Question about Elson Audio Players & Recorders
I have a ELSON CORAL E water heating boiler. But even when I turn the booster switch on,I dont happen to get a reasonably hot water at all.Ans I do not know if there is any way to increase the temperature ,as there is no facility that I could identify.Please advice.
I've worked on them for a while now and I find the booster is just that, will only 'top up' your hot water's temperature not give you the same as the bottom heater, which is usually on for 7 hours and reaches 85 degrees, they are both the same elements, needs to be on max or 85 degrees, that booster element is normally set lower so you could try adjusting that, but it may mean your bottom heater is not working, that's the one that does the hard work, I have wired up the top heater so it comes on over night while I was waiting for the new element to arrive, but this just doesn't heat as hot as the bottom one, maybe because of the position(half way up the tank) or just the stat settings, be warned though I have had many elements where the thermostat tube it's self has become unsoldered and so you get very hot water seeping out, so if there is any signs of water leaking or 'furring' around where the stat goes, get the element replaced asap ....
Posted on Jun 11, 2013
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Thermostat is not switching on boiler.
There are many ways for a hot water boiler to be controlled. One of them is to have an 'on-board' aqua-stat that cycles the boiler burners to maintain water temp set-point and the space thermostat controls only the circulating pump. There is no way of knowing if yours is set up this way, but try turning the thermostat on and off and see if the circulating pump cycles with it.
Volumns can be written on boiler control but with the limited information provided we can only guess.
Aug 25, 2015 | Heating & Cooling
Why the hot water temperature couldn't reach the set temperature (130 degree) in Amtrol WHS80Z indirect water heater?
I have a couple of thoughts. You may have air in the boiler water circuit at the loop that feeds the tank. You'll have to find the vent in the loop to get it out. Second, the automatic valve that opens for hot water may not be opening fully. Have you felt both the boiler water lines that go in and out of the tank? If the water going in is hot and the line out is very cold you have very little boiler water going through the loop. Make sure the isolation valves on the loop are open. Is your boiler full of water? If the boiler loop lines are hot going in and coming out, the tank is full of rust or debris and no water can get to the fins on the internal tubing to pick up heat. If that's the case there is no repair and its time to get a new tank. Hope this helps good luck.
Nov 04, 2014 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
Utica furnace hot water system problem
Check the heat Antisapator on the thermostat, or replace the thermostat.
Nov 13, 2013 | Heating & Cooling
Potterton Suprima 30 - Hot water is working - no problem. But the heating doesn't. When I switch the heating on at the controller and turn the thermostat up - nothing ! The boiler status light doesn't...
I am going to assume that there is a pump to move the boiler water to the heat registers. If this is the case then look for an on/off switch for the pump motor or maybe the pump has seized up and needs to be replaced.
Oct 02, 2013 | Heating & Cooling
Get a electric water heater or not?
I'd stay with the boiler, electricity to heat water is very expensive. I would not bother with a timed shutoff for the reasons you said. The water will stay hot for some time.
Jun 15, 2010 | Water Heaters
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
Hot water
there are two main faults with combi boilers not giving hot water. one is a faulty flow sensor, the other is the most common which is a blocked heat exchanger caused by debris and scale in the system. this needs to be flushed out or may require a new heat exchanger depending on the age and condition of the boiler some plumbers may suggest a new boiler.
Mar 02, 2009 | Water Heaters
Ariston Microgenus 27mffi combi boiler
im an engineer and recently had exactly the same thing with this ariston boiler, i found out it was the the 'air pressure switch', this is a switch which is part of the ignition, it works in conjuction with the fan. when the boiler fires up the air pressure switch makes, if its faulty it can break the circuit mid flow and cause the burner to shut down therefore giving intermittent hot water and heating, theres a possibility that the aps tubes may be damaged as well so ensure they'e condition is good. hope this helps you
Aug 29, 2008 | Combi Centre DX - Mango
Gas Boiler will supply /fire up to supply Central heating When Room thermastat turned up and switched to Heating and Hot water. When on Hot water Only will not fire up even though thermostat on hot water...
most likly or a shorted wire unhook the wire from the boiler see if it stops then if it's still is on it's in the boiler if off try unhooking it at the t-stat on the heater this should narrow it down for you dan
Jul 19, 2008 | Heating & Cooling
402 people viewed this question
Top Elson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Elson Audio Player and Recorder Expert? Answer questions, earn points and help others
