Question about Navman iCN 520 GPS Receiver
Battery replacement navman icn530
Hi
i have icn530
i bought a replacement battey due to the poor life of the original however i cannot seem to remove the rear panel to access the battery
I have removed the two small screws on the bottom but the rear panel is firmly attached . is there a way to remove this without damage?
Many thanks
Dave does not turn on
describe how to open the back cover for battery replacement or other repair
Remove the 2 small screws and use a tiny flat screwdriver and insert it by where the screws came out and twist. It is clipped down with a series of plastic flanges which can be popped with a twist in between the front and rear case. You need to work your way around the case doing the side with the earphone jack last as the cover needs to slide slightly sideways to slip off. Don't be afraid to use gentle pressure as they will pop apart and wont break
Posted on Apr 17, 2009
2 Suggested Answers
SOURCE: battery replacement navman icn530
Besides the two screws the back lit is "clicked" to the front lit. I used a small screwdriver and carefully pushed it in between the front and back lit and after some careful manouvering it clicked open at several positions. My battery was glued to the electronic print! Again using the small screwdriver and watching carefully not to turn on the power I was able to remove it. This procedure is certainly not an advocate of Navman! But in my case it worked ....
Posted on Oct 25, 2008
My e71 went dead suddenly.. black BLANK screen - no sign of life!
hi, my e63 used to do the same thing. i found that if you take off the battery cover and remove the battey then replace it, it should work after 5mins. but sometimes the phone just over heats and switches off.
sorry theres not much help i can offer
from lewis
portsmouth, UK
Mar 21, 2011 | Nokia E71 Smartphone
Require a manual were can i get one from
Here is the manual for yo u.
http://www.navman.com/docs/manuals/navman-icn530-manual-en.pdf
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Oct 18, 2010 | Navman iCN 530 GPS Receiver
NAVMAN
when you discover where let us all know
Apr 17, 2010 | Navman iCN 530 GPS Receiver
My navman icn530 seems to be frozen on 1st screen when turned on.
Try this solution : http://www.fixya.com/support/t906770-no_map_displayed All you need is to find the appropriate rom image
Jan 23, 2009 | Navman iCN 530 GPS Receiver
Navman Satnav icn530
Did you tried to recover keys with SmartST ? The option is on the software menu
Sep 03, 2008 | Navman iCN 530 GPS Receiver
Aug 18, 2008 | Navman iCN 520 GPS Receiver
Update icn530
yes you can get the updates from there web site here http://navman.com/Navman/Templates/standardcontent____4407.aspx
riz.
Nov 20, 2007 | Navman iCN 530 GPS Receiver
Navman f20
this is because of high voltage in input AC power so u have to replace it
Nov 06, 2007 | Navman F20 GPS Receiver
Navman iCN 520 GPS Receiver Logo
740 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
