Question about Epson Stylus RX425 Multifunction All-In-One InkJet Printer
I replaced the paper when this ran out and then all the lights started flashing and an E appeared in the window. Please help!
  • 530 Answers
Hi im josh in cebu phils.may i help you? friend try to use thse things. The first item to check is whether your printer is connected correctly to your computer. Check the connecting cable to make sure that the connections are tight. You also should unplug each end of the cable to ensure that none of the connecting wires are bent, making a bad connection. You might also want to change the printer cable. Cables can get old, and the wires inside can break; try a new cable and see whether this change fixes the problem.
caution
Next, you should make sure that the printer is connected to the correct port on the back of your computer. Checking the port connection is not always as simple as it seems. Some computers come with more than one printer port, and your printer might be hooked up to the wrong one. If you have multiple printer ports, try plugging your printer into the other ports.
Next, check the paper feed of your printer. If you're out of paper, your printer can't print. You also should check the paper path inside the printer to make sure that no stray pieces of paper are lodged inside. Make certain, too, that your printer is online, or set in the on position.
You should also check to see if your printer is paused. Check your front panel buttons to make sure that your printer is online. You should also double-click the Printer icon in the Windows system tray to open the Print Manger and make sure the job isn't paused from within Windows.
Another potential cause of this problem is having the "manual feed" option selected in Windows or on your printer. If this option is selected and there is no paper in the manual feed tray, your printer just sits there waiting for someone (like, oh, you!) to insert some paper. The solution to this is to either add some paper to the manual feed tray or switch off the manual feed option.
It's also possible that you have the wrong driver installed or selected within Windows. Right-click on this printer's icon in the Printers window and select Properties. Check the Details tab to make sure you're printing to the correct port using the correct driver. If you need to change drivers, pick one from the pull-down list, or click the New Driver button to add a new printer driver.
note
It's possible that the correct driver is installed, but something has gone screwy with how Windows reads the driver information. Go to the Printers Window and delete the current printer, and then use the Add Printer Wizard to reinstall the printer driver. You might also want to check with your printer's manufacturer to see if there is an updated version of your driver available.
In addition, it's possible that a recently installed device has somehow mucked with your printer configuration in Windows. Try deleting your printer driver and then reinstalling it, as described in the previous paragraph. Because the last device installed on your system can overwrite previous configuration information, go ahead and make your printer the last installed device.
If none of these suggestions solves your problem, you're looking at a major computer or printer problem. Try hooking up another printer to your computer; if the new printer works, it's time to take your old printer into the shop. If the new printer doesn't work, you probably have a defective port in your printer. good luck hope i helped you.
Posted on Mar 04, 2009
My printer is i-sensys MF4150. It prints one page then stops the error light flashes red and message 'load correct paper cassette : ltr ' appears on the LCD screen.I print 1 page then I...
Dear
Pl. select the paper size ( as mentioned on the paper packet) on computer on click START-PRINTER AND FAXES(new window opened)-(right click on printer icon) PRINTING PREFERENCE(new window opened)-select PAPER -paper option (here the paper size to be selected- APPLY. This may set the paper size default.
Thanks.
Feb 03, 2015 | Office Equipment & Supplies
Flashing yellow warning light?
make sure there is paper in the printer and that it has no paper jams also make sure your printer is set to default.
Oct 11, 2014 | HP Photosmart 3310 All-In-One InkJet...
I have installed new cartridges but paper comes out blank
Hi Khalid,
Make sure your printer is set as the default printer on your PC.If you were printing many pages,try selecting the current or the page with the text only and try to print it.Check paper size settings,orientation,layout and printable area in your software and make sure they're in line with the paper you're using.If problem not solved,then you may need to clean the printhead to unclog the nozzles so that they enhance smooth flow of ink.
  • Connect the printer to the computer and turn it on.
  • On the taskbar of your PC,right click on the printers icon.[If there's no icon,go to your printer properties window and then click on the maintainace tab.Select on the head cleaning option].
  • Select 'start' on the headcleaning pop up window that will appear.
  • The printer will starting making noise and the green light will start to flash.
  • After the cleaning the green light will stop.Select 'print nozzle check pattern' and then click on print.[make sure there is a loaded paper in the tray].
  • Check the printouts.If gaps and lines appear on the paper,click 'clean' and if they're ok,click 'finish'.
Hope this helps.Thanks!
Please rate this answer.
Dec 01, 2011 | Epson Stylus C86 InkJet Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
INK WONT CHARGE ON SX200 RED AND GREEN LIGHT FLASHING TRIED PRESSING START. CHECKED EVERYTHING WORKING ALL THE USUAL
Hi
Please check paper tray if there are paper jammed or check the cartridge compartment if there are paper jammed. If there is access door, please check also for paper jammed.
If no paper jammed, follow this steps.
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator (You should be in this command C:\WINDOWS\SYSTEM32- If not type this command when you in the dos command prompt "CHDIR C:\WINDOWS\SYSTEMS32 and press enter")
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Please let me know it you need more help. Regards
Mar 18, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Unable to refresh paper source
Please open the below link and follow the steps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01892627&cc=us&lc=en&dlc=en&product=1146336
If the issue still persists, please follow the below steps.
STEP 1.
Check the ink levels. Please take out all the cartridges and clean the copper contacts with the help of a lint free cloth and the water.
STEP 2.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 3.
1. Disconnect and then reconnect the power cord.
2. When the lights begin to flash, press and hold On and Copies button.
When only the On light is flashing, release the buttons.
When the On light is steady, the reset is complete.
Apr 11, 2010 | HP Photosmart C3150 Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Epson R200 lights flashing but printer not being picked up
Please ensure that there is no paper jam in the printer or any door open thereby. Replug the printer after 10 min. powering off.
First start PC and then printer. Report us back for further assistance.
Aug 27, 2009 | Epson Stylus Photo R220 InkJet Printer
HP Laser Jet 1320. Orange light next to triangle symbol keeps flashing. This began after a paper jam. I cleared the paper jam but can not get the light to stop and so it wont print. I have shut it off...
The Amber light is designated as the "Ink Error" light. With regards to a Hewlett Packard printer, the Amber light is indicating that one of the Ink Cartridges (Tri-Color/Black) is empty, defective, unrecognizable, or just simply needs to be changed. The procedure is; lift up the front cover, look at the Black Ink Cartridge, and examine the Ink Level Window on the Cartridge, located at the center of the Cartridge. If the square window appears to be a solid Green then that means the cartridge is completely full. If it is Half Green/Half Black then it is indicating that the cartridge is half way full, and if the square window is completely Black, then the cartridge is completely empty. Also, remove and examine the Tri-Color Cartridge. If the Tri-Color Cartridge feels very light or if the Tri Colors on the bottom of the Cartridge appear to be discolored i.e. All Magenta, All Cyan, or All Yellow, then the Cartridge should immediately be changed. After replacing the Black or Tri-Color Cartridge, your printers Green Power Light will flash and allow you to continue your print job
You can also try:
Clean the cartridge and carriage contacts with a cotton swab moistened with water. If you have refilled the cartridges don't assume that they will still work. If cleaning doesn't help you may have a failed cartridge even if it is not refilled.
If you are getting a grinding noise, clean the carriage rod with alcohol and lubricate it with a few drops of Tri-Flow, available in 2 oz. squeeze bottles at cycle shops.
If I have helped please rate my post...I will always do my best to help
Apr 09, 2009 | Office Equipment & Supplies
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
Epson Stylus RX425 Multifunction All-In-One InkJet Printer Logo
61 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
