Question about Microsoft Windows Vista Ultimate Edition
Windows vista can not support full screen mode for cmd .how it can be solved.
    Genius:
  • 1,605 Answers
Right click on the cmd icon. got o layout and resize the screen.
Posted on Mar 04, 2009
How to Run Turbo Pascal Full Screen mode on Windows 7
Now that's a program I've not worked with in a while ;-) I haven't used it since my early high school days in the 1990s. Turbo is a really old application that has been around for ages- unfortunately, being as such, it is only capable of developing 16-bit DOS applications, which has, for better or worse, gone the way of the dinosaur. In the x64-bit versions of Windows Vista and 7, all 16-bit native support has actually gone out the window in favor of 32-bit and 64-bit application development. This is why DosBox was invented- it is a true 16-bit DOS environment (much like command.com and CMD.exe used to be) that is capable of running all the older DOS programs that are no longer compatible with Windows.
When you run Turbo from the DOSbox program, press ALT-ENTER and it will fullscreen whatever you're working with.
Hope this helps,
- Vern
Mar 24, 2012 | Computers & Internet
C language is not running in full screen mode
Windows Vista takes away a lot of support and convenience for the sheer attractive of flashy user interface. One major feature is the ability of open full screen window for command prompt shell in Windows Vista. When you attempt open or run DOS .com applications, .bat batch scripts or games that relies on command prompt, and including cmd.exe itself, you will encounter the following error message:
This system does not support fullscreen mode. Choose “Close” to terminate the application.
The lack of support for full screen DOS command prompt in Windows Vista is a big annoyance especially for those who still playing games for DOS and Windows 3.1/9x era, use legacy software such as WPDOS or programmers who frequently switch to command prompt to use DOS based programming language such as PASCAL.
There is no simple solution to this no support for full screen window in Windows Vista. In almost all possible workarounds, you are almost guaranteed that your Vista will be broken in some way, at least on the part on Windows Aero. You will lose the nice Aero Glass interface if you attempt any of these trick, plus other unknown side effects.
Workaround to Run or Open Full Screen Window Mode
Workaround 1: Use XDDM driver instead of WDDM driver for video graphics adapter
In another word, install the Windows XP video card driver for use in Vista. If the video graphics card hardware supports Windows XP driver, you can download the Windows XP driver for your video hardware and install it under Vista. However, be warned that using XP driver on display adapter may crash your Vista system randomly, so save your works before proceeding and use with care.
Note: This solution has been recommended by Microsoft in KB926657.
To install a Windows XP video driver under Vista, just follow the procedure listed in the guide below. The steps should work for both NVIDIA and ATI video graphics accelerator card.
Download the Windows XP driver installer for your graphics card from NVIDIA or ATI. Run the installation setup program just downloaded. Confirm any User Account Control permission warning when prompted. The installer will first extract and unpack the files required by installation to proceed to a folder/directory. Note down the path to the folder. For ATI, the folder for these installation files usually located in a directory with a name that resembles C:\ATI\SUPPORT\7-5_xp_dd_46743\Driver or C:\ATI\SUPPORT\7-5_xp_dd_ccc_wdm_46743\Driver, with the only different been the number to indicate the version and build number of the driver
Jul 31, 2009 | Computers & Internet
Windows vist full screen mode is not coming
HI
Because C++ & CMD work on only 1024*768
Harry
Apr 09, 2009 | Microsoft Windows Vista Ultimate Edition
Full screen TC
Hi Yes , You can run C++ in full mode. Plz follow the below step.
Hold Alt Key and hit Enter key it will move in full mode.
If you want permanent full mode option then right click and select proprties. In display select full screen and that it.
Feb 04, 2009 | Microsoft Windows Vista Ultimate Edition
Computer problem
that is your DOS prompt
Try typing at the black cursor (chkdsk /r <ENTER> <Y> <ENTER> REstart the PC)
If that does not work
Shut down PC
F8 on boot get back to Advanced boot option
SAFE MODE WITH NETWORKING
Sign in as ADMIN or Owner
say yes to get to Desktop
Once you get to the Desktop
(Windows XP)
Start>RUN>CMD (This will be the command prompt window}
(chkdsk /r <ENTER> <Y> <ENTER> Restart the PC)
(Vista)
Start>Start Search>cmd>(above) Right click on CMD>Left click(RUN ADMIN) (This will be the command prompt window)(chkdsk /r <ENTER> <Y> <ENTER> REstart the PC)
Jan 23, 2009 | Intel D845GVSR Motherboard
Turbo c/c++ not working in full screen mode
The problem the dos is not compatible with windows xp.Right the launcher file and select properties->screen->select window(i.e deselect full screen) now the program will launch hopefully,it worked for me. now go to full screen by pressing alt+enter.
Aug 20, 2008 | Dell Inspiron 1501 Notebook
Not working
Do a file search for cmd.exe and then you can create a shortcut on your desktop pointing to it and then in double quotes put the location of the application you are trying to execute, ie.. It should be located on c:\windows\system32 - cmd.exe
C:\WINDOWS\system32\cmd.exe - in Properties Target and put this in double quotes and then your application with the full path in double quotes after that.
Jul 26, 2008 | Microsoft Windows Vista Ultimate Edition
go to compiler set it into ur drive where it belong ur C++/ turbo
May 16, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
