Question about Fujitsu Siemens ESPRIMO P2500 PC Desktop
I have Integrated sound card but there is no sound or vol. icon control appear on my widows and on device manager their is an yellow exlamination mark
  • naila_alhame Mar 04, 2009
    thank you but i try all of this but still even i have no voulum control botton appear and when i try to play sound file this message appear (Windows Media Player cannot play the file because there is a problem with your sound device. There may not be a sound device installed on your computer, it may be in use by another program, or it may not be functioning properly.
  • 530 Answers
Hi im josh in cebu phils.may i help you? Friend try to use these solutions of mine it will help you for sure Problem: Your New Sound Card Doesn't Work—You Don't Get Any Sound Let's look at the simple stuff first. Is the card installed properly in your system unit? Have you connected the audio cable from your sound card to your CD-ROM/DVD drive? Are speakers (or headphones) hooked up to the card? Are the speakers plugged in and turned on? (And are they plugged into the correct jack? You don't want to plug your speakers into your microphone jack!) Are you performing a task on your PC that actually produces sound? Is the volume turned up loud enough (both on your speakers and in Windows)?
Okay, now that the easy stuff is out of the way, let's turn to something more difficult. The most likely cause of no sound is some sort of conflict. One by one, change your card's DMA, IRQ, and port settings. (This might entail resetting some jumpers on the card itself, as well as making some software-based changes.)
This problem can also occur if you add a new sound card to a system that has sound capabilities built into the motherboard. You'll need to disable the onboard sound before the new sound card can work.
Problem: Your New Sound Card Crashes Your System If you've just installed your sound card, you might not have the card properly installed. Check your installation (is the card properly seated and connected?) and then reboot your system.
If this doesn't fix it, you have something wrong in your setup. Check your software setup to make sure you have the same DMA, IRQ, and port assignments as selected on your sound card itself (usually via DIP switches or jumpers). If the settings are correct, you probably have a conflict of some kind. You should methodically change the DMA, IRQ, and port assignments in Windows so that they don't conflict with the assignments for other devices on your system. thats all friend good luck hope i helped you.
Posted on Mar 04, 2009
Audio windows 7
click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
hope it helps
Jul 20, 2012 | ASUS P5PE-VM Motherboard
MY PORTEGE NO SOUND AFTER INSTAL WIN 7
hope this helps you W7
Apr 10, 2012 | Toshiba Computers & Internet
NOT ACTIVE AUDIO WINDOWS XP.....WHAT THIS IS SOLUTION ASUS P5KPL-AM SE
Click Start, click Control Panel, double-click System, click the Hardware tab, and then click Device Manager. 18abb370-ac1e-4b6b-b663-e028a75bf05b.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation. Double-click Sound, video and game controllers to expand that category. If a sound card is listed, you have one installed. If no sound card is listed, check the information that came with your computer to see if there's supposed to be a sound card installed. If there should be a sound card installed, you'll need to install one.If you think you have a sound card installed, but you don't see it under the Sound, video and game controllers category, expand the Other devices category and check any devices listed there.Laptops don't usually have sound cards. Instead, they have integrated sound processors, which appear in the same category in Device Manager.
If there's a yellow question mark next to the name of the sound card in Device Manager, there might be a problem.
  1. Right-click the name of the sound card, and then click Properties.
  2. Click the General tab, and then look in the Device status box to identify problems with the sound card.
  3. Although most speakers have a volume control, you can control the overall level of sound using Windows.
    1. Open Volume Control by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then, under Audio Devices and Sound, clicking Adjust system volume.
    2. Under Main Volume, move the slider up or down to raise or lower the volume.
Aug 04, 2011 | ASUS P5KPL-AM SE Motherboard
No sound
I don't know what operating system you're running or what type of motherboard, but I'll do my best to help. Assuming you've checked your speaker connections and they are ok, the next thing you'll need to do is go into the device manager to check the status of the audio/game controllers (that would be your sound card or, if integrated audio, the chipset used). Click on start-control panel - system - hardware- device manager, then scroll down to audio, game controllers, click on the plus sign in front of sound, video, game controllers and see if there are any yellow triangles with an exclamation point (!). If you see anything like that, it means the audio drivers were never installed, and you'll have to either reinstall the drivers from the disk that came with the motherboard or sound card, or you'll have to download from the manufacturer's website. Next, check in the lower right hand corner of your screen (called the system tray). If there is a speaker icon, click on it and check and see if mute is selected. If you don't see any speaker icon, again, download or install the drivers.
Jan 24, 2011 | Computers & Internet
No sound on hp ze5600 no device found in manager also mute button on side doesnt work
Installation of Sound Card. Go to the control panel Click on the System Icon Click on the Hardware Tab Click on the Device Manager then Select the Multimedia Controller or Audio Control the yellow Question Marks sign on it. Right click on Multimedia Controller and uninstall it. After this go to the top of the device manager and click on scan for hardware changes. Driver installation Wizard start. if the problem is still exist. Replace the sound card or have a local tech take a look at the sound card.
You Can download HP Sound Card Driver from this site. HP Sound Card Driver
Mar 13, 2010 | Computers & Internet
No sound fitted new hardrive cant find driver
1st of all you check the sound card driver is install in the system.and also know Manufacturer name .
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Click on the Sound, Video and Game Controller then
  • See the Audio Driver is in the list.if it is not available then
  • You see the Yellow Colour Question mark in the list Unknown devices or Multimedia Controller.
  • You delete this yellow colour Question marks and click on the top of device manager icon "Scan for Hardware changes".
  • After this Windows appears hardware wizard, you just give the right path where your Audio driver located.
  • Then you click on next and your driver will install.
you can download sound drivers from this site.
Sound Card Drivers
Mar 10, 2010 | Computers & Internet
Soundmax integrated digital audio
1st Download Driver from this site SoundMAX Sound Driver
  • Select the Multimedia Controller or Audio Control the yellow Question Marks sign on it.
  • Right click on Multimedia Controller and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Mar 19, 2009 | Computers & Internet
Sound
Try to check if there is a volume icon on the notification area or go to control panel and check the sound icon there, if not right click my computer and click on manage or go to device manager and check if the driver for your laptop is installed, all dell laptops has built in sound cards, if the driver is not install go to support.dell.com and download the driver of your sound card.
Thank you!!
Nov 02, 2008 | Dell Inspiron 1501 Notebook
No sound on my desktop
Hi.
It appears you need to install the drivers for your sound device.
To know if you have a sound device installed:
Go to Start - Control Panel - DobleClick System icon - Hardware - Device Manager, look under Sound, video and game controllers
Is there a yellow icon ? Yes ?
you need a software called driver to activate that device.
Hope this help.
Jul 11, 2008 | Computers & Internet
Toshiba Speaker problems
1) try the function key and the icon on keyboard for sound up.
2) is the vol control by the time and day. double click it and turn it up
3) Be certain the sound card driver is installed
right click on my computer/properties/ device manager
any yellow questions or bangs or exclamations
Jan 30, 2008 | Toshiba Satellite M105-S3004 Notebook
Fujitsu Siemens ESPRIMO P2500  PC Desktop Logo
399 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
