in the back of each bin to soak it up and change it every other day. Also, water below the bins turns to ice.
I am pretty sure you are having a defrost by CouponDropDown">drain blockage
problem. Most defrost every eight hours and over a period of time the
drain line that comes down from freezer into a cup like object top
middle and back of the fresh food section. If blocked by gunk or ice you
will see trails of liquid leaking down the rear wall of fresh food
compartment until it reaches the crisper drawers.This is not always the
same with every model as you may see frozen ice flowing down ther rear
wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian
He has been around a good bit and deserves credit for his
contributions. Here is another way to make this look more si mple in
clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If
you still have questions please ask and rate me if I was able to
explain this well enough. Every refrigerator is made different so these
are examples only. The key is to find if ice or just gunk has blocked
you defrost drain. Unplug and then remove the rear panel in back of
freezer. We need to see if the water is overflowing the condensate drain
tray or if the blockage is in the turn the drain leads down back of
your refrigerator. Much more on this page=> Leaking Refrigerators!
This is a common tip so I will be placing this post and add as we go
new ideas listed in Sea Breeze Tips Section. If you run into any
problems along the way of repair please let me know, Thanks, Sea Breeze
Having exactly the same problem with our Samsung, which is just over 1 yr. old. Will try to clear the defrost drain.
I HAVE THE SAME PROBLEM - SAMSUNG IS CLUELESS- CANNOT GET ANY HELP
Guess they don't want our business. Social networking is an amazing thing!
