Question about Sony VAIO PCV-RS720G (027242658103) PC Desktop
Intermittent wi-fi My Sony Vaio NR21z has built in wifi - shows connection to Lan and internet but slow or non-existent web page access - time outs repeatedly. On ethernet, or a separate wifi dongle (not the built in) connection works fine. How do I find/replace the wifi card? Thanks
  • 38 Answers
Most laptops you can just flip them over and open an access panel. Usually just 2 or 3 screws are all that stand in your way. Some laptops like 1000 Model HP's require you to remove the entire plastic panel on the bottom. You will recognize the wireless card inside by two distinct cables that attach to two corners of it. It is usually 1.5 x 1.5 inches big and will have one cable hooked to main and one to auxillary. These cards are available for purchase online if you google internal wireless cards notebook. There may be other types out there but i run into this one almost every time!
Posted on Mar 05, 2009
Is it possible to connect a standard DSL modem - without Wi-Fi (with 1 Ethernet port) and a DSL modem - Wi-Fi (with 4 Ethernet port) to broadcast Wi-Fi singles
Does the non wifi modem give out DHCP addresses?
Can the wifi modem be set up to receive it's IP address from DHCP?
If the answer to both these questions is Yes then that's what to do as a first step. Make sure the wifi modem DHCP service is disabled as it must NOT give out DHCP addresses.
Connect the ethernet port of the non wifi modem to one of the LAN ports of the wifi modem and NOT the DSL/WAN port. The wifi modem is not participating in any DSL connectivity at all so it's DSL light will remain off. The non wifi modem is doing the DSL duty so it's DSL light should be correctly illuminated.
May 01, 2015 | Computers & Internet
How do I turn on an acer aspire wireless switch?
Sony's Sony Vaio laptop features built-in wireless LAN adapter that allows the computer to connect to any wireless access point. If you want to adjust the device's WiFi settings, you must use the proprietary software and hardware that comes preinstalled on the laptop and the Internet connection options that come with Windows. Once you have all of the correct settings enabled, you can have your laptop connected to a wireless access point without any additional applications.
Enabling Wi-Fi with Wireless LAN Switch b> Before you can connect to a wireless network or change any of your Wi-Fi settings, you must first enable the computer's Wi-Fi feature with the wireless LAN switch. This switch is located directly below the laptop's screen and is labeled "Wireless." Once you have located the switch, slide it into the "ON" position. b> Enable Wi-Fi in Vaio Smart Network b> Once Wi-Fi has been enabled with the wireless LAN switch, you must enable Wi-Fi using the laptop's proprietary wireless connection software, "Vaio Smart Network." To access this program, click the "Start" button in the computer's task bar and select the "All Programs" option. Select the "VAIO Smart Network" option to launch the program. Alternatively, you can click the VAIO Smart Network icon in the computer's task bar to launch the program. This icon is in the shape of a green button with two white arrows on it. Once in the application, click the switch to the right of the "Wi-Fi" heading to toggle it to the "ON" position. Windows Connect to a Network b> With Wi-Fi enabled, you must connect to the wireless network using the "Connect to a Network" feature that is a part of the Windows operating system. Click the network icon in the computer's task bar to bring up a list of the available wireless networks. This icon is in the shape of a computer and an Ethernet cable if you not connected to a network. If you are connected to a network, it is in the shape of signal bars. Select the desired wireless network from the menu that appears and select the "Connect" option. Enter the networks password if necessary and connect to the network. b> Network and Sharing Center b> If the wireless network that you want to connect to does not appear in the "Connect to a Network" window, you must connect to the network manually. Click the network icon in the computer's task bar and select the "Open Network and Sharing Center" option. Click the "Manage wireless networks" option, followed by the "Add" option. Click the "Manually create a network profile" option and type the network's information in the spaces provided. Place a checkmark next to the "Start this connection automatically" option and click the "Next" button to connect to the network.
b>
Feb 08, 2013 | Sony VAIO VGN-AR150G Notebook
No matter if secure or not will not connecet to wifi
Hope this helps
Nov 19, 2012 | Sony VAIO VGN-N325E Notebook
Will not connect to wifi network
Hope this helps
Nov 11, 2012 | Sony VAIO VGN-N325E Notebook
I have the ASUS T101 how do I get internet access without WIFI. Is there an internet card I can get?
