Question about Uniden Lands Phones
Uniden DSS7855+1, flashing ''welcome! please wait...'', wont work
Hi experts- we have the Uniden DSS7855+1 5.8 gig cordless base station with two handsets.
After a power failure last night the base station flashes the ''Welcome! please wait'' message and provides no other service or connection.
The handsets consequently do not work also.
I have read other responses to those that this has happened to- power failure followed by welcome message flashing and no service- and no one has an answer apart from Uniden telling them to BUY another base station.
This seems dodgy/shonky to me.
We have had plenty of power failures before, but not this problem.
There are no reset buttons and, apart from disconnecting power and telephone lines, only the various input keys that don't work.
I would hate to think that Uniden would charge for another base station when there could be a reset code that could be typed in on the keypad or something similar.
Grateful for any assistance.
This is not a direct solution to your problem, but a workaround for a similar situation. I have two headsets and two charging stations. One of the headsets was stuck with the message ''Welcome! please wait''. When I put the phone on the charging station it usually sits on nothing would happen, but when I put it on the other station the phone came back to life. The non-working charging station will still charge the phone so it is worth keeping.
Posted on Feb 02, 2010
Hi Andrea, I am having the same problem, did u find any solution to fix?
Posted on Oct 08, 2009
How does one use the intercom
To Page another phone to initiate intercom:-
From the base station - press Find hs/Intercom.
From a handset - Press Intercom/clear.
Then select the station you want to talk with or All to
page all stations at the same time.
To answer a page:-
From the base station - press Find hs /Intercom or Speaker.
From a handset - press Intercom/clear or Talk/Flash.
Hope this helps
Ive also included a link to the D1785 Series User's Guide
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1785om.pdf
Feb 01, 2014 | Uniden D1785-3t Dect 6.0 Cordless Phone...
Will the vtech interact with already an existing Uniden 5.8 ghz power max base unit and handset plus one additional handset and charger to give me four locations or just two more single handsets with...
Hi there, Your new phones will not interact with a base station from another brand of phones. If you want to use one base station, you can buy single phones of the same model and brand and those will interact with the original base station. Your new phones will not connect to the old base station Sorry, Alex
Jun 03, 2011 | Vtech CS62192 Cordless Phone
I have uniden dxa1850 series phone. It was working fine, but now I can't get a dial tone. I tried the basic fix of unplugging and removing but it still does not work
Check that you have power (eg. Led indicator is on) to your Base station.
If you have power to the base station and you still do not have a dial tone, plug in a non-cordless handset to the phone socket and see if you have a dial tone on yor non-cordless handset, then you have a faulty base station.
Hope it helps and good luck! let me know how you go!
Dec 12, 2010 | Uniden Cordless Phone
It will not ring and the base will not register
Hi
Thanks for using FixYa. Please follow these steps to resolve the issue:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to a base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
E4 Error is showing on Uniden 5.8 GHz expandable phone. Power may have been disconnected. An ideas on a solution?
The handset displaying the message may have lost its memory of the base station. Take it over to the base station and reset it as when you first associated the handset with the base.
I hope this helps.
Jan 10, 2010 | Uniden TRU9480 Cordless Phone
I have a Uniden cordless phone EZI996, The lights on the base are blinking on & off bright red.
Hi.
Try the following procedure to reset and re-sync the phone system:
  • Disconnect all units from power.
  • Remove batteries from all handset.
  • Check all phone connections to base.
  • Check the phone connector underneath the base (RJ11 squared plug).
  • Put back battries on handsets.
  • Place handsets on base.
  • Connect base back to power with handset sitting on base.
If that does not fix the problem , then there is an internal fault. In that case call Uniden to arrange repair or replacement.
Uniden support number for your area is prited inside the user documentation.
Regards.
Dec 05, 2009 | Uniden Cordless Phone
Handset Won't Connect to Base Station
Here's is the fix, I just had the same problem.
I have 2 handsets here and just had replaced in 1 of the handsets.
Here's the trick, make sure the correct handset is in the correct base. The way this is done is when one of the handsets are in their bases, they will show either HS1 or HS2 in the upper right hand part of the display.
When they are in the correct base, then go push the Find HS button on the main base and you will hear the page feature paging the other base.
When the 2nd handset starts beeping just push the Find HS button again and other handset should work.
After that it don't matter which handset is in which base.
Let me know if this works for you.
Thanks,
Brian
Nov 12, 2008 | Uniden EXI 7960 Cordless Phone (EXI7960)
Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Apr 14, 2007 | Uniden CLX485 Cordless Phone
Lands Phones Logo
3,109 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
