Question about Whirlpool DU930PWS Built-in Dishwasher
I need the manual for a whirlpool dishwasher model number DU930PWSQ0. May have something obstructing the water tube - need to know how to dissassemble parts.
  • 35 Answers
The parts catalog for it is at
http://www.manuals-in-pdf.com/index.php?main_page=product_info&products_id=1162311
but it will cost you $7.99
Posted on Dec 16, 2011
Http://shared.whirlpoolcorp.com/product_literature/search.jsp
Posted on Mar 05, 2009
Where is the drain located on the dishwasher model DU930PWSQO
The drain is in the bottom of the unit, right in the middle. You can find helpful information for your Whirlpool dishwasher here, including pictures, videos, maintenance, repair tips, troubleshooting guides and parts! My DU930PWSQ0 Model Overview from PartSelect com Good luck!
Feb 20, 2015 | Whirlpool Dishwashers
Whirlpool du930pwsq0 won't stop draining
check that the float is not stuck.. it should be down when not in use and should move up and down smoothly.
Mar 02, 2014 | Whirlpool DU930PWS Built-in Dishwasher
Bosch shu43c02uc
test this steps and fix it. God bless you
Belt, Water Pump
Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Drain Pump
If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller
The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit
If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve
The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly
If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer
If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose
If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve
If the dishwasher won't drain the check valve might be stuck closed. The check valve is a device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is located in or at the outlet of the pump that the drain hose attaches to. Sometimes the check valve is accessed from the inside of the unit depending on the model.
Check Ball
If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Jul 22, 2013 | Dishwashers
I need a heating element (i think) for my whirlpool quiet partner 1 dish washer, but i need the model number and I dont have it with me, do you know the part number for the heating element that I need or...
Your Whirlpool Quiet Partner 1 should have its model number inside along the left side. Mine is DU1010XTXT1. Your heater part is original Manufacture # W10518394. Can be purchased for about $38.00 at
http://www.partselect.com/PS8260087-Whirlpool-W10518394-Heating-Element.htm?SourceCode=3&SearchTerm=w10518394
or order an after market heater element part # AP5690151 for about $33.00 at
http://www.appliancepartspros.com/whirlpool-heater-w10518394-ap5690151.html
Hope this helps!
Apr 04, 2011 | Whirlpool Dishwashers
Whirlpool DU1301XTV dishwasher - the top rack started cleaning woefully a few months ago. The bottom seems OK. I checked wash arm action by starting the washer and opening the door several times. The...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Nov 04, 2010 | Whirlpool DU1301XTV Builtin Dishwasher
Dishwash
sometimes those dispensers become defective,, make sure nothin is obstructing it from opening possibly dishes or rack attachments,, if not then u will need to order a new dispenseer assembly if this is a whirlpool built kemore,,,( kenmore just puts there name on aplliances, they dont build them) just to let u know if u didnt know already...
deteremine your model number go to sears online check out there parts and service page and research parts by puttin in your model number and determine the part number for your model ,,,, i believe they vary from 20 to 60 dollars ,, this is somethin you could do just have to get part and seperate the panles by removing the screws all around the inside door.. hope this helps
Jan 31, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Does not pump water. Leaves dishes soappy
We really need your model number to help you properly. In the mean time you can check you sink connection and air gap for obstructions. Usually the cover just pulls up and off then you unscrew the cap to expose the drain tube for the dishwasher. More often than not if the unit fills and washes but leave soap on the dishes a clogged drain line is the problem. You may have to run something down the drain tube to clear it. Usually you will see the obstruction when you remove the cap. There is a remote possibility if it drains into a garbage disposal that food particles have clogged the drain outlet inside the garbage disposal. Hope this resolves your problems. Cheers!
Sep 20, 2009 | GE 15" Laundry Pedestal for Horizontal...
Whirlpool dishwasher model DU912PFGBO drains very slowly and not anywhere near complete
You may have something obstructing the flow of water through the drain hose. You need a tech to check where the problem is.
http://tclaundryrepair.com/
Feb 19, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GE Dishwasher
Have you gone to the GE website yet?
You can drill down to "appliances" .. "dishwashers"... then "Parts&Accessories" (on the left side of the web page).Look for the section titled "Repair or Replacement Parts". Enter your model number. You can see drawings of your machine. I suggest looking at the tubing leading to the water valve. There are a couple of screws below the door which you need to loosen to get access to this and everything else. They do have your model on the site. I have repaired several of my own GE dishwashers over the years. Most use the same core components. Let me know how you make out. If you need more help, I'll be glad to help.
Oct 16, 2007 | GE GSD3200J Dishwasher
Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
Apr 14, 2007 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool DU930PWS Built-in Dishwasher Logo
467 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
