Question about Frigidaire Dryers
My dyer will not turn on this happened before an i had someone com out and they replaced the fuse. i neeed to know where it is located and where acn i buy the fuse at.
  • Frigidaire Master
  • 3,361 Answers
It will be the fuse agin most likely.
All lint and obstructions must be cleaned from the dryer exhaust system and the attached vent hose.
Need a model number for the fuse location.
Posted on Mar 04, 2009
Honda crv srs airbag light is stuck on checked all conections no fault found need location of control module
Adult acne has got the same causes as acne within our teens. Environmental toxins like exhaust and dust fumes make a difference to the skin poorly. Anxiety is thought to be another component for adult acne. Flareups may worsen although it may not specifically trigger acne. Living is not straightforward with the family offer work responsibilities tossed onus daily. Stress is practically impossible to avoid sometimes. Discover approaches to relax. Another probable reason for acne is hormonal changes in pregnant women. When girls get although these adjustments, it consequences appetite, their temper, and also their skin. Specific medicines may also trigger outbreaks.
http://pureandeasycleanseidea.com/reversaderm-instant-lifting-eye-creme/
May 19, 2016 | Honda Cars & Trucks
Dyer would not work when on extra dry setting. when put on time setting it worked for a few months now it does not stat at all. by passed thermal fuse and still nothing
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Dec 17, 2011 | Whirlpool Inglis IP8200 Dryer
Kenmore electric dryer 90 series part# 3405768 kit # 27918 problems. The dyer heats up, the bulb at the door lights, but the dyer doesn't hum neither does it rotate to dry clothes! I'm unable to locate the...
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Feb 24, 2011 | Dryers
Dyer is spinning but not getting hot
There is a few things that will cause this to happen.Be sure to check and make sure there is proper powr to the unit by checking the wires on the terminal block make sure there is 220 volts.
Next you need to check the continuity on the heating element and all the thermal fuses located near the heating element,fing the one that has no continuity and replace it.
Sep 26, 2010 | Dryers
Dyer is not heating up.it turns on and runs but it just does not heat up i took off hose and clean . also looked in back of dyer by taking off clover to look for fuse please help .
Kenmore dryers have what we call a thermo fuse, usually on top on the burner area - I would check continuity on this unit and replace if nesessary.
If the thermo fuse is okay and dryer heats up with gas, check your igniter and/or gas unit coils.
If dryer heats up with electric elements check continuity at both element ends and/or high limit thermostat.
GOOD LUCK!
Sep 01, 2009 | Kenmore Dryers
Dyer not working
Most likely a faulty heating element or a blown thermal fuse. Both components can be tested using a multimeter. Test for continuity. A lack of resistance indicates a bad component. The thermal fuse located just inside the rear of the dryer and is usually mounted on the exhaust duct. It is about one inch long. If it has no continuity, the thermal fuse is blown. Hope this helped and best wishes.
Aug 07, 2009 | Amana ALG331RAW Gas Dryer
Horn does not work on 2006 dodge stratus
youre horn is located at the lower engine bay its normally around lower chassis rails ok m8
thanks lee
Jan 03, 2009 | 2006 Dodge Stratus
My Whirlpool Duet Dryer is not heating up. Unit is only Two year
If it is a gas dryer. Sounds like thermal fuse. It costs about $12.95. Most appliance part stores carry it all the time. Very easy to replace. Also can be ignition switch (also cheap). If you know someone who is mechancally inclined, after removing fuse,they can run an electrical jumper cord to the two open ends. If the dryer begins drying, then it is definitely the fuse.
Go to Whirpool site and get part number and diagram to fix. Maytag repair can help at a costly figure after they order part since Whirpool bought Maytag.
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
49 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
