Cars & Trucks Logo
Posted on Mar 31, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Renault clio 1.5 dci speedometer not working handbrake,abs,and service light all on continuesly
Travis cook
Level 2:
Champion:
  • Renault Expert 308 Answers
  • Posted on Apr 12, 2013
Travis cook
Renault Expert
Level 2:
Champion:
Answers
308
Questions
0
Helped
229927
Points
373
Your abs system is faulty vehicle gets speed info from abs comp and the lights are to warn you of the abs fault
5 Related Answers
Anonymous
  • Posted on Aug 18, 2010
SOURCE: renault clio abs, stop,handbrake and service lights all on
plz
Anonymous
  • Posted on Feb 01, 2009
SOURCE: i cannot locate screenwash bottle on clio dci 2003
bottle is at the back of the engine bay to the right as you look at it.
Anonymous
  • 1036 Answers
  • Posted on Jun 17, 2008
SOURCE: renault clio 1-5 dci (2002)
Hi there!
It's very likely a valve stem seal that has split. This will allow oil into the cylinder from the crank gallery.
Off with it's head! I'm afraid.
The only other thing it can be is overfueling - but then it will be sputtering and lagging on acceleration.
You can check which cylinder is affected by removing the plugs and looking for the oily one. They will all need replacing really as it's false economy to do just 1. The seals are cheap. I would get a new cambelt fitted at the same time - as it has to come off anyway.
(If this leads to a solution, please take the time to rate as Fixya! - Thank you)
Anonymous
  • Posted on Feb 08, 2009
SOURCE: renault megane 1.4 16v
could be a sensor will need to hane a fault code read to detrmine where the fault is
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Sep 21, 2011
SOURCE: Question? will a 52 number
yes it will providing you have the donor next to you for any final bits that dont line up ,But i wouldnt advise you to do it under the EEC directive ,the certificate of homoglonation wouldnt be correct so therefore the vehicle cannot be tested for the MOT .Unless the appropiate`paperwork is issued by a technical engineer then the work carried out by a authorised garage with a VAT number ,then said vehicle inspected by the technical engineer to ensure the fitting is correct and to verify the engine number .Now under the europeon directives iam a qualified motor vehicle technician and a member of the appropiate body so iam a position to offer you the technical engineers report and draw up a project for this job for the garage and the minimum fee for this sort of work is 1000 euros.Now please remember that unless i sign the paperwork for this engine swop you cannot do the the job and legally use the said vehicle on the road or get the cars documents changed and without this you cannot MOT the vehicle or get insurance .I didnt do 6 yrs at college for nothing which i did when i lived in the UK the certificates were only good to hang in the privvy but here in spain they are worht a lot more and lets hope that the laws are changed soon in the Uk before i die anyway so i can open a office and charge what i like for a rubber stamp on a bit of paper just like spain .
How much gearbox oil do i need for renault clio 1.5 dci
gearbox oil capacity for a renault clio 1.5 dci 2002
1helpful
On my dashboard the abs, handbrake and service light are constantly on will not go off.
Hi
You need to have a diagnostic scan carried out to read the relative fault code, which will give you an idea of what is needed. Clio common for split ABS ring on front driveshafts. Scan at a good local garage should be around £30- 40 ish
Regards
Martin
3answers
My Renault Kangoo injector pump gave up and I had to get a new one fitted. Now a mechanic friend has told me that no matter how well I wash out the tank, the fiings will go through the system and wreck...
Well my friend from my Experience with Renault kangoo all i can say is they all have that problem with that injection pump and If i were you I would go to a junkyard and get one from a wrecked car because it will cost you lot of $$$$ to get that pump. and if you get a pump just put it in i dont think that would matter because it will fail when it suppose to just like your old one. Good luck
2helpful
Renault clio 2ltr sport back brakes
two brake shoes with a auto adjuster at the top ,handbrake lever on right shoe and two return springs .if you cant remember take the other side off and look at that
1helpful
I cannot locate screenwash bottle on clio dci 2003
1helpful
Starting problems
get the crank sensor (TDC sensor) replaced. It is a very common problem on Renaults. Join us on Renault Forums. Cheers
1helpful
3answers
Renault clio
#1 if theairbag light is on. it means the airbag system is basically ofline. it cant deploy even if u crashed. but a god idea to get it sorted. usually a bad conection under one of the front seats.
Top Renault Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
john h
Are you a Renault Expert? Answer questions, earn points and help others
