Question about Dell OptiPlex GX520 PC Desktop
Bios default password
What is the default password to get into the BIOS, to set up the boot sequence...on a Dell Optiplex GX520 Desktop
  • Anonymous Mar 19, 2014
    Bios A05 Dell Desktop
  • Dell Master
  • 19,396 Answers
The BIOS default password is just blank, and it is not asked.
When you set a bios password, you are asked to enter a value, therefore if bios is asking the password, the password had been changed.
To reset the bios password if you do not know the password you need to access to motherboard and temporarily remove battery for few seconds.
Removing battery will reset bios and delete the password.
Unplug power cord before accessing the motherboard, and try not touching the motherboard with your finger.
Put battery back in place before restarting computer.
See also the following websites:
technibble.com/..
satyathakur.com/blog/
Posted on Mar 04, 2009
    New Friend:
I have a problem my dell optiplex gx520 has i have forgot my administrator password ...help me
Posted on Mar 08, 2013
Password admin bios
Reset the CMOS by unplugging your Optiplex from the power cable & removing the CMOS battery.
The CMOS battery is just a larger "watch battery" about the size of a nickel. Remove it for a few seconds, put it back in & power it back up. This will reset the BIOS password & restore all the BISO settings to default however.
Oct 16, 2013 | Dell OptiPlex GX520 PC Desktop
To break the bios password on GX520 dell desktop
BIOS should not be passworded unless you are not the original owner. I have never seen it set by default. Some equipment use 0000 as the default but that is usually bluetooth and wireless equipment.
Mar 06, 2013 | Dell Computers & Internet
How to change boot options to usb in dell optiplex gx520
Go into BIOS buy pushing F2 when the machine boots. Once in BIOS, look for boot options and make sure to select USB/External Drive is an option.
Alos, make sure that your current BIOS is able to boot via USB. May have to update your system BIOS
Oct 23, 2012 | Dell OptiPlex GX520 PC Desktop
Dell optiplex desktop freezes up at boot screen. Says drive 2 not found. Bios setup is correct and boot sequence has been setup correctly. Was working before but now freezes up.
Swap out the ram one stick at a time, bad ram has been known to cause this type of symptom, the other thing to check is the motherboard, check the led light on the board is green, if not and it is yellow or amber indicates motherboard issues.
Aug 10, 2011 | Dell OptiPlex GX520 PC Desktop
Bios password removel of Dell Optiplex GX280
If you don't know the BIOS password, and need to access it - you'll have to unplug the AC power then open the case and remove the lithium "coin" or "button" battery from the motherboard. Wait 5 - 10 minutes (allows the capacitors to discharge) and replace the battery. This will RESET all BIOS values to default.
Restore AC power reboot. Enter the BIOS and change the values as desired. To access the BIOS, Press the F2 function key repeatedly during boot sequence. You may need to plug the USB keyboard into a different USB port if it doesn't let you in to the BIOS page.
I hope this helps & good luck! Please rate my reply - thank you.
Feb 22, 2011 | Dell OptiPlex GX520 PC Desktop
How to reset my Dell OptiPlex GX520 PC Desktop Bios password
if you can open the cabinet and there on the mother board you will find a CMOS battery (round one) take that battery and keep it out for around 3 mins and then put it back properly - start your computer - BIOS password will be reset .
Oct 04, 2010 | Dell OptiPlex GX520 PC Desktop
I have an Ubuntu CD but cannot boot from it. How!?!?
Check in your BIOS to see if the CD ddrive is in front of the HD boot sequence.
Mar 11, 2010 | Dell OptiPlex GX520 PC Desktop
Unable to upgrade onboard graphics on dell gx520
Try disabling your onboard graphics in the BIOS. Some BIOS allow this. If you have a sound card, disable the onboard sound too. Count your beeps. they contain a code. Go online and "Google" bios codes. This should give you a starting point to diagnose the problem.
Oct 10, 2009 | Dell OptiPlex GX520 PC Desktop
Reset bios to factory settings in dell optiplex gx520
The BIOS password may be cleared from a Dell Optiplex by removing the password jumper (PSWD) from the motherboard.
Can click the link below to see how its done or follow the steps below :--
http://support.dell.com/support/systemsinfo/documentation.aspx?c=us&l=en&s=gen&~subcat=87&~cat=12
Choose the desktop model and continue.
For most Dell Optiplex desktops, the steps to reset a BIOS password and clear all CMOS settings are:
  • Locate the 3-pin CMOS password reset jumper on the system board.
  • Remove the jumper plug from pins 1 and 2.
  • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
  • Replace the jumper plug on pins 1 and 2.
Else can follow Optiplex User Guides.
Hope it helps !!
Thanks.
Sep 14, 2009 | Computers & Internet
Want to Boot from dvd ROM
when the pc in post usually on dells bios there is a boot menu option it is usually f12
if you don't know what your doing in the bios it is not a good place to test your skills after pressing F12 just choose cd rom for boot
Jan 28, 2009 | Dell OptiPlex GX280 PC Desktop
Dell OptiPlex GX520 PC Desktop Logo
4,175 people viewed this question
Alun Cox
