Want run The front power light comes on and it stop there.
    Problem Solver:
  • 5 Answers
Ok, take your computer apart!! take all the cords that are connected to it off so you dont shock yourself.. take the side to the case apart.. lay the case on its side so you can see into it.. you should see your (RAM) random access memory or aka memory sticks, depending on the computer there should be anywhere from 2 to 4 slots. the memory itself is green it is like a loing stick, what you need to do is take these out, BUT BE VERY CAREFUL VERY CAREFUL!! when you get the memory out take a cloth with some rubbing alcohol on it and GENTLY rub the brown connectors on the bottom of the memory, let them dry them put them back in, put everything back to gether plug it up and you should be good to g. IF THIS DID NO SOLVE YOUR PROBLEM LET ME KNOW
Posted on Mar 06, 2009
If the break lights in my 1986 c corvette works but the tail lights do not, what could be the cause
Blown fuse ,bad headlight switch,or wiring issue.
the tail lights have there own fuse and are powered through headlight switch. Do the front running lights come on? If none of them work, switch could be bad if front work and rears dont, check bulbs and power to them when lights are on
Mar 17, 2015 | Cars & Trucks
We have no running tail lights we have blinkers, hazards and brake lights on our 1993 dodge Dakota, we are told its a ground wire, we need to run ground wire and need a picture with instructions please we...
blinkers and stop lights are on the same circuit-tail lamps are on another circuit-i'm going to start from zero so please be patient-do the front park lamps come on with the headlamps-have you checked the fuses-have you checked at the rear lamps with a volt meter-take the rear bulb out and try in front if fronts working-as far as the ground at the rear there should be a screw in the frame where the ground should be and there should be a ground wire coming out of the harness in the area where the harness from the front plugs into the turn signal harnesses-otherwise-you can driill a small hole in the frame and one in the truck bed underneath and run a wire between them-the bed is not grounded by being bolted onto the truck-cheers Denny
Nov 02, 2013 | 1993 Dodge Dakota
What causes runing lights to go out all together?
Has to be in wire going to rear of car my guess if the front ones still work run new wire splice into front ones (back woods hick solution hehe
Jan 31, 2013 | 1997 Mitsubishi Galant
Will a aspire 5610 work with battery out?
yeah, it will work but no light on at off condition
Jan 10, 2013 | Acer Aspire One PC Notebook
Why does my washer stop in cycle
Raise and lower your lid six times to reset timers.
Sep 30, 2017 | Speed Queen CTSA0AWN Front Load Washer
1993 UK spec XV535. Tail light and front running/parking light stopped working after sitting in garage for awhile. Rode it about 5 miles and it sat for another 2 months. Went to work on it and tail...
I would start simply.Check or replace all your bulbs first.Then take apart your bulb sockets front and back and spray with electrical contact cleaner and a little lubricant.Make sure all the sockets have free travel and are not corroded at the grounding points on the frame.Some lights ground through the frame mounting and some have a separate ground wire.It sounds like you may just have a bad connection. Most brake lights wont work with key off as there is no power to the circuit.Also clean your brake light switches in the handlebar and down on the frame for the back brake.
Aug 17, 2011 | Yamaha XV 535 Virago DX Motorcycles
are you sure you're not looking at the running lights? the running lights on the rear and the daytime running lights on the front are suppose to come on when the car is in gear and go out when the car is in park.
Aug 16, 2011 | 2008 Ford Focus SE Sedan
Makes a whining noise from front of truck while driving
power for the fog light relay and switch comes from the headlight switch. you could rewire that power to come from accessory power - Which would not let you leave them on, or from battery power. They will not trigger the lights on chime, so accessory power would be a better choice.
May 30, 2009 | 1998 Ford Explorer
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
