Question about Microsoft Windows 98 for PC
Error is occured.
I use window xp and at time of using system i some time have an error which is "your data can't save on c: due to harware failer" and after that a blue screen comes out please tell me can i do?
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there.
    Can you please try and describe what the blue screen says.
Clean your memory by pencil eraser and check your hard disk bad sector.. just go to safe mode and in run tym cmd then chkdsk /f enter and restart the system
Posted on Jan 26, 2012
    Sergeant:
  • 183 Answers
Blue sreen problem occurs either faulure of Hardware or software and solution is right the message which is displayed on blue screen so you need to look at message once and follow the procedure according to blue screen.
if you are not aware of it then please post back the message which appears on blue screen.
and vote all answeres.
Posted on Mar 04, 2009
What does error CE-36329-3 indicate on a frozen PS4?
per Sony's site :
Here are a few ways to deal with the error message:
Option 1 (Update system software and application data): Close the application, install the latest system software and game update, and restart the system.
Option 2 (PS Camera Compatibility): If a PS Camera is connected to the system, remove it and reboot the system, then go to [Settings] > [User] > [Login Settings] and turn "Enable Face Recognition" OFF.
Step 3 (Save Data Issues): If the error occurs again, back up your saved data, and then go to [Settings] > [Initialization] and choose [Initialize PS4]. If it continues after initialization, check to see if you have save data in online storage. If you suspect incorrect save data in online storage, remove the affected save from system and online storage.
Things to remember:
  1. Check to see if this error occurs with multiple titles. If not, you may be dealing with a game or app specific crash that may be helped by re-patching/re-downloading.
  2. If you suspect issues due to your local network, try using a wired connection and/or checking your network settings results http://manuals.playstation.net/document/en/ps4/settings/nw_test.html
  3. Periodically back up saves to USB and/or online storage if you have Save Data concerns.
Oct 11, 2015 | Video Game Consoles & Games
Tip
How to fix No Bootable Media Error Message
FAT (File Allocation Table) is one of the most widely used file systems used now-a-days with various versions of Windows operating systems and memory cards. Every logical partition contains a FAT that consists of file allocation information and the information of free allocation units that need to be assigned to files. Although the FAT file system is reliable, corruption still occurs due to various reasons. In such situations of FAT corruption, your system becomes unbootable, resulting into inaccessibility of data saved in FAT based hard drive. To access the data after FAT file system damage, an easy way is to restore the data from an updated backup. But, with inaccessibility of data backup or backup falling short to restore the required data, an ideal option left is to use an advanced FAT Data Recoveryapplication that can recover the lost data.
To illustrate the above scenario, consider a practical case the below error message pops up when you attempt to boot your system:
“No Bootable Media”
As the above error message appears at the time of booting the system, you wont be able to access the data saved in the hard drive.
Cause:
The above error message because the FAT file system has been corrupted. Few main causes for file system damage are improper system shutdown, human errors, and virus attack.
Resolution:
To isolate the above error message and to access the data after the above error message appears, you will need to follow the below steps:
Run CHKDSK utility to repair the FAT file system. If the problem persists, format the hard drive.
While the latter resolution resolves the above error message completely, it also deletes the data saved on your hard drive. In such cases, if the backup is not available, then you can only recover your formatted data by using an advanced third-party FAT Data Recovery software.
A FAT Partition Recovery utility thoroughly scans a FAT based hard drive and recovers almost all data, even after formatting. The data recovery utility can be downloaded from the Internet.
Stellar Phoenix Windows Data Recovery is an efficient FAT Partition Recovery tool that recover lost, deleted, and formatted data from both FAT (FAT12, FAT16, FAT32, VFAT) and NTFS (NTFS, and NTFS5 ) based hard drives. The detailed help manual attached with the tool allows even a new user to perform recovery easily without any technical knowledge. It supports Windows 7, Vista, XP, 2003, and 2000.
on Jun 30, 2010 | Computers & Internet
Sharpdesk issues
I had this same issue. The problem was because the client was using an older version of Sharp Desk on Windows 7 machines. After uninstalling SD, I installed SD 3.3. No more issues.
Jan 23, 2012 | Sharp Office Equipment & Supplies
Error code 0x00000002
STOP 0x2 DEVICE_QUEUE_NOT_BUSY error code has a value that is 0x00000002. This is a fatal error typically known as STOP message or Blue Screen of Death (BSOD).
This error generally occurs in Windows XP but may also occur in latest version of Windows such as Windows Vista or windows 7. The computer may stop responding without warning. Moreover, your computer may give error messages like STOP 0x00000002 error or related errors and if blue screen appeared then you may have to restart the system in the mean time of your work due to which unsaved work will be lost.
