Question about Whirlpool LER5636P Electric Dryer
Whirlpool dryer #LGR4634JQ1 not drying or shutting off
Dryer turnes and blows cold,does not get warm and does not automatically shut off
  • william0828 Mar 05, 2009
    My whirlpool estate dryer is not heating, and not cutting off at the appropriate time.
  • oha603 Mar 09, 2009
    I have the same problem with a dryer less than 3 years old. Dryer spins normally, but no heat. Figure it might be the thermal fuse? The part is available on line for $9.99. Appears to be easy to access, next to the vent tube in the back. Anyone else have this problem? How was it repaired?
    Problem Solver:
  • 8 Answers
This sounds like several problems. Check ur voltage first. Then check ur heating element. If this is good then your problem is with ur motor
Posted on Apr 07, 2009
2 Suggested Answers
  • 14 Answers
SOURCE: whirlpool gas dryer #LGR4634JQ1 not drying or shutting off
MIGHT NNED A NEW IGNITER
OR GAS VALVE SWITCH
STEVE'S APPLIANCE
516-300-3249
Posted on Apr 06, 2009
Gas dryer dries sporadically. dial for automatic dry doesn't move
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ...Replaced outlet, cord, and moved the outlet so we don't have the same ... Whirlpool LER4634EQ0 110 v timer motor, when timer contacts TM .... David Villa 7 months ago ... 3 years and now thedryer won't heat and the timer doesn't advance, ...Missing: cu
Nov 17, 2015 | Whirlpool Dryer. Gas Dryer. 7.0 cu. ft. in...
Why is my inglis dryer not drying?
You must have a gas dryer. Assuming it is a gas dryer, the ignitor is working because she glows. the flame sensor is also working because the ignitor shuts down. The only other thing in the assembly is the solenoids which tend to work properly but short and die when warm, then when cool will work some more much later. very difficult to diagnose. Replace the solenoids and party on Amigo.
Jun 12, 2012 | Whirlpool Inglis IP8200 Dryer
The automatic dry cycle of my Whirlpool LGR4634JQ1 dryer does not work. I'm trying to locate the moisture sensor, but canot find it.
If you are looking for the auto dry sensor it is in the console where the timer is. Most of the time it looks like a computer board on the opposite side of console than timer. There is also sensor strips inside the drom that relay the info to the auto dry sensor board.
If you need further assistance Please feel free to comment me back.
Jul 27, 2011 | Dryers
I have a whirlpool dryer and it is no longer drying. it blows cool air and tumbles.
Check the gas connections are tight. Also check the gas shut off is turned on.
Aug 16, 2010 | Whirlpool LER4634J Electric Dryer
It will not automatically turn off when running, the knob does not turn while running.
Miss Stephanie you must replace the timer.
If you have a timed dry setting. Run timed dry. If it does not shut off timer is bad.
If it does shut off you have a sensor problem.
Apr 14, 2009 | Kenmore Dryers
Whirlpool gas dryer #LGR4634JQ1 not drying or shutting off
OR GAS VALVE SWITCH
STEVE'S APPLIANCE
516-300-3249
Mar 04, 2009 | Whirlpool LER5636P Electric Dryer
I run the gas dryer,i smell gas...turn off dryer,no smell.....
mostly that after burn,,check vent and vent exhaust reall good,,exhaust coming back in home..
Dec 08, 2008 | Whirlpool LER5636P Electric Dryer
My dryer never shut off for 7 hours now it runs but dsnt heat up
Your timer has gone bad. if you get me the model # i can get you a part number and you can order the part from sears. (this is a very common issue)
Nov 19, 2008 | Dryers
Whirlpool LER5636P Electric Dryer Logo
541 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
