Question about Cooper Wiring Devices 1301-7B GROUNDING SINGLE POLE TOGGLE SWITCH
Wiring diagrams schematic (boilers)
Can any1 help an put any wiring diagrams for honeywell or othe type of boiler. C plan, C plan plus, S plan, M plan, Y plan
    Problem Solver:
  • 13 Answers
Honey well produce a wireing guide for central heating ring there technical department
Posted on Jan 17, 2010
Call me alan 0776 7494009 have books on c, s,y plans
Posted on Aug 03, 2009
I have a mclain 68 boiler... I have no power going from boiler to thermostat. what can that be?
Could be a disconnected wire or failure of the thermostat power supply.
Oct 23, 2016 | Heating & Cooling
Need wiring diagram to include: Underfloor heating downstairs (wet system,polyplumb) combi boiler for the heating and hot water
could you provide the exact model number or the product you need the wiring diagram for
Thanks
Proton
Oct 30, 2008 | Honeywell Heating & Cooling
Hi, I have a baxi solo boiler WM60/4RS and a Landis & Gyr RWB252 timer but my Honeywell T6160 thermostat has nether been connected, can anybody shed light on the wiring connections please.
The color code for thermostat wiring is as follows.
The "R" terminal is power into the stat from the boiler control transformer. Normally 24 volts. The "Y" terminal is for cooling. Normally left blank for a boiler. The "W" terminal is for heat. This one used to start the heating cycle.The "G" terminal is for fan operation. Probably not used for a boiler. Check the boiler terminal board for these functions and write down the wire color on each one. Match the boiler colors to the right function on the stat. If you need more than this, let me know.
Jan 06, 2014 | Honeywell Programmable Thermostat Heater
Replacing an ST699 with a ST9400C following repl wiring diagram, but programmer does not come on. Is the diagram incorrect? Wiring colours do not follow any of the plans. Syst has room stat, cyl stat,...
Disregard wire colors. Instead wire by terminal designation. In other words :
Wire on "R" Terminal on old thermostat to "R" Terminal on new thermostat no matter the color.
Jun 14, 2011 | Honeywell Heating & Cooling
How do I wire an S-Plan system with a Honeywell programmer to the Valiant ecoTEC plus 428 boiler.
hope this will help http://www.tlc-direct.co.uk/Technical/DataSheets/Horstmann/Pics.pdf
Jan 23, 2011 | Heating & Cooling
Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Jan 16, 2009 | Honeywell Programmable Thermostat Heater
Thermocoupling on a Honeywell Economy Plus EP50B Boiler
the thermocouple most likely plugs into the gas valve, the box with the gas control on it.
Jan 10, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Cooper Wiring Devices 1301-7B GROUNDING SINGLE POLE TOGGLE SWITCH Logo
2,069 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
