Question about Epson Stylus C84 InkJet Printer
I need control codes for an Epson Stylus C84 printer. I need to make it print with a smaller font.
  • 353 Answers
Hi nosnilleb - are you talking here about basic escape sequencies for DOS, or HP PCL Emulation? I think you will find all you need if you simply do a Google search for it. This is really a software programming problem not really suitable for here.
Posted on Apr 22, 2009
Epson Stylus C84 Fuzzy printing every five rows of
Try re-aligning the heads using the alignment software function
Jan 01, 2011 | Epson Stylus C84 InkJet Printer
Please help me. I have a Toshiba Satellite L355D-S7825 Laptop with Vista. Can you Pleaseinstruct me on how to set up my Epson Stylus C84 printer---express Code 70445
The driver is included in your OS. If doing a wired connection, just plug the data cable into the printer. Then follow the on-screen commands (New Hardware Found Wizard). If that doesn't launch, click Start > Control Panel > Printer (under Hardware and Sound). Click Add A Printer to launch the wizard. (If you do not see this command, right click in the Printer Window and you should find it.) Select Use Existing Port, Next, Epson and Stylus C84 in manufacturer and model, Next. Then Set As Default printer if desired and Next. Then you can print a test page and Finish. (If you are using a print server or other type of networked printer, use the Add a Printer Wizard from the Printer window but choose Network.)
Ink levels available through the Printer Properties. Epson Easy Print is available for Vista here: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?cookies=no&oid=23953&infoType=Downloads&com.broadvision.session.new=Yes .
I hope this helps.
(problems with print servers can due to OS incompatibility or bad cables. Replace cables when any printer problem occurs intermittently.)
Jul 18, 2010 | Epson Stylus C84 InkJet Printer
Printer wont print out in colour The inks are full. The black ink works but not the colour inks, Epson stylus C84
Epson Requires Original Epson Ink.
Colors will not come out as they should, and then the words will print out only either top or bottom.
Good Luck....
Oct 06, 2009 | Epson Stylus C84 InkJet Printer
Not printing
If you've just bought a C84 today then you've been sold a second (or even third) hand unit which is clogged solid.
To resolve this you're going to need to clean the printheads which is something I've described here
It's a different printer but the same process applies.
Hope that helps.
Feb 21, 2009 | Epson Stylus C84 InkJet Printer
Stylus is not printing
It appears that gbmalabanan and guest have lost interest in this problem, so I think we may post it as "Solved by Posters".
Jan 18, 2009 | Epson Stylus C84 InkJet Printer
Epson C84
go to printers, right click on the printer icon, choose printing preferences, then click on maintenance. you will find everything you need there.
Jul 01, 2008 | Epson Stylus C84 InkJet Printer
Epson Stylus C84
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The durabrite inks that EPSON invented is brilliant when you print pictures but it tends to harden very easily
Thanks for reading!
Mar 16, 2008 | Epson Stylus C84 InkJet Printer
CAN NOT PRINT LWORKS FILE TO THE EPSON STYLUS C84 PRINTER
Can you print something with a different program such a Microsoft Word? If you can then the problem is with LWORKS if not then the problem is with the printer driver. Please respond so I can help more.
Thanks for reading!
Nov 29, 2007 | Epson Stylus C84 InkJet Printer
CAN NOT PRINT LWORKS FILES IN EPSON STYLUS C84 PRINTER
Hi there HarryW - what is the "LWorks" program? Is it a Windows program - if so, you don't need a separate driver for it. All you need to ensure is that the printer is properly installed on your Toshiba as a Windows printer. If it isn't installed, just insert your Epson C84 CD and follow the instructions.
If you don't have a CD, go to
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=23953&prodoid=36033903&infoType=Downloads&platform=All
to download the driver (Printer Driver v5.4cA).
If Lworks is not a windows program, or if you have any further queries, report back to me with a new comment.
Please rate this solution if it has been helpful to you.
BIG PROBLEM
If any of the ink cartridges are needing to be replaced, the Epson C84 will not print, you will have to change the cartridge, if you lift up the printer lid the carrier will stop at the empty ink colour.
Nov 14, 2006 | Epson Stylus C84 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
98 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