Cause of Error:
  • You may be using corrupted profile in your system which raised this problem
  • The device driver of your system is not updated
  • Malfunction of hardware usually is the cause of error such as STOP 0x2 DEVICE_QUEUE_NOT_BUSY or similar error
  • Registry database of your system may have corrupted or modified erroneously by invalid application
  • You have installed new hardware unsystematic or installed unknown application
  • Spyware has infected the PC
  • Antivirus software is not working
  • The operating system or application might have run out of usable memory.
This is one of the serious problem in computer if it is not resolved instantly then it might create some more unexpected error. STOP 0x00000002 error and its related error will disturb you all the time and you may have to bear loss of data. When blue screen of death appear on your monitor screen then you need to restart directly whether you have saved your work or not. Therefore, you are suggested to fix STOP 0x00000002 error as earliest possible.
How to Fix:
To fix STOP 0x00000002 error you need to follow the following methods.
  • If this error occurs in your pc then you will have to restart the PC and then press F8 key before appearing Windows. You will see a black screen with white text giving many options. Select the option "Last Known Good Configuration" and press Enter. If you have configured the computer improperly then it may fix the error.
  • If you have installed any hardware in your system then the chances is more that the device driver is not updated and thus errors of type STOP are given at the time of operation. You must download latest drivers.
  • If your system does not become stable then you need to try scanning of registry with this tool. Since, registry keeps all configurations of your system if it gets impaired then you must download registry repairing softwareand repair it .
Mostly, spyware has been the reason of various errors in computer system. Spyware damages files in the computer system and if once damaged then it is no longer used and it also corrupt registry database. The file which is infected by virus may be a program file, system file etc. If STOP 0x00000002 error occur in spite of antivirus then download anti spyware to scan your computer.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 28, 2011 | Microsoft Computers & Internet
Blue screen in xp & system shuts down
Friend,
It is an indication that Windows is about to crash. You must do the following immediately:
1. Back up all your data if possible to a different drive. Or at least out of C:\Windows folder where MY Computer resides.
2. Go to www.ccleaner.com. And download CCleaner, the registry cleaner. What happens is that all programs registry themselves with Windows Registry. When yo uninstall the some do remove their traces from the registry, most do not. And the registry keeps bloating. This not only slows down the PC but also can cause a crash when a lot of junk is there. So use this CCleaner and remove all the junk from the registry. And you may not have to reinstall Windows. And if you have to then you have to and are prepared for it by having taken a backup of your data.
Dec 19, 2009 | Microsoft Windows XP Professional
Error: 0xC004D401 an unauthorized change was made to windows The security processor reported a system file mismatch error.
I suspect a program or driver for a hardware device was just installed prior to this error. Best thing to do is to use Windows Restore and use a restore point dated before the first occurance of the error. You may need to repeat this process choosing previous restore points until system is back to normal or you have run out of restore points.
Here's how:
Startup computer and go into safe mode (Press F5 key as computer is starting up but before you see the Windows logo screen).
Open your Windows Vista Start menu, select All Programs, select System Tools, and then choose System Restore.
Use the System Restore Wizard to choose a restore point/date that was created before the error started occurring on your Windows Vista computer.
Revert your system configuration to this same restore point.
If error still occurs and you had other restore points, you can repeat process with older restore points.
If you have gone back several points and still cannot, you may have not choice but to do a full Windows restore. This can result in a loss of data.
If you get to this point, re-post here for instructs on how to possibly save data before doing a full restore.
Bret
1-2-1ComputerServices
Oct 07, 2009 | Microsoft Windows Vista Home Premium with...
XP Installation and win32k.sys
hi,
this problem is occured due to corrupt or scratched disk.
u need to install XP with new bootable disk.
Sep 18, 2009 | Microsoft Windows XP Professional for PC
Data execution prevention ERROR
I doubt that this has nothing to do with counterfeiting and you will get a little box in the bottom right hand side of the screen saying so.
The problem should be fixed by running a System Restore and take the machine back to a date before the problems occurred.
Be sure to backup your documents and music. Don't wanna lose those.
Good luck.
Jul 09, 2009 | Microsoft Windows XP Professional
Vista Transformation Pack 8.0.1 screen shot
i think your vista dvd loading error occurred some time that problem occur because when your vista dvd is making that time some file has missed that's why this problem occur
Aug 27, 2008 | Microsoft Windows Vista Ultimate Edition
MS Outlook Contacts error solution
completely uninstall and download ccleaner from downloads.com. run it which removes any previous office system related files. then reinstall office
Jun 06, 2008 | Microsoft Office Outlook 2003 for PC
Microsoft Windows 98 for PC Logo
64 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
