Question about Toshiba Satellite A215-S7422 Notebook
Toshiba satellite a215s7422 screen blackout problem, however, computer powers up and fan is running. external monitor will start in safe mode. sometimes i see the word signal on external monitor. help
  • peldredge Mar 05, 2009
    Which drivers?
    Scholar:
  • 82 Answers
Sounds like your refresh rate is incorrect
Boot into safe mode. Go to Start > Control Panel > Under Appearance and Personalization , select Adjust screen resolution ,
Selct your laptops display , set the resolution to 1024x768 , click on advanced settings then click the monitor tab at the top.
In the box below , select Use hardware default setting .
Hit ok.
If that doesnt fix it something is wrong with the drivers.
Start in safe mode with networking and get the drivers from here and install them.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1852724&rpn=PSAFGU&modelFilter=A215-S7422&selCategory=3&selFamily=1073768663&selModel=1852724%7CPSAFGU
Posted on Mar 05, 2009
I have a toshiba satellite l455d-s5976 black screen
Sounds like it has overheated and damaged the GPU on the mother board. There are companies on flea bay that will re ball the GPU for you.
Jan 24, 2014 | Toshiba Satellite L455D-S5976 Notebook
My Toshiba Quasimo has red vertical lines running down the screen and it will only start up in SAFE MODE. I've been told by several people that its the motherboard graphics card. Is this the case and if so...
Plug the computer into an external monitor. If the picture is normal the screen on the laptop needs replacing. If there are lines on the external monitor then its the motherboard.
Welcome to Toshiba
Oct 14, 2010 | Toshiba Qosmio G10-133 Notebook
Baterry went off. i have charged it but the screen wont come on though i hear the fan. i have to remove the battrey to put it off. have tried an external monitor and it says computer on sleep mode. press...
Perhaps a result of the auto display off. press any key to activate the screen again.
If using the LCD screen, make sure the priority is not set on an external monitor. To do this, press the Fn function key combination to set the display priority.
if you use an external monitor:
1. Check whether the monitor is switched on
2. Check if the power cable is properly connected
3. Check if the cable menguhungkan external monitor and the notebook is connected correctly.
4. Try to set the constrast and brightness on the external monitor
Nov 01, 2009 | Toshiba Satellite A355D-S6921 Laptops
I have a toshiba satellite laptop the screen is black
Shutting the computer down could be done by holding the Power Switch down for 10 seconds, rather than unplug/no battery "solution". A blank screen is more often than not caused by the failure of the screen's backlight. Plugging an external monitor in the ext monitor port would verify the computer still works, and I am sure it does.
Oct 10, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite a215s7422 screen blackout problem. computer powers up in safe mode and on an external monitor only. tried downloading display drivers and flashing bios-both failed (failed to find...
As you can see an image on an external monitor, this means your video card is OK.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 05, 2009 | Toshiba Satellite A215-S7422 Notebook
My laptop not working Toshiba Satellite A135.
ok i got it as u said that u can hear the fan and it powers up but u cannot see anything on the screen iin that case what u can do is that disconnect the ac adaptor and then take the battery out of the computer and then without the power cord and the battery press and hold down the power buttoon for one minute and then connect the adaptor and the battery and the try and turn on the computer and then still if u do nnot see anything on the screen then turn on the computer and then connect the external monitor and if u see the display on external monitor then the lcd screen has gone bad and if u do not see the display oon the external monitor also then the video card of ur laptop has gone bad replace it ....good luck
or what u can try is that try lkgc (last known good configuration) and then try and boot the computer or try in safe mode....good luck
Jan 29, 2009 | Toshiba Satellite A135-S4527 Notebook
PROBLEM WITH MY SATELLITE M35X-S111
Check to see if your Display is bad or Video is bad..
To Do This....
Plug an External Monitor into the laptop serial port..Boot the laptop and use the function key plus F5 to boot to external screen... If you see your PC running on the external screen it is a Video card/chip problem.....
Do your lights run ..the Power Light/Battery light/ hard drive light??? Do you hear the hard drive spinning??
May 19, 2008 | Toshiba Satellite M35X-S111 Notebook
Toshiba Satellite M30 Montior Blackout
have you tried changing the resolution, if not try this power on your laptop press F8 run in safe mode go to device manager an disable your display adapter after disabling reboot windows after rebooting go back to device manager enable display adapter and go display properties an change resolution.
Mar 15, 2008 | Toshiba Satellite M30 Notebook
Toshiba Satellite A215-S7422 Notebook Logo
217 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
