Cougar Black Solution Steel ATX Mid Tower Computer Case, 3x 5.25in Bays, with 12 Logo
Lewis Posted on Mar 31, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No 10 pin connector on mother board for usb
Tiger direct sold me a m5a97 LE R2.0 motherboard. There are no place for 10 pin connection from case to motherboard. have no usb in front of case that can work now. Motherboard and case where a barebones kit. should be a place to hook this up or a way to fix it?
Level 3:
  • Master 19,187 Answers
  • Posted on Apr 11, 2013
Master
Level 3:
Answers
19187
Questions
0
Helped
4343198
Points
82259
So you have a case with front connections and no place to hook those up? You will have to get a different case, that is a nice motherboard.
How do i connect this front usb cables,the mother board is ms 6533e ver10b
On the motherboard, looking at it from the front there should be 2 10 pin white usb headers to the left of the cmos battery labeled jusb2 and jusb3. There is a pin missing from each as well as a plugged hole on your connector coming from your front usb. Just line the missing pin up with the plugged hole on your connector. Hope this helps, have a great day.
1helpful
I have an xw9400 board on a normal case,after connecting usb on board with the front panel,board still cant recognize front USB,i need to change wires in the connector to match the board,same thing with...
The front USB header on the XW9400 board has a ground connected to pin #10. The USB standard #10 pin has nothing connected to it, so HP uses it to sense whether a connector is attached to the header.
1helpful
KK266 mother board (IWill) need a wiring diagram, usb is not being identified
Antec doesn't make mother boards, they make enclosures. The standard USB connection on the board is a 2x5 pin connector, with 1 pin missing. The end that has the missing pin, is the end that the cable shield is attached to.
Propor place to plug in internal multi card reader
Most mother boards have an internal USB connector.
Have a read through *********** board manual it will describe all the connectors. If you don't have the manual you should be able to find it in the ASUS web site.
Also if you look really close at the Mother board and read the little white writing next to the connectors you may spot it.
I just took the lid of my pc to prove it can be done.
Mine is labled USB3 it has a block of 10 pins (male) and one is blank so it is really 9 pins. You mother board will be different to mine but have a look and see what you can find.
1helpful
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
1helpful
2answers
Need pinouts
I have an old pc chips M575 motherboard that also uses the J3 ATX Form card. I can only assume the pinouts are the same so here they are from the manual.
Pins 1-4 and 10- 13 are USB connectors
USB USB
Pin Description Pin Description
1 +5v 10 +5v
2 data- 11 data-
3 data+ 12 data+
4 ground 13 ground
Pins 5-6 and 15-16 are PS/2 Mouse Connector
Pin description
5 +5v
6 Mouse CLK
15 Mouse Data
16 ground
Pins 7-9 and 17-18 are Infrared connector
Pin description
7 Ground
8 Reserved
9 +5v
17 IR in
18 IR out
hope that helps
2helpful
2answers
T3624 MB someone pulled off the 3 wire pairs to the front bezel. What's the pin out for the 2 leds & power on??
According to the internet, your computer has an Intel 845GV chipset motherboard. Intel tends to use a generic pattern for connecting the front panel connectors. A description can be found on intel's site.
If this doesn't solve your problem, comment back with the motherboard model number. Look on the board, it should be printed somewhere, and it should start with D845GV...something something...
Steven
2answers
Jusb connection wiring
These are standard pin outs as you notice your pins on JUSB areupside down to this but the pin locations are correct if you start from the blank (missing) pin and work backward.
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
2answers
To fix front usb and audio to the mother board
Consult the user manual for the motherboard. It should have a layout diagram showing all connections. Or go online to manufacturer's website and download the user manual there. Also, using a bright light and magnifier you may be able to read the small print on the motherboard by the connectors.
Top Cougar Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Cougar Computer and Internet Expert? Answer questions, earn points and help others
