Question about Compaq (254124-001) Case Cooling Fan
My laptop just overheated in the computer bag after i thought i had turned it off. now when i turn it on...it works and i can see the screen and everything but the colours have gone strange sometimes it flickers with the correct colours etc but mainly lots of lines and flickers blue colours.... sorry i know nothing about computers and i am so so upset, my boyfriend bought this for me as a 21st birthday present. it means so much to me and i have always been so careful with it... please can i fix it ........ thanks :(
  • 1 more comment
  • sbyrne Mar 04, 2009
    no i dont think so...i got it april 2007
  • Nicolas
    Nicolas May 11, 2010
    Well, if you live in sweden---you have 2 years warranty, but i dont think you do that so the warranty is one year.
    You can get it repaired...but it will cost..
    Good luck
    Nic
  • Nicolas
    Is there any warranty left on it?
    Cos i think it will be verry expensive to fix it....sorry
    Nic
  • 21 Answers
I can only think of 2 things. it may have overheated to the point of damaging the RAM or it may have overheated or just moved the screen connection. either way there is no way you can fix this on your own and you will have to take it to a computer lab they will be able to help you alot more. sorry for the limited solution good luck with it.
Posted on Mar 05, 2009
Computer shuts down
Make sure Windows Update is turned on. For Windows 7, Vista, and Windows 8 there are Updates that resolve some hardware glitches such as the one you are experiencing.
Apr 03, 2014 | Dell (6F858) Cooling Fan
Message keeps popping up saying Turn off computer, problem in cooling system
you need to get pressurized air and blow the vents to remove dust particles causing over heat. Or if possible remove keyboard to expose cooling fan and chip and use pressurized air to blow off dust
Nov 25, 2013 | Toshiba Satellite 1715XCDS Cooling Fan...
My Toshiba Satellite becomes very hot when I use Skype and I hear that cooler works very hard and then at last computer just turn off.. and then I need to wait awile to wurn it on again... what to do?
Did you try to clean the FAN of the processor? Try to clean it because the dust is blocking the airpath that`s why you laptop is overheating and shutting down.
Sep 13, 2011 | Toshiba Satellite Laptop Cooler
Emachines T2958 overheating
Go to emachines.com and see if there is a firmware update for your computer BIOS. Some thermostat errors are cause by a BIOS fault that can be corrected with a firmware upgrade.
Aug 18, 2008 | Computers & Internet
Advent laptop overheating
Check the jack on the machine to see if it's loose or broken. Use a small screwdriver, and see if you can move it in any direction. If it is loose or broken, get it fixed imediately. A loose or broken jack can create an electrical arch which can do severe damage to the machine.
Jul 22, 2008 | Computers & Internet
System warning pop-up
Are you sure that nothing is overheating? If your cpu fan is turning too slow it won't disipate the heat. Do you have a program showing cpu temp:? I would take the access off the bottom and make sure the cpu fan is clean. If that is not the problem I believe you can turn the warnings off in the bios settings
Jun 08, 2008 | Toshiba (K000016310) Cooling Fan
Chill mat
i have 1 as well and it broke too. this is http://computers.pricegrabber.com/laptop-accessories/m/1754767/
right?
if its the cord's thats broken, its most likely the switch, more specifically the soldering where the wire connects to the switch is prolly broken. i just sawed my switch open w/ a knife, and took a look. now if a wire is loose in the switch, u can either solder it back on, or (in my case i always have the fan on anyway cuz of my **** dell computer overheating) rip the wire off the switch completely and just connected it w/ aluminum foil.
Mar 24, 2008 | Targus Chill Mat PA248U Laptop Cooler
HP dv1000 cooling fan does not turn on
it is either clogged with dust or not functioning.
Here is the repair manual . You can probably fix it your self.
It is on page 162.
http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
Dec 28, 2007 | Computers & Internet
Fan stopped working, replaced, still not working, laptop overheats
did u check the connections? i mean the connection would be loose
Dec 27, 2007 | PC Toys System Fan Controller Fan...
Crashing Laptop
if its the case of the overheating is becoming worse then
a quick fix is to go and buy one of these cans of air duster
and blast the cooling vents and heat fins
i regularly fix a toshiba lap top of a friends and the dust build up is un-real
after so long it just freezes.4359f1d.jpg the picture is inside the heat sink you can see the dust build up
here after 2 months
hope this helps you out
Nov 10, 2007 | Toshiba Satellite Laptop Cooler
Open Questions:
See all Compaq (254124-001) Case Cooling Fan Questions
Compaq (254124-001) Case Cooling Fan Logo
550 people viewed this question
Top Compaq Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
