Question about Kenmore 24 in. 15689 Built-in Dishwasher
Lower spray arm will not spray water - Kenmore 24 in. 15689 Built-in Dishwasher
    Scholar:
  • 46 Answers
I just had a simliar problem with all spray arms and solved the problem by cleaning the food screen. Basically, it takes water pressure to make the spray arms rotate. Before assuming there is a failed part, make sure the spray arms are getting max water pressure by checking the food screen. Here's how I serviced my Kenmore dishwasher.
The lower arm assembley is removable by twisting the center plastic piece. It's not very tight and should come off easily by twist with a pliers (but gently). Then remove the tubing to the upper arms (Two screws). Then remove the bottom drain cover (4 star screws).
Under the drain cover are two more things to remove. One, a plastic plate over the bottom of the water drain (1 screw). Two cover to the food screen (1 screw). After removng the screw to the cover of the food screen, it will be a little difficult to remove that cover. The side opposite the screw requires releasing a catch with a screw driver. It's hard tell which way it releases, just keep trying different ways until it pops up. The cover may stick a little beacuse of the food stuck in the screen.
Once you have access to the screen, the screen can be removed by pulling on the center shaft (spring loaded) with a needle nose pliers and lifting the screen straight up. (Note: there maybe a blade next to the screen used to braek up the food.)
After removing the screen, clean it (I used a plastic scrub brush).
Reassembly is performaing these steps in the reverse order.
Hope this helps!
Posted on Mar 04, 2009
  • Mindcell Mar 19, 2010
    Update...Chopper assembly is also common replaceable part ~$25. Tip; do not allow large chunks of food in washer, and be carefull to remove all broken glass if something should break in the dishwasher.
Dishwasher lower spray arm will not move or turn by hand
Search Results
    Dishwasher Spray Arm Not Turning ' Home Guides ' SF Gate
    homeguides.sfgate.com > Foreclosures > Other Foreclosures
    Remove the lower tray of the dishwasher to freely access the spray arm. Turn it byhand, and if it doesn't move freely, you will need to unscrew or unbolt any ... How to Remove the Lower Wash Arm on a Maytag Dishwasher MDB7000AWW ...
    Maytag dishwasher bottom spray arm doesn't turn - Home Repair Forum
    www.homerepairforum.com > Forum > Indoor Home Repair > Appliances
    Jan 3, 2009 - 5 posts - ‎3 authors
    I'm now soaked, but I was able to determine that the lower arm isn't turning. There's a LOT of water coming out, but it doesn't move. Turning by hand I can turn it freely, it spins like a top. .... You may not post new threads; You may not post replies; You maynot post attachments; You may not edit your posts.
    How do i remove the lower spray arm of my Maytag .
Jan 18, 2016 | Maytag Dishwashers
Neither of the arms are spinning water
Your spray arm jets are probably clogged.
Depending on the model, the lower spray arm generally has a nut or thumb/butterfly screw (plastic) that you remove and then lift the spray arm off. I always soak mine in hot soapy water and then flush with hot water. If debris such as pieces of paper, bone, peelings are in there, you'll need to take a tweezer or toothpick to remove them from the jets. The upper spray arm usually has the same apparatus and you can follow the same procedure.
The upper spray arm receives water pressure from a tube that runs up the back of the machine on the inside. If the connection has been knocked out of line, the water can't flow through the tube to the spray arm. My kids used to knock ours loose when they loaded the lower shelf. Pull out the top shelf and see if the plastic connectors are in place. If not, snap them back on the shelf supports and this should align the tubes.
I hope these suggestions help your problem. If so please come back to Fixya and rate my advice!
Jul 21, 2011 | Whirlpool Dishwashers
Top rack does not wash dishes.
Possible causes of spray arm inefficiency:
Loading large or tall items in the lower basket which stops the arm revolving.
Upper spray arm split along seam.
Upper spray arm blocked.
Under dosing of powder causing foam and reducing upper spray arm water pressure.
Blocked strainers reducing water to circulating pump, therefore reducing upper spray arm water pressure.
inefficient wash motor impellor (faulty)
Dec 21, 2009 | Kenmore Dishwashers
Very low pressure getting to spray arms
I removed the lower spray arm, and then the filter. I found that there was a lot of buildup under the filter area. I scraped the buildup off. I found that it was restricting the input of water flow to the pump
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Lower and upper spray arm will not turn
If the spray arm is not binding due to worn out plastic bushings, then it could be a lack of water pressure, because it is water pressure which makes the arm turn.
Give it a gentle tap in a clockwise direction,,does it spin easily?
If it does,,then it will be lack of water pressure that will be the cause.
Possible pump wear or failure.
Jan 30, 2009 | Maytag MDBE790 Built-in Dishwasher
Lower spray arm not rotating
rotation is only by water coming out of angled jets at end of spray arm. probable that these are blocked. take spray arms out and run water thro centre hole and remove whatever is blocking the jets - usually rice or sweet corn
Aug 05, 2008 | Dishwashers
Dishwasher
Plugged filter or spray arms .
Sep 30, 2017 | Dishwashers
Lower spray arm
New Spray arm split around center joint so when it gets hot it opens up spraying water under door
take it back for another
Alan
Oct 13, 2007 | Hotpoint 23 in. BF50 Built-in Dishwasher
Small plastic top and mid spray arm do not turn, bottom does
decrete, you want to get down to the chopper and screen. If the screen is plugged up with gunk there won't be enough pressure to reach the top spray arms. Check out the posted pics. Remove the lower spray arm. Rotate the rear feed arm to the right until it unsnaps from the tube going up the back. See the 4 torq screws holding the filter on. Remove them. Lift the filter up. Now you will see the chopper inlet cover. 1 torq screw holding it in. Lift it up and there's the chopper and screen. Catriver..post back
Apr 09, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
Kenmore 24 in. 15689 Built-in Dishwasher Logo
498 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
