I have a Philips Universal remote brand new. My Sabre 26" HD LCD TV controller stopped working. I was hoping to get the code for this remote but I am unable to find it online.. Please Help ME. The brand number is LCT260BKA
  • 2 more comments
  • traumajun827 Mar 04, 2009
    I would like the exact code I have been to the website. They dont seem to help Thanks
    My philips remote is a SRU3004WM/17
    I takes a 4 digit code
    Brigadier General:
  • 3,614 Answers
may i know exactly the remote model that you have.
Posted on Mar 04, 2009
  • 19,396 Answers
You can download the code list for this remote from Philips website.
I will give you the exact link for the download.
  • 3 more comments
  • Ginko
    Ginko Mar 04, 2009
    Here is the codelist for philips universal remotes:
    PM725 Universal Remote
    Here also a remote manual
    According to remote list , Sabre has 402 587 618 619.
  • Ginko
    Ginko Mar 04, 2009
    Unfortunately the exact code is not on Philips manual, as Sabre did not communicate codes to Universal remotes manufacturers.
    The valid codes for sabre are 402 - 587 - 618 - 619.
    You need to test the four of them.
    I will do some additional research to see if more Sabre codes are available, in the meanwhile test the four codes listed above, if they work the manual will turn TV on and off.
  • Ginko
    Ginko Mar 04, 2009
    On this website: they say that Sabre uses Sony codes, in this case the code should be 202, or 708, or 801.
    You can try but I do not know if the information is genuine.
    Since Sabre had not made the codes for this model available, the only thing to do is giving them a quick call to retrieve the code for your set.
    Below the contact for Sabre, their customer service is excellent, surely it won't take long to get the code.
    Military Star Card Contact Center:
    (877) 891-STAR (7827)
    Exchange Catalog Contact Center: (800) 527-2345
    Alternatively you can get an original replacement remote control from link below.
    Sabre LCT260BKA Replacement Remote Control.
  • Ginko
    Ginko Mar 04, 2009
    If it takes four digit code, then give me the make and model of the remote, Philips remotes usually work on three digits.
  • Ginko
    Ginko Mar 04, 2009
    Try the following codes: 0414, 0902, 0801, 0708, 0639
    If they do not work, then you need to use the auto code search feature.
    If the codes given did not work, then the only way to use this TV is performing the Auto code search procedure, as in page 8 of user manual below:
    SRU3004WM-17 BL OM.pmd
    I quote:
    "If your product does not respond after you have tried all
    the codes for your brand, or if your brand is not listed,
    try searching for your code by following these steps.
    1. Manually turn on the device (TV, VCR, etc.) to be
    controlled.
    2. Press and hold the SETUP button until the red
    indicator stays on, then release the SETUP button.
    3. Press and quickly release the desired mode button
    (TV, VCR, etc.). The red indicator blinks off once.
    4. Press the CHANNEL UP button repeatedly (up to
    300 times) until the device to be controlled changes
    channel. The red indicator blinks off with each
    button press. If you accidentally overshoot the
    code required, press the CHANNEL DOWN button
    to backtrack through the library until the device
    changes channel. Pressing CHANNEL UP changes
    direction to forward again.
    5. Press and release MUTE to install the code."
    Here also all the codes for your TV, and code procdures explained. As on all other sources, the Sabre codes are not listed.
I'M LOOKING FOR THE 4 DIGIT CODES FOR A PIXEL TV TO SET UP A UNIVERSAL REMOTE CONTROL
How can I manually setup my universal remote control?
www.p4c.philips.com/cgi-bin/cpindex.pl?...
Philips LCD TV 32PFL7684H 81 cm (32") Full HD 1080p digital TV with Pixel Precise HD. 32PFL7684H/12. 32PFL7684H/12. Search for information about this product. Product ... Enter the 4-digit RC code of the device you wish to setup.
26PF7521D/10 26" LCD digital widescreen flat TV Pixel ...
Search for information about this product ... In digital mode, press the 'DIGITAL TV/MENU' button on the remote control to display the setup menu. Press the cursor up/down button to ACCESS RESTRICTIONS and press the cursor ... Note: If you have forgotten your personal 4-digit pin code, enter the universal code (0711).
Searching for Your Code - Universal Electronics Remote ...
www.urcsupport.com/html.php?page_id=314
Dec 22, 2015 | Universal Remote Control Televison & Video
I HAVE A HCT 24" FULL HD LCD TV and I need a code for the remote control I have a philips universal
The booklet with the remote usually has the number and they are typically universal for that brand. If its not in the booklet then it may not be compatibility.
Jul 16, 2014 | Philips SRP2003/27 Infrared Universal...
Remote control codes for sabre tv
When are you people going to learn. The only way you will get it to work is to find the same remote that come with the tv, That is what happens when you buy unknown brand (Electronics) Not evan a good universal remote will work on them, Stick to a known brand.Like jvc,sony, toshiba,lg,panasonic. Then you won,t have that problem. If the dog ate your remote,Because you for got to (Feed) it.
Oct 21, 2012 | Sabre LCT371BKA LCD TV
Cannot pmy "Direct TV Satellite Remote, so I can control TV Sound
10178 or 11331 or 11610, depending on the model of your remote.
Sep 13, 2009 | Syntax LT26HVE 26 in. HD-Ready LCD...
Does anyone have the At&T U-verse remote codes?
Here is the list of universal remote codes given by PROSCAN in your owners manual. I hope this helps you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
May 18, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Codes
Here are some sites that will have your codes and instructions on how to enter them:
  1. Universal TV Remote Control codes Universal remote control codes for all TV and VCR brands including: at&t, beery systems, bondwell, curtis mathis, dish network, ge, gemini, ...
    www.tvcodes.com/ - 23k - Cached - Similar pages -
  2. Universal Remote Control Codes Universal Remote Control Codes for DVD, VCR, TV and Home Theaters System.
    www.remote-codes.com/ - 7k - Cached - Similar pages -
  3. Philips Magnavox Universal Remote Code Philips Magnavox Universal Remote Code - Instructions on how to program your Philips Magnavox universal remote control.
    www.universal-remote.net/philipsmagnavox.html - 35k - Cached - Similar pages -
Apr 17, 2009 | Televison & Video
Cannot find the code for a Sabre Model No. LCT320BKA television
I have a comcast universal remote and can't find remote code for plasma 42" lcdtv.pls help
Nov 23, 2008 | Televison & Video
Universal Remote not working
With nearly all brands of universal remote control, there is usually more than one code for Philips. Keep going through the codes until you find one that works correctly.
So if you know that the 1st code doesn't work, then don't save it, and move to the next.
You may find that several codes will actually put the TV into standby, but other functions will be different.
Mar 12, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
Top Televison & Video Experts
