F7 code keeps flashing, nothing on keypad works. I can use second oven with the dial and also my counter range top but the F7 won't go away, nor the beeping. I can push the start button or stop and F7 will go away temporarily but comes back again with the same problem. The model number is JKP27BOA1BB; Serial #TT6576910. Please tell me how to correct this problem; I'm a senior citizen living on a fixed income and don't have funds to hire someone to fix it. Thank you so much.
After much searching, I have found that you have a faulty keypad.
The recommended solution is to unplug the oven, or shut it down at the fuse box, and then remove the faceplate where you can then remove the keypad, and clean the connectors with an eraser, as well as the ribbon that connectes the keypad with the oven.
I hope this helps out.
Was this helpful?
Yes
No
Popular Solutions for GE Profile JT910SASS Electric
We woke up to the stove beeping and flashing F7 in read and EA to the right in green letters? We...
(More)
We woke up to the stove beeping and flashing F7 in read and EA to the right in green letters? We unplugged it, plugged it back in but it continued this way. None of the other keys work, although it beeps when we push Start and Clear. I reset the circuit breaker and still get the same error. Thanks for your help!
We tried disconnecting powe and it briefly went off. When we tirned the oven on it shut down and the...
(More)
We tried disconnecting powe and it briefly went off. When we tirned the oven on it shut down and the error code came back. The key panel is out completely. Thanks
I have this model oven from the USA but am living in Europe. Anyone know how I can connect this for...
(More)
I have this model oven from the USA but am living in Europe. Anyone know how I can connect this for 220 volt? It has five wires - white, black, redl heavy wires, blue and green regular wires. Any assistance is much appreciated!!!
I can enter bake and temp but when i press start nothing happens so the oven never turns on...help...
(More)
I can enter bake and temp but when i press start nothing happens so the oven never turns on...help Thanksgiving is upon us!
