Home | GE | Profile JT910SASS Electric Single Oven | F7 code keeps fla...
GE Profile JT910SASS Electric Single Oven
Problem for GE Profile JT910SASS Electric Single Oven
F7 code keeps flashing on upper oven, nothing on keypad works
By bgrivers on Mar 04, 2009
F7 code keeps flashing, nothing on keypad works. I can use lower oven with the dial and also my counter range top but the F7 won't go away, nor the beeping. I can push the start button or stop and F7 will go away temporarily but returns within seconds. The model number for upper oven is JKP27BOA1BB; Serial #TT6576910. Please tell me how to correct this problem; I'm a senior citizen living on a fixed income and don't have funds to hire someone to fix it. Thank you so much.
Best Solution
posted on Mar 04, 2009
Very Helpful)
jumptrout51
Rank: Guru  GE Expert
Rating: 89%, 975 votes
A function pad is probably stuck.
Push all buttons several times each. Often this will clear a stuck pad.
If that does not work replace the clock.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
cargurudude
Rank: Master
Rating: 84%, 12 votes
You have a faulty keypad, you need to turn the oven off at the fuse box, and thne remove the faceplate, as well as the keypad, and then clean the terminals with an eraser, making sure they are cleaned and debris free.
Also check for a reset button no the back.
Was this helpful?
Yes
No
Solution #3
Not Rated)
ButtFuzz
Rank: Wiz
Rating: 83%, 341 votes
I do not know this for sure, but from reading the literature and several sites on the internet, I conclude that the error code "F7" means the control panel itself is bad. Best guess is this is a $250 fix.
Sorry for the bad news. For further clarification, you may call the GE answer center: Toll Free: 800.626.2000
Take care and good luck,
Rob
Comments:
Mar 04, 2009
- If you are feeling industrious, see this post on fixya! :
http://www.fixya.com/support/t146996-f7_error_code
That may fix it!
Was this helpful?
Yes
No
Popular Solutions for GE Profile JT910SASS Electric
Questions and Unsolved Problems for GE Profile JT910SASS Electric
Do you recommend GE Profile JT910SASS Electric Single Oven?
Answer
Answer
We woke up to the stove beeping and flashing F7 in read and EA to the right in green letters? We... (More)
Answer
We tried disconnecting powe and it briefly went off. When we tirned the oven on it shut down and the... (More)
Answer
I have this model oven from the USA but am living in Europe. Anyone know how I can connect this for... (More)
Answer
Oven seems to be shut off but convection fan keeps running.
Answer
I can enter bake and temp but when i press start nothing happens so the oven never turns on...help... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Profile JT910SASS Electric...:
Top Oven Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Oven Experts
Top Range & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(410) 609-0006
A Leader In Kitchen Equipment Sales,...
Allegro Restaurant Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
