Question about Canon PIXMA MX850 Multifunction Printer
How to reset the Canon MX850 Printer, after ink change and counter reset? After I had changed ink cartidge and reset ink counter, I was able to print without problem. But this was only for a few days. Now I see an error message that the ink volume/status cannot be correctly read.
  • 1 more comment
  • myamiga Apr 29, 2009
    Hi all,
    I refilled my pgi5BK but the printer displays 'Cannot detect ink level'
    All other colors were refilled and no errors.
    The printer refuses to do anything other than show the error message.
    Thanks
  • Herbert Metz
    Herbert Metz May 11, 2010
    Did you use new, used, or refilled cartridges?
  • dlaurent46
    dlaurent46 Sep 15, 2012
    Thanks I been trying to figure out My MX850 for years
  • 33 Answers
One way is to hold the 'Stop/Reset' button for at least 5 seconds until the display shows a new message about ignoring the current ink condition. This does not reset the chip but it does allow you to continue printing with the refilled ink tanks.
Posted on Apr 29, 2009
    The reset will only work as long as the ink tank is in the printer. If it is removed or refilled you need to reset the status. The printer will continually show the low ink status but will allow printing anyway.
  • myamiga Sep 02, 2009
    The cartridge without chips will not work once the printer has set the low ink warning. You must use cartridge with a good chip then the above process will work.
This advice doesn't help me!
When I pressed the Reset-Button nothing happend. The Error Message comes again and again. Also when I pressed it 4 seconds and more.
I think, there must be an other way to reset the printer.
I use new ink cartridges without chips. I only use the old chip and put it in the new cartridges. It worked every time till now. One of the cartridges isn't work now. I didn't now the reason.
Please help me!!
I thank you in advance for your kindly reply!
tho-bln,
Berlin, Germany
Posted on Aug 31, 2009
  • mpeters957 Aug 16, 2011
    how do i fine the cartridges
Canon mp258
Some Canon printers require a reset of the "print counter" this is a method used by the manufacturers to get more money from the printer. If you can find a service shop they should be able to reset the counter for you. Ask them how to do it for your model and then you can save yourself the hassle in the future.
Jun 15, 2013 | Computers & Internet
Where can I get a Parts List for a Canon MX850 MF Unit
Ink Absorber Full
This may clear the ink absorber problem.
There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Apr 23, 2013 | Canon PIXMA MX850 Multifunction Printer
It is saying that the ink absorber is almost full how can we change this
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. There are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk. I will not advise you as it is not a permanent solution.
Sep 21, 2011 | Canon PIXMA MX850 Multifunction Printer
I have a Canon MX850, I don't understand why my big black ink cartridge is full and it uses only the small one, how can I change to use the big one?
The printer use big PGI-5bk cartridge to print documents and text.When you print photos or some other pictures printer use small CLI-8bk cartridge because this cartridge has a photo ink.If you print text and it print blank page that mean the nozzle on PGI-5 cartridge is clogged.Try cleaning test on maintenance menu on printer.
Oct 29, 2009 | Canon PIXMA MX850 Multifunction Printer
Help!Have Canon printer.Changed cartridge, but can't print!
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Oct 16, 2009 | Canon PIXMA iP1600 Printer
Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black...
Canon PIXMA MX850 Multi Function Printer Printer Canon MX850 will not print from... Answer Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink... (More) Canon MX850 will not print from small Black Ink Cartridge - 8BK. It only uses the large black ink cartridge and I have a drawer full of small 8BK cartridges. How can I get it to use the small black cartridge and not the large black cartridge? Thanks
Sep 30, 2009 | Canon PIXMA MX850 Multifunction Printer
Waste ink couter
You need to locate the L shaped plastic under the ink cartidge and then clean with water ...
Jul 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Waste ink tank almost full i950 printer
Hi!
For resetting the waste ink counter---
  1. Start with the printer OFF
  2. Hold down RESUME and then hold down POWER
  3. release RESUME
  4. press RESUME twice, then release POWER
  5. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
pressresume button 3 times - light color will change to orange- It will Reset waste ink counter.
Do rate this solution if you found it helpful
Thanks
Rylee
Feb 07, 2009 | Canon i950 InkJet Photo Printer
Black ink cartridges
Make sure you are not printing with "photo" settings. Reset to defaults from the preferenceies, select plain paper. See if that solves it.
Nov 13, 2008 | Canon PIXMA MX850 Multifunction Printer
Canon Printer not printing
Clean the heads, the printer is not reading cartidges. Is yours a model that needs the ink levels reset to funtion correctly, then do this too.
Feb 13, 2008 | Office Equipment & Supplies
Canon PIXMA MX850 Multifunction Printer Logo
3,661 people viewed this question
old marine
old marine