Most desktop computers do not have Wi-Fi capabilities. If you wish to connect it to Wi-fi, you can use a USB Wi-fi LAN Card, which can be connected to any USB port of the PC and can be used to recieve wi-fi signals/ data. Note that PCI Wi-fi LAN Cards are also available, which are internal and added to PCI Port of the PC.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | ASUS Computers & Internet
Is it possible to get a wireless connection to the vaio PCV-RX221
Vaio PCV-RX221 does not have Wi-Fi capabilities. If you wish to connect it to Wi-fi, you can use a USB Wi-fi LAN Card, which can be connected to any USB port of the PC and can be used to recieve wi-fi signals/ data. Note that PCI Wi-fi LAN Cards are also available, which are internal and added to PCI Port of the PC.
CreativeTECH
Sep 09, 2011 | Sony VAIO PCV-RZ221 PC Desktop
My sony vaio e series can't connect to the
Hi
You need to make some tests first,
Try to get LAN cable form other PC at home, and plug it in the sony vaio
You need to enable wireless ( Through wi fi switch, of Fn + F2 )
Please tell us your results
Good Luck
May 13, 2011 | Sony Computers & Internet
Please instruct on how to access McDonalds wifi. A booklet was not included with my netbook 7 inch and I am lost. Please detail
From McDonalds:
You need a Wi-Fi (802.11b/g) enabled device.
Most newer laptops have built-in Wi-Fi capabilities. Older versions may require a separate Wi-Fi card, which you can purchase at most larger electronics retailers. Any chip or card that has been certified for compliance with the Wi-Fi wireless LAN standard (IEE 802.11b) can be used. More and more PDAs and even cell phones are now Wi-Fi enabled. A manufacturer or service provider can help you identify these devices.
Connecting is simple:
When in the McDonald's restaurant, just turn on your computer (or PDA), select "Wayport_Access" from the available wireless networks and open the Internet browser. You will be pointed to the McDonald's splash page where you can select the CONNECT button.
I hope this helps - please rate my reply.
Dec 22, 2010 | Sylvania G-Netbook
Cant connect wii to internet
The unit can connect to the Internet by utilizing its 802.11b/g Wi-Fi, which is built in, for wireless connections or via a USB-to-Ethernet adaptor for DSL connections.
For your wireless connection or Wi-Fi, the 802.11b Wi-Fi has a data rate of 11 Mbits per second and has an indoor range of 30m or approximately 98 ft. The 802.11g has the same indoor range, however the data rate is at 54 Mbits per second. If you have an existing wireless connection or are in a Wi-Fi hotspot, the unit will connect to your wireless connection automatically out of the box. If you do not have a wireless network, however, you will need to have your wireless network subscription done or set-up first. Once you have wireless Internet access, you then search for your access point, put in your security settings and you’re good to go. It would also be advisable to have a wireless router for this so that you won’t have to shuttle the connection between your PC and your Wii. wi-fi-usb-connector.thumbnail.jpgAnother option would be to connect your Wii via the Nintendo Wi-Fi USB Connector. This accessory allows Nintendo Wii users who do not have an existing Wi-Fi connection or a compatible Wi-Fi network to create one through their broadband or DSL connected computer. This is inserted into your existing computer’s USB port and the Wi-Fi USB Connector acts as a wireless access point for the Wii. This allows the user access to the internet and to play Wi-Fi Connection games from Nintendo Online.
nintendo-wii-lan-adapter.thumbnail.jpgFor your DSL connection, however, you will need to have quite a few things. You can use a WII LAN adapter to connect your Wii to your DSL modem. You can also use a router so that you can use your PC and your Wii at the same time. With the LAN Adapter though, to use or plug in the Wii, you must disconnect your PC. This can be quite tedious since you will have to plug in and out your PC and your Wii every time you need to use one or the other. A LAN Adapter is fairly cheap, but if you get a router, your PC and your Wii can go online at the same time, saving you the hassle of connecting one or the other when you need them. You can then hook up the existing ethernet cords to the back of the router and connect it to the Wii via a USB 2.0 cord.
i hope this helps
Nov 05, 2009 | Nintendo Wii Console
Sony laptop won't reconnect to wireless router
First check your wi fi switch is on in laptop.
Second also check that your wi fi network padapter found your router netwrok in my netrwork places.
Then when u cliko n connect what happen let me know please.
Jun 14, 2009 | Sony VAIO NR Series Notebook VGNNR460EP
Sony VAIO PCV-RS720G (027242658103) PC Desktop Logo
232 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
