Question about Nortel Meridian M7208 Corded Phone
Programming Nortel M7310 to Auto Answer
Just purchased Head set for our phone and need to program it to Auto Answer so the head set can answer phone without pressing line button.
2 Suggested Answers
  • 201 Answers
SOURCE: Nortel M7310
Your M7310 phone does not have caller ID. The phone system can have caller ID and there are a few different options you could have for phone system and caller ID packages. You should try to find out which Nortel phone system you have and possibly what type of Caller ID unit.
I suspect you cannot do what you are looking for because as I mentioned, the phone itself does not have caller ID and only displays what the phone system tells it to. It is more complicated for a caller ID system to store a list of previous calls when you have multiple lines and multiple phones. Would you want to see a list of every call that has come in, just the calls that rang at your station or just the calls that rang and you answered at your station.... BUT... this may be ansered in a user guide specific to your phone system or your caller ID interface.
Posted on Oct 26, 2007
ynotphone
  • 192 Answers
SOURCE: Need Caller ID displayed on Nortel StarTalk Flash/M7310
A question: -> does your phone ring? -> what software are you running on the system? If you know this will help a little in giving you more information. There is a Feature that you can dial if your phone rings... when there is a call coming in, dial FEATURE 8 1 1 You can even make this a button rather than dialing this feature code everytime: -> Feature * 3 -> press the button that you want to program -> dial Feature 8 1 1
Posted on Jul 16, 2009
I need to program the lines to ring on my phone. How do I do this?
This is tech programming and not admin, you can take a course on how to program and navigate a business Nortel Norstar phone system. It is the system that runs the phones.
If you are aware of how to program then it is under config/sets/lineaccess/Lineassignement. You will need to know you line #'s in programming i.e. line 5 is not 5 and depending what what system software depending what line it is in programming.
Dec 17, 2012 | NorStar M7310 Corded Phone
How do you turn the ringer back on a T7316E Nortel phone? We have several phones that do not ring, we need the feature code to hear the ringing
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to temporarily turn them off use do not disturb (feature 85, feature #85 to turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310, ...regards John
Mar 14, 2011 | NorStar T7316E Corded Phone
Does auto answer feature is available on Norstar phones? if yes, how?. Thanks!
Yes in system programming, handsfree answer back must be enabled. There are several different phone system models that the M7310 phone works on. I need the model number of the phone system to give accurate programming directions.
Dec 07, 2010 | NorStar M7310 Corded Phone
Our company has purchased a Nortel Norstar Meridian M7310 phone system, that has been previously used. We didn't know, but it did not come with voicemail, so it is tough to get calls when I am not here....
Programming2.gif is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key til it says appear and ring
press next key (lower right arrow)
The display should say line 002: appear only
press the Chng key till it says appear & ring
Continue til all of your active lines say appear and ring
press the heading key(top left arrow) till the display asks for another extension number
repeat line programming for that extension
press the release key when finished
Aug 30, 2010 | NorStar Meridian M7310 Phone
How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
The display should say speed dial#:--
enter in the speed dial number you wish to program.
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Apr 16, 2010 | Nortel T7316E 2-Line Corded Phone
Call display won't work as the phone system M7310 keeps picing up on the first ring. I have changed the Auto Attendant and the CCR # of rings but that doesn't help
It may be that you have the forward no answer parameter set to 1 ring on ANY of the phones you have programmed to ring on those lines. Make a call to your system from your cell and see what answers....the auto attendant (you can dial another ext) or a voice mail box. If your system is equipped, we offer remote programming services.
www.dyna-tech.us Hope this helps . Bill
Mar 22, 2010 | NorStar M7310 Phone
Nortel Norstar M7310 - How do I identify the admin set if all are the same?
As luck has it, they *all* will go into admin programming. Try FEATURE **ADMIN and IIRC ADMIN as the password. If by some odd chance they are attached to a BCM, then there's another layer of passwords.
Carl
Oct 27, 2009 | NorStar M7310 Corded Phone
Program a new Nortel m7310 phone with an existing extension
If the extension was a swap of the old M7310 with a new(ish) M7310 no additional programming should be necessary. However if the phone was replaced with another type of nortel set(M7208, M7324,T7313 etc.) then the phone will default to its base features. To re-program the feature keys press feature *3, the button you wish to program, and the feature code for that button
Sep 28, 2009 | NorStar M7310 Corded Phone
M7324 nortel phone line 1 can't answer on handsfree, how do I fix this?
Programming2.gif is done on 7310, 7324 and 7316 type sets.Enter programming2.gif by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change to handsfree.
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say foward no answer.
press the next key 3 times (bottom right arrow)..
The display should say handsfree. Press the show key.(top right arrow) change from none to auto
Sep 16, 2009 | NorStar M7324 Telephone
I have a Norstar Meridian with M7310 phones. When calling out using the speakerphone, the microphone doesn't work. When trying to switch to hands-free during a call, it puts the line on hold.
sounds like your telephones not programmed for handsfree.
Sep 14, 2009 | NorStar Meridian M7310 Phone
Nortel Meridian M7208 Corded Phone Logo
649 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
David Burbee
David Burbee
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
