Question about Microsoft Windows 98 Second Edition for PC
Disabling the adjustments of Date & time??
We have a clocking in system here at my work place. But some people are adjusting the times to get out earlier and is causing us major issues. I have tried to search everywhere for the answer but not having much luck. Im not sure weather this is possible in Winows 98, where as in Xp u can disable the changing of time and date. Any ideas???
Thanks in advance
Emma
  • Emma J
    Emma J Mar 11, 2009
    Thanks for the help Lee (again) I did try this. It worked once only Ive just tried to do this again and it didnt work.
    Any other suggestions?
    Thanks
  • Emma J
    Emma J Mar 11, 2009
    Anyone know how to open command.com usingthe hex editor, I have gone as far as opening command.com but dont know how to enter the hex view?????
  • Microsoft Master
  • 4,806 Answers
Hi there.
This is the best i can remember about Win98
In Win98, rename the timedate.cpl to _timedate.cpl from your system folder and open command.com in a hex editor and go to the location that is on or around 0x010b36. there you will see a table of DOS commands.
simply rename "time" (and/or "date") to something else (as long as it's exactly 4 characters long!). then bring up a new DOS window and you will see that it only accepts your new command for changing the time and date.
This method, in combination with (renaming timedate.cpl), and
making sure that your BIOS settings are password protected, should prevent virtually anyone who is a non-guru from changing the system time.
Good luck and thanks for using FixYa!!
Posted on Mar 04, 2009
  • Lee Hodgson
    Lee Hodgson Mar 11, 2009
    hi there,
    you can download a hex editor free from the net, you say it worked first time? It sounds to me like one of your staff knows your admin password and/or bios password or is far more clued up with computers that they let on.
    Change all the admin and bios passwords, log in to the admin account and try again, if the computer has a chassis lock or a hole for one is suggest you lock it with a padlock as the bios password can be wiped by shorting pins on the motherboard.
    Good luck with it and please post back with the results if you need any more help.
    regards
Set clock on computer
  1. Press the Windows key on your keyboard to display the taskbar if it isn't visible.The Windows key has the Windows logo on it.
  2. Right-click the Date/Time display on the taskbar and then choose Adjust Date/Time from the shortcut menu.
    The Date and Time dialog box appears.
  3. Click the Change Date and Time button.
    The Date and Time Settings dialog box appears.
  4. Enter a new time in the Time field.
    You can also use the up and down arrows next to that field to change the time.
  5. If you wish, click on a new date in the calendar display and then click OK.
    You can also change the time zone, if necessary.
  6. Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
    If you don't want your computer to adjust for Daylight Saving Time, click Change Time Zone and click the Automatically Adjust Clock for Daylight Saving Time check box to turn this feature off.
  7. Click the Change Date and Time button.
  8. Enter a new time in the Time field.
  9. If you wish, click on a new date in the calendar display and then click OK.
  10. Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
Jan 20, 2017 | Computers & Internet
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
How to adjust date and time free of charge
You did not specify the phone you using.
To set date and time on your nokia phone
Select Menu > Settings and Phone > Date and
time.
Select from the following:
Time - Enter the current time.
Time zone - Select your location.
Date - Enter the date.
Date format - Select the date format.
Date separator - Select the symbol that separates days, months, and years.
Time format - Select the time format.
Time separator - Select the symbol that separates hours and minutes.
Clock type - Select the clock type.
Clock alarm tone - Select the tone for the alarm clock.
Alarm snooze time - Adjust the snooze time.
Workdays - Select your working days. You can then set an alarm only for working day mornings, for example.
Automatic time update - To update the time,date, and time zone, select On. This network service may not be available on all networks.
Regards
Jun 30, 2011 | Lands Phones
How do I change the time on my TIMEX T307S clock?
Hello
To adjust time follow this.
Auto-Set Time and Date Settings
This model is equipped with the Auto-Set feature, meaning that the time and date have been programmed at the factory
and will already be set when you first plug the model in. Auto-Set will automatically adjust the time and date settings for
daylight-saving time and leap years. Auto-Set is programmed for Eastern Standard Time; if you do not live in this time zone,
you can easily switch the setting to one of six other time zones.
1. To change your time zone setting, press and hold the 8 Time Zone Button. The current Auto-Set Time Zone in the
lower-right-hand corner of the display will flash for approximately ten seconds, after which the display will revert to the
standard clock display.
2. While the Auto-Set Time Zone is flashing, press the 1 Reverse and 6 Forward Buttons to select your time zone.
The display will show each zone's current time setting. There are seven zones to choose from:
Auto-Set Time Zones
Z-01 Atlantic Standard Time
Z-02 Eastern Standard Time
Z-03 Central Standard Time
Z-04 Mountain Standard Time
Z-05 Pacific Standard Time
Z-06 Alaskan Standard Time
Z-07 Hawaiian Standard Time
3. Find your time zone, then press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the
setting to lock into place.
Manual Time and Date Settings
1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator.
3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting
to lock into place.
4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year.
5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the
4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day.
6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place.
Mar 15, 2011 | Timex (T307S) Clock Radio
Set right time on WIL
Hi this is how you can do it
First go into settings then calender.
This option lets you adjust the date and time of the console's internal clock. Please note that the Wii console uses a 24 hour clock. For example 1:00 pm is displayed as 13:00.
To Access the Calendar
  1. Access the Wii System Settings
  2. Choose "Calendar" on System Settings 1.
To change the Date
  1. Point at the up or down arrows for the part of the date you wish to chance (Month/Day/Year).
  2. Press the A Button on the up or down arrow to adjust the date as desired.
  3. Point on the "Confirm" button and press the A Button to set the date.
To change the Time
  1. Point at the up or down arrows for the part of the time you wish to chance (Hour/Minutes).
  2. Press the A Button on the up or down arrow to adjust the time as desired.
Jan 18, 2011 | Nintendo Wii Console
System date is incorrect ... How do i reset the system date
The easiest way to do this is by double tapping the time in the Taskbar. It would be in the bottom right hand corner.
This would then bring up the "Date/Time Properties" where you can set the correct date, time, Time Zone and select the tick-box "Automatically adjust clock for daylight saving".
What you have to remember though is if the terminals batteries are discharged and it cold boots then it will loose the time settings.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Jun 25, 2010 | Psion WORKABOUT PRO
How to set the clock on my computer
Double click the clock down in the right lower corner click the middle tab and select your correct time zone. The computer should set the time automatically from here on out
Apr 05, 2010 | Dell Inspiron 530s Desktop Computer...
Clock is set to Pacific time. I need to have Mid west time
Right click on the time display in the system tray. Click on "adjust date/time" in the menu that pops up. On the "date and time" tab, select button to "change time zone." Select new time zone (you can also select daylight savings time adjustment here). Click OK to exit time zones list, OK to exit date/time.
Feb 06, 2010 | Medion md40298 Notebook
Certificate problem
Please check your clock on your machine to see what the date and time if it is correctly configured.
You might also be using a third party software that is conflicting with SSL secured websites. Try uninstalling or disabling the latest software that you might have kept may be that could be the cause.
Please do vote for me if you liked my solution.
Thanks
May 25, 2009 | Computers & Internet
Time clock shows the date 3/8/2009, should be 3/9/2009
Right click the clock on the desktop, and choose adjust date/time. Adjust it, and enjoy.
Mar 09, 2009 | The Times ROYAL TC100 TimeMaster Time...
Microsoft Windows 98 Second Edition for PC Logo
81 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
