Question about Samsung Refrigerators
Freezer and frige got power but dial wont work
Rs 21 dcns samsung american stylefridgefreezer please help !
had a power cut and now the dial wont work althopugh the lights are on no cooling happing how do i reset this /?
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
CHECK OUT THIS GUY ON YOU TUBE
some great help-tips on samsung
samsung fridge freezer diy help
Posted on Oct 02, 2010
  • 400 Answers
It sounds like possibly your thermostat (dial) is broken. You could probably find a compatible thermostat at RECO or TECSA or any refrigeration spares shop. Makes sure you have unplugged the fridge, then remove the covers over the dial, either take a snapshot with a camera of the wiring side of things so that you can refit them correctly. Take the thermostat with you and the shop can confirm that they can supply the same type or a compatible. Be sure to let them check that the connections on the compatible (even if they look like they are in the same position) have the same function as the original.
Hope this works for you. Cheers Shane.
Posted on Mar 04, 2009
How do i remove doors rs 65dunh
take the top hinge off an lift door off the bottom one .
Mar 01, 2015 | Samsung RSH7ZNRS Stainless Steel 513L...
My Fridge side is not getting that cold and the Freezer works fine, not sure what to do..
there is a tempature dial in the frige side turn it to a higher number then wait and see if it gets colder
Feb 13, 2015 | Samsung RS263TD Side by Side Refrigerator
Samsung rs21 dcns freezer fualt
Two things to check: 1.) Check to see if condenser coil is clean, it may be packed with dirt. This is the coil located under the refrigerator. 2.) The defrost heater may have burned out causing the breaker to trip. This heater is located on the evaporator coil located inside the refrigerator.
May 21, 2014 | Refrigerators
Samsung Model SR 21 NME. The freezer is on the top, this freezers fine, but the fridge isnt even cool. We have taken the back off the freeze to do a complete defrost. The fan works fine. But the ttemp dial...
Inside the fridge compartment, at the back, is a panel that can be removed, remove the screws careful with the bulb, its plugged in behind the panel.
the panel has a vent that allows cold air flow from the freezer, this will often freeze completely shut with ice. let it thaw out, then check to see that the vent opens, or closes when you turn the dial, the best thing is to open it as wide as possible, I even used toothpicks to open the valve even more, its just a thin flap, surrounded by Styrofoam.
afterwards if your fridge is too cold, adjust the real thermostat located in the freezer.
Jan 06, 2011 | Samsung Refrigerators
Refrigerator not cooling
Could of been a back feed from the power ,and it could of shocked your frige.
Nov 24, 2017 | GE Monogram ZISS420DRSS Stainless Steel
Model TBX18KMB. Liquids on top shelf often freeze. Also,need to cut electric bills,can Power Saver help?
Turn the refrigerator temp control down try factory setting, usually c on frige and 3 on freezer control. The cold air circulating from the freezer enters at the top of the frige therefor it is usually colder.
Nov 04, 2009 | GE Refrigerators
Change the waterfilter
Hi, I looked up your model and it shows a filter. It appears to be inside a small box. I have never seen one like this. Is there any kind of box inside the refrigerator or underneath?
Let me know if this helps.
Vic
May 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
Malfunctioning American Fridge Freezer
Is it freezing. Sometimes those led's go out.
Dec 21, 2007 | Freezers
Refrigerators Logo
104 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
