Question about IBM ThinkPad T23 2647 Notebook
IBM laptop cant load XP from externall CD drive
I have an IBM laptop that doesnt have a CD drive,a bit old.I use an external CD drive thats connected via USB.I formatted the harddisk drive externally,but now I currently cant load XP using the external CD drive.what do I do?
  • 65 Answers
Also, if you do have a floppy drive, you can go to bootdisk.com for instruction on creating DOS boot disk with usb support. This will give you access to your cdrom.
good luck..
Posted on Mar 27, 2009
    Scholar:
  • 82 Answers
If you have a floppy drive on it you are in luck.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;310994#XSLTH3135121122120121120120
That would be the most straightforward way to do it.
If not.
Are you able to boot off the external CD?
If so there is another way using the PE , preinstallatoin enviroment.
If not , you said you formatted it externally , which I assume means you have either a 2.5 to 3.5 IDE adapter or a USB to IDE adapter and another PC to format it with.
If you can hook the drive to another PC , you can do the install there , change some hardware settings , run the SYSPREP utility and swap the drive back into the laptop.
Posted on Mar 04, 2009
Have bought a second hand IBM USB Portable Diskette Drive. It worked just fine at the sellers place. Now that I try and use my own PC I load a 1.44 Mb diskette and it tells me to load disk ??? What to do...
Hi Graham,
Your Portable USB 3.5 diskette drive uses a pretty old technology that would come with software or drivers needed to run it. You would need to check on your device manager on control panel. But I would advise you upgrade yourself to better storage devices like the flash drive or the CD/DVD USB portable drives. They are a bit more expensive, but the technology is newer and have less issues. Let's face it, the 3.5 diskettes are getting pretty outdated. Don't you think so?
Cheers & Kind Regards
Sep 24, 2009 | IBM USB Portable Diskette Drive (05K9276)...
My IBM Thinkpad with windows xp when turned on has many colors streaming on the screen. It will not load and what worries me is losing music, video & picture files. What can be done to retrieve the...
Might be video card problem or something that is connected with your video is getting fault, dirty or loose contact is a big candidate. If you can test it using external monitor if it have external monitor port try that first. If external monitor works then back up your files immediately using external media. CD, dvd, flash drive or in another external hard drive.
Second option is to take out the hard drive and hook it into a USB hard drive adapter or a USB enclosure. And retrieve your files if you want on another working computer.
Then the laptop should go to a repair. If you are not so sure of doing this, have your friends that have knowledge on this assist you or bring it to a reputable shop.
Just for an input.
Sep 04, 2009 | IBM ThinkPad T30 2366 Notebook
External Harddrive doesnt show up in harddrive management.
it sounds like a hardrive issue. You can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Aug 24, 2009 | IBM TravelStar 48GH 48 GB Hard Drive
T30 wont reformat
Sounds like you have a faulty hard drive. Can you see or detect the hard drive in the BIOS? To test the hard drive, remove it from the laptop and connect it to a USB hard drive adapter and plug it into a working computer's USB port. If this computer sees it as an external hard drive and you can open the various folders and files, then it os OK and the fault is in the laptop. If the hard drive is faulty, then you need to replace the hard drive in the laptop and install Windows to get the laptop working again.
Jun 03, 2009 | IBM ThinkPad T30 2366 Notebook
Options for installing Windows on old laptop with broken CD drive
Since this Laptop is a older version, there is remote chance of having USB drive (Memory Stick or Pen Drive option), Best way is getting the help of local laptop engineer to connect external cd drive and instal Win XP, which is advisable,
May 30, 2009 | HP Pavilion ZE5200, ZE5200 CTO, ZE5207,...
I have a 600E that had the hard drive reformatted. I don't have a boot disk for the system (only has CD drive) but it won't boot from that when I try to reinstall Win 98. Got any suggestions?
Your cpu is slower than I was thinking of. However you should be able to load XP. When you load XP remove all partitions and set it up on NTFS. Go for a full installation, load, anti virus and any utilities that you want. Get yourself an external hard drive and save all your folders to that after you have finished working on them. That way you will free up your cpu to manage. If you still want to load 98. Try going into the Bios and set the CD drive as your first boot option, with a bit of luck it may work. Once you have loaded your operating system be it 98 or XP, go back into the bios and re-set your boot preferences to HDD then CD Rom. Failing that I can not help you any futher. You may think of up grading to at least a P3 in the future. Another point. Borrow a copy of windows XP from a friend and install that, if it loads ok then you can obtain your own copy if you want to.
Dec 07, 2008 | IBM ThinkPad 600X Notebook
I don´t have internal cd, only external(usb)
You will need an internal CD drive for the machine in order to load XP. If it doesn't recognize the external in the boot menu, then there is no setting to get it to.
Jul 23, 2008 | IBM ThinkPad 600E 2645 Notebook
Cd drive/ USB/ reinstall XP
Nifty little IDE to laptop ide adapters on ebay for under $10 delivered..
remove laptop HD.. use adapter, plug into desktop as second drive.
Load up XP install to a folder.. use a decent file copier so you get hidden files. try filesync 2.xx (look for it),
Back into the laptop, try it..
Only other thing would be LEGACY USB SUPPORT in the bios and an external usb drive... Hopefully your usb problem is XP related and not hardware related..
Feb 12, 2008 | Acer Aspire 3690-2196 Notebook
Hard Drive Replacement T30
Hey there jlricker, in order to accomplish your task you need an external drive, with the ability to do full copy, from another drive installed in your computer. One such option is EZ Upgrade Kit. It includes the external drive case and data copying software. You can use the case and old hard drive as a regular external when you are done. Good Luck!
Jan 31, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T23 2647 Notebook Logo
90 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
