Question about HP PSC 1215 All-In-One InkJet Printer
HP psc 1215 all in one error message
I replaced my Hp ink cartridges with a compat version of new catridges which are cheaper they did work great . However the next set also compat are now not being reckonised and my 'all in one printer ' is flashing a error message ' check print cartridges' and will not print .
Ive tried switching on and off , re..strarting .. removing cartridges then re.adding but without success . Can anybody help as these cartridges are full and compat ?
  • daz1br Mar 04, 2009
    A very detailed and good response , unfourtunately after trying suggestions my printer still displays' ink cartridge error ' the printer does connect with computer when print is selected but nothing happens due to this error , thanks anyway Josh for trying to help i appreciate it
  • 530 Answers
Hi im josh in cebu phils.may i help you? Friend try to use thse solutions surely it will help you:
The first item to check is whether your printer is connected correctly to your computer. Check the connecting cable to make sure that the connections are tight. You also should unplug each end of the cable to ensure that none of the connecting wires are bent, making a bad connection. You might also want to change the printer cable. Cables can get old, and the wires inside can break; try a new cable and see whether this change fixes the problem.
caution
HP  psc 1215 all in one   error message - caution_icon.gif Anytime you change any connection between your system unit and any external device (such as your printer), you probably need to turn your computer off and then back on again for the connection change to register with your system. So if you're plugging in cables, reboot your system when you're done.
Next, you should make sure that the printer is connected to the correct port on the back of your computer. Checking the port connection is not always as simple as it seems. Some computers come with more than one printer port, and your printer might be hooked up to the wrong one. If you have multiple printer ports, try plugging your printer into the other ports.
Next, check the paper feed of your printer. If you're out of paper, your printer can't print. You also should check the paper path inside the printer to make sure that no stray pieces of paper are lodged inside. Make certain, too, that your printer is online, or set in the on position.
You should also check to see if your printer is paused. Check your front panel buttons to make sure that your printer is online. You should also double-click the Printer icon in the Windows system tray to open the Print Manger and make sure the job isn't paused from within Windows.
Another potential cause of this problem is having the "manual feed" option selected in Windows or on your printer. If this option is selected and there is no paper in the manual feed tray, your printer just sits there waiting for someone (like, oh, you!) to insert some paper. The solution to this is to either add some paper to the manual feed tray or switch off the manual feed option.
It's also possible that you have the wrong driver installed or selected within Windows. Right-click on this printer's icon in the Printers window and select Properties. Check the Details tab to make sure you're printing to the correct port using the correct driver. If you need to change drivers, pick one from the pull-down list, or click the New Driver button to add a new printer driver.
note
note_icon.gif The tabs in the Printer Properties dialog box are specific to the brand and model of printer you have installed. If your Print Properties dialog box doesn't have a Details tab, look for a Ports or Advanced tab instead.
It's possible that the correct driver is installed, but something has gone screwy with how Windows reads the driver information. Go to the Printers Window and delete the current printer, and then use the Add Printer Wizard to reinstall the printer driver. You might also want to check with your printer's manufacturer to see if there is an updated version of your driver available.
In addition, it's possible that a recently installed device has somehow mucked with your printer configuration in Windows. Try deleting your printer driver and then reinstalling it, as described in the previous paragraph. Because the last device installed on your system can overwrite previous configuration information, go ahead and make your printer the last installed device.
If none of these suggestions solves your problem, you're looking at a major computer or printer problem. Try hooking up another printer to your computer; if the new printer works, it's time to take your old printer into the shop. If the new printer doesn't work, you probably have a defective port in your computer. good luck!
Posted on Mar 04, 2009
  • slenders May 07, 2011
    I have got the same problem as "Daz1br"! Is there anybody with a different solution? I think it is possible to solve this by some kind of softwaren...
    Thanks!
Hi. I have replaced the colour cartridge (57) on my 1215 psc but it is failing to print a clear page and the colour is not correct. Thanks
Remove catridge from printer shake well,touch nozzles with tessue paper & see all three cours are visable or not repeat two or three times then chech with printer..
Sep 05, 2011 | HP PSC 1215 All-In-One InkJet Printer
I have an hp psc 1215 all-in-one. My black cartridge won't print. It recognises if I swap it out for a new one, and goes through all the motions. It registers the correct ink levels. The cradle...
The problem is not with the ink-cartridges. You've proved that, by swapping BLACK cartridges.
The problem is that the ink-jets that spray the BLACK ink onto the paper are clogged.
Thus, no BLACK ink reaches the paper.
Open the HP Printing Assistant, and open Utilities, and run a few "print-head-cleaning" cycles, to try to unclog the print-head.
Jul 19, 2011 | HP PSC 1215 All-In-One InkJet Printer
Please i bought ink from one computer shop today and i dont know how to refill the catridges. am using hp psc 1215 printer. pls help me. i cant see any hole on the catridge
you have to drill a very small hole in the top of the cartridge fill it up with ink from a syringe then put tape over the hole
Aug 23, 2010 | Computers & Internet
Compatible cartridge for HP 1513 used in INDIA having 136 & 132
HP printers supplier, can arrange or supply in Hyderabad India,
the hp printer PSC-1513 catridge (color)136 and catridge 132(Black)
or advice us, where could we get said catridges. Thanks
Sep 03, 2009 | HP PSC 1510 All-In-One InkJet Printer
Ink cartridges stuck after replacement
HP PSC 1350.
Very sensitive printer. Due to dust, the catrdges are getting stuck at right side. Please clean the steel roller where the catridges are rested. Clean it with nice cloth and if possible put 3-in-1 oil in that area only for the smooth flow of catridges in that steel stem or roller.
This might happen iif we are not installing the orignal and genuine catridges and there is a chance of ink gettng leaked onto the printer.
Kind advise is if the printer is old, please put an annual maintenace service contract with local authorized hp Printer Dealer which will solve your problem once for all.
have a nice and good working day.
Jul 16, 2009 | HP PSC 1350 All-In-One Thermal Printer
I changed my black ink and now i get the message left cartridge incorrect..how do i fix it?
HP PSC 2210 InkJet Printer. The following has to be done for checking the Blank Ink Catridge working : 01. Remove the existing Black catridge and Color Catridges from the Printer carefully. 02. Clean the location with a soft cloth with cleaning liquid to make the place dust free. 03. Put the correct black and colour cartridges recommended by HP and that too genuine one. 04. Do not use any refilled or reinked local catridges that will spoil the HP PSC 2210 printer. 05. Re-install the catridges both Black and Colour properly. 06. Take a test print out - both black and colour print outs. 07. Check the Printer status and there is no warning of Cartridges wrongly inserted. Have a Good day.
Jul 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
HELP..."ink cartridge not compatible" error message.
I had the same problem and solution was change the cartridge for a new one (My printer is a HP PSC 1315)
May 11, 2009 | Office Equipment & Supplies
Flashing light check print cartridge
You must replace all ink carts with new ones at the same time. Yeah, this how HP makes its money.
Jan 02, 2009 | HP PSC 1315 All-In-One InkJet Printer
Ink cartdge issues w/ Hp C4180 all-in-one brought from US 2 UK.
don't forget U.K. use 220v we using 110v. can't be compatible!
Dec 13, 2008 | HP PSC 1510 All-In-One InkJet Printer
Printing photos on hp psc 1215
Are u using the original HP ink ? The HP ink is formalated to dry fast. You might try using a different ink cartridges, but try a couple sheets of HP photo paper to see what happens.
Apr 21, 2008 | HP PSC 1215 All-In-One InkJet Printer
HP PSC 1215 All-In-One InkJet Printer Logo
777 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
