Question about Canon Office Equipment & Supplies
Error E000002-0000 Getting error E000002-0000 for Canon IR2200 which tells me to switch off at side main switch to see if it will rectify the problem. unfortunately this doesn't solve the problem have just got a new drum fitted. This error happened day after please help
  • chrisylis67 Mar 06, 2009
    Thanks for your help and me being so thick but how do I get to the inservice mode. No buttons working except the on/off switch
    help please
    chris
    thanks again, but unfortunately none of the buttons will activate anything
    cheers chris
    Sergeant:
  • 199 Answers
As sm -
E002
0000 The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
Main cause The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact,
or the fixing heater is faulty).
To clear the error, execute the following in service mode:
COPIER>FUNCTION>FCLEAR>ERR.
Posted on Mar 04, 2009
  • Sunil Rathod Mar 06, 2009
    to execute service mode
    press star then press 2 & 8 key at the same time then press star
Tip
Error Code Canon iR2200 / iR2800 / iR3300 / IR3100
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Error Code iR2200 / iR2800 / iR3300 / IR3100
Error Code
Detail
Code
Error Name/Explanation of Error
E000
0000
The reading of the main thermistor does not reach 30°C 1 sec after the main power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
E001
0000
The main thermistor detects 250°C or higher.
0001
The main thermistor or the sub thermistor detects overheating (hardware circuit detection).
0002
The sub thermistor detects about 295°C or higher.
E002
0000
· has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
· has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
· has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
E003
0000
The main thermistor reading is lower than 140°C when paper is moved.
0001
Low fixing temperature detection after standby (by sub thermistor)
E007
0000
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
E010
0000
After the main motor drive signal is generated, the clock signal does to arrive within 1.3 sec.
E014
000
After the fixing motor drive signal is generated, the clock signal does not arrive within 1.3 sec.
E019
0000
The waste toner case is full of waste toner.
E032
0001
The DA unit connection is disconnected (after connection).
E051
0000
At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
on Mar 14, 2010 | Office Equipment & Supplies
Canon ir2200 printer error code e0000020000
1. Hit "additional functions" key on the printer's keypad.
2. Press and hold 2 & 8 at the same time for one second.
3. Hit additional functions key again.
4. You've entered service mode. Now hit "copier"
5. "Function" key
6. "Clear"
7. "Err" . There should be an error or the error code in this section select this part.
8. Hit "ok"
9. Restart the printer by switching off the physical black power switch on the side and switching it back on.
For more help visit cbrtechsolutions
Dec 14, 2010 | Canon Computers & Internet
E000000-0000 on canon ir2200 photocopier how to clear? I'm having the "E000000-0000 on my Canon ir 2200 photocopier everytime i turns it on. Is there any way to clear this error?
this is tadesse E000is the main thermiistor (TH1) has poor contact or an open circuit. the termal switch (TP1) has an open circuit.the main /sub heater has an open circuit .the main power supply PCB is faulty. the DC controller PCB is faulty .you can clear starting service mode 1) press the user mode key *
2) press '2' and '8' on the keypad at the same time
3)press the user mode key * on the contrl panel
(copier, fuunction,clear,ERR
May 19, 2010 | Office Equipment & Supplies
ImageRUNNER 3300 All-In-One Laser Printer: PLEASE TELL ME SOLUTION FOR THE ERROR CODE OF IR22...
* 2 8 * ( service mode )
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on
If does not helps replace fixing film assy
May 17, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
IR2200
When I pluge my Canon IR 3300 is showing me to Turn OFF and ON the Switch in the right, if the problem did not solve, so please send solution on Email - rajkumarsingh_kushwah@yahoo.com
Apr 28, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir2200 has an error code e502/0000 what is this please
the code u r asking is a finisher code if u had installed the finisher then reconect the conector again
Mar 03, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Error code E000740-0003
hi the error code means tah lan card cannot be read and faulty check the harnes betwen it and the PCB if its ok change the card thanks.
May 20, 2008 | Canon imageRUNNER 2200
E000014-0000
E000014-0000 ir 3300 canon machine solution
May 03, 2008 | Canon (6981A002AA) for imagerunner 2200,...
458 people viewed this question
old marine
old marine
