either call aplumber or prepare to get a little dirty and youl have to undo the piping wher it goes into your saniflow so you can gain acces to the clog and access the problemeither call aplumber or prepare to get a little dirty and youl have to undo the piping wher it goes into your saniflow so you can gain acces to the clog and access the problem
You can't post conmments that contain an email address.
Usually Saniflo requires 8" or 9" from top of p-trap to floor level, not from top of shower base to floor level. If the base is raised 8" then you will have enough room to fit a p-trap without cutting the concrete, if you had cut the floor to fit the p-trap then the base is not raised high enough to maintain the water pressure inside to engage the unit.
There is a product called Wham that works very well for this appplication.You will probably have to go to a plumbing supply outlet to find it. Just follow directions on container after you have the system clean and use monthly. It also helps with odor control. Hope this helps you. Thanks.
We have a maserator in en-suite which serves the toilet & shower, We moved in to house 6 years ago and it was already here. After having guests stay a couple of months ago the maserator hasnt worked properly. When we flush the toilet, the water rises and whilst the cistern is filling with water, there is a humming noise for a couple of minutes, then the water rushes back down and there is a clonk and the water bubbles back up through the shower plug hole.Any suggestions as to what this problem is & how to fix it please?
These usually have a larger drain line than a shower or bath. If you are draining into a smaller drain then there will be a considerable amount of backing up. This is not a good idea. hope this helps. Good luck.
Sounds like a restriction in the outlet pipe, the 2 galls from a flush are OK but the bath or shower is more, especiallly if you have flushed before you shower, try drain unblocking chemicals or flushing the outlet pipe with mains water from a hose
so the wc works but notthe shower, where the shower connects in on the saniplus is a not return valve which could be stuck in the closed position??
Have you checked thatthe shower trap isnt blocked with hair etc.
If the wc works & the unit is pumping away then the motor is working ok, so it could be a flow switch problem or as i said thers no flow through the shower waste pipe-work due to a possible blockage
OK thanks, how do I correct this?
OK thanks for the tip - David!
