Question about Avaya 5610 IP Phone
Avaya assighning New static IP address after IP address conflict
After having a Ip adress conflict problem in teh office i assighned the phone a new IP adress now after it displays discover and the phone has rebooted it ask's to enter command is the phone now asking you to config from scratch? we try pressing the enter button but any buttons we do press the handset bleeps at us and they are none responsive pelase help?
  • Anonymous Mar 20, 2014
    Phone not working through DHCP but working through static IP address
    Problem Solver:
  • 10 Answers
If you need to reconfigure the phone press "mute"RESET# where the alphabets correspond to the digits button they appear against on phone. E.g. for R press 7... and so on ..... then the phone will ask reset values? press # to reset and reboot the phone. Then key in the correct IP address for phone .... call server IP address ... router .. files server .... VLAN ID etc ....
If all the settings are done correctly ... and if the phone gets the reach ability to the call server it will work fine...
if you are unsure of these settings.... go to the menu and network options of any working phone and get the correct values from there
Posted on Apr 02, 2009
The phone is looking for the calsrv ip address, which it cant see. So it is trying to "Dsicover" it.
Go to another phone and press "mute"ADDR#
You can then see the ip address information and input it into the phone that is incorrect.
Posted on Mar 05, 2009
    New Friend:
Enter procpswd
Posted on Mar 25, 2013
  • kingman_fars
    kingman_fars Mar 25, 2013
    enter procpswd for avaya 1616-1
Avaya 9620-ip phone DHCP conflict
Give it a static address OUTSIDE the DHCP scope.
Aug 21, 2012 | Avaya 9620 IP Phone
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
4621 ip phone sitting in discover after resetting and clearing what is causing this problem?
"Discover" is the phones way of saying that it can not see the phone system at the IP address you gave the phone. If the phone is on teh same subnet as the IP Office, check that the IP set in the phone for "CallSrv" is for the IP Office.
If the phone is on a different sub-net, make sure that there is an IP route in the IP Office to allow traffic to come from the sub-net where the phone is set up....
Jun 18, 2012 | Avaya 4621SW
Avaya 1616 IP phone doesn't take the router IP when assigned statically. There is no DHCP. It shows Bad router after the phone gets a restart.
bad router means that you assigned an IP in the router section, that can not be found on teh network.
You dont have a DHCP server on the network?
Sep 13, 2011 | Avaya 1616 IP Phone
5610 sw phone displaying Adddress Conflict * to program
Reboot the phone to grab a new DHCP address. If it still does that, then something else has that IP, and the phone has a static as well, so teh phones IP will need to change.
Jul 15, 2011 | Avaya 5610 IP Phone
I've powered my 9620 off/on, moved the phone to a different desk. I keep getting DHCP Conflict and the phone keeps rebooting. I am not able to CRAFT... does not work on this phone at this point.
Someone configured a static IP on your network. The DHCP server thinks that IP is free and keeps handing it out to you. You can either trace the equipment (workstation or phone) that has that IP or you can go into the CRAFT menu and assign a static to the equipment (please check with your network or system administrator to see what IP you can assign to your phone. Also talk to your network admin if you are using VLANs)
To get into the craft menu and change the ip address settings
1. during the startup of the phone press the * key when you see "* to Program" during initialization
2. enter 27238#
3. navigate to the ADDR menu
4. change the ip address, call server ip, subnet, router to the correct ip addresses
5. if needed change the http, https, or file server address
6. restart phone
Mar 08, 2011 | Avaya 9620 IP Phone
Display screen reads dhcp bad conflict
There is a dhcp error. Reboot the phone.
When It says, DHCP * to program, press the STAR button.
when the IP address is displayed, change it by press 0.0.0.0. Where the dots are would be the star button. then press the #(pound) button until you see save new values, press star for yes.
Hopefully that will force it to grab another IP from teh DHCP server.
If not contact your admin.
Jan 12, 2011 | Avaya 5610 IP Phone
Describe your avaya 5610sw ip enter commandproblem hello. I cannot logon to my telephone for some reason. I have restarted the phone many times. The screen says "phone =***.***.x.xx" next line says...
Enter the IP information. if you leave the IP at all zeros, it will grab DHCP (if available).
Press the pound (#) sign to continue.
Callserv IP is the IP of teh phone system.
press pound to continue.
Jul 03, 2010 | Avaya 5610 IP Phone
IP phone to IP phone through an IP trunk Issue
Is this an IP office? If so, maybe try to untick the "direct media path" box in the extension tab.
Jul 07, 2008 | Avaya 4610SW IP Phone
Avaya 5610 IP Phone Logo
2,998 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
