Question about LG 42LC2D 42 in. LCD HDTV
Remote stuck i have a LG 42 HDTV the remote will not work every button i hit nothing happens but the STB lites up....help thanks
  • smarchetti Mar 05, 2009
    yup that worked...new at this thanks!!!!
  • 71 Answers
Need to reconfigure the remote
Posted on Mar 05, 2009
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
I need to program my telus remote to turn my 46"
Press and hold TV, then OK at the same time. Let go of TV and OK, top buttons should quickly blink red then stop press the code 1019 then hit the bottom right button marked ENTER or OPTIONS
Remote should now work with tv.
To control volume and power at the same time... Press and hold STB and OK at the same time, let go, red blinking up top enter the code 977 STB should blink red a few times.
Hit STB, see if TV volume adjusts Hit POWER. see if both STB (Set Top Box) turns off and TV turns off.
All should be good.
If both TV and STB do not turn on/off, repeat the process for the code where you enter 977
Jan 29, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
None of Tv controls on side of tv will not work and remote will not work
MAY HAVE A STUCK BUTTON SUGGEST PRESSING EACH BUTTON HARD AND SEE IF ANYTHING CHANGES. THE MAIN MICRO PROCESSOR IN THE TV WILL RESPOND TO BUTTON COMMANDS BEFORE ALL ELSE SO IF THERE IS A STUCK BUTTON NO OTHER BUTTONS WILL WORK AND IT WILL NOT RESPOND TO THE REMOTE.
Dec 17, 2010 | LG 42LC2D 42 in. LCD HDTV
My 42" plasma is constantly changing channells up. remote also not working while this is happening.
I think it may remote controllproblem.channel button or scan button were pressed. you open the remote and clean slighitly all buttons with cotton .
Thyanking you
Aug 11, 2010 | LG 42PB4D 42 in. Plasma HDTV
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Feb 08, 2010 | Directed 434MHZ Remote Control
42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
May 19, 2009 | LG 50PC1DR 50 in. Plasma HDTV
Need remote code for LG HDTV model 47LG90...
Just bought an LG 32" HDTV and have the new Samsung STB, with a Scientific Remote; the code in the remote manual for LG says to use 1005, but after trying it and many others, I used the "Find Code" set-up (991) and (990) in the remote manual and happened upon 1004 for the LG.
While this worked, the remote is a bit awkward, as you have to enter yet another code (998) in order to control the Power for both the TV and Box with the remote; the good news is that the instructions to do this are pretty straightforward and well presented.
Now, I can turn both TV and Box on/off with power button on remote, can change channels with remote and also vary volume with remote!
Hope this helps
Mar 29, 2009 | Televison & Video
32lg30 mkj40653801 codes
A printable manual with codes can be found at http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3252
Jan 21, 2009 | LG 37LG30 37 in. LCD HDTV
The tv sensor is not working on my 42" lg lcd hdtv
Believe it or not...THIS WORKS!!!!
 Look on the back of your set for an external remote jack. It should be the same size as a small headphone jack. If it has one, use a spare headphone plug or your headphones, and plug them in and out about 50 times. This will clean the tarnished contacts and make your remote sensor start working. Your remote sensor goes through a switch on this jack.
Feb 12, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
261 people viewed this question
Computer Repairing
Computer Repairing
