My computer does not start up
My computer does not want start up.we tried everything in our knowlegde to the problem.
  • 530 Answers
Hi im josh in cebu phils.may i help you? Friend try to use these solutions i got this in my book.
Dealing with System Startup Problems There's nothing scarier than turning on your computer and finding it doesn't start. What you do next depends on exactly what it is your computer is or is not doing. Let's work through some specific startup problems, and how to proceed in each instance.
Problem: Your Computer Doesn't Start—You Hear No Noises and See No Lights First things first—don't panic!
Now, very calmly, look at the back of your system unit. Is the power cable plugged in to the right connector? Now follow the power cord to the other end. Is it firmly connected to a power outlet? Now check the wall switch. Is it turned on? Now walk to your fuse or circuit-breaker box. Is the fuse good or the circuit breaker set? Now go back to your computer. If it still isn't working, unplug the computer from the power outlet and plug in something that you know works—a lamp or a radio, perhaps. If the appliance doesn't work, you have a bad power outlet. If the appliance does work, you really do have computer problems.
If you're positive that your computer is getting power and that you're turning it on correctly, you probably have a hardware problem. The most likely suspect is the power supply in the system unit. To determine the culprit and fix the problem, however, you'll need to call in professional help at this point. Take your system to a certified repair center and let its technicians get to work.
Problem: Your Computer Doesn't Start, but It Makes the Normal Startup Noises If your system is making noise, at least you know that it's getting power. Because you can rule out a bad power cord, the most common things to look for are poorly connected cables or a nonfunctioning monitor.
Begin by checking your monitor. Is it turned on? Is it plugged into a power outlet? Is the power outlet turned on? Is the monitor connected to the correct port on your system unit? Is the connection solid? Is the connection solid in the back of the monitor? Are the brightness and contrast controls turned up so that you can actually see a picture? If you have a newer monitor, try disconnecting the monitor from the computer (with the monitor turned on); if the monitor is working correctly, you should get a No Signal or Lost Signal message on the screen.
If everything is connected and adjusted properly, you might have a monitor that needs repair. Is the monitor's power light on? If not, your monitor might have power supply problems that need attention from a professional. If your monitor's little green light is on but nothing shows onscreen, the video card in your system unit might be loose or set up incorrectly. Try swapping monitors with another system; if the new monitor works on your system, your monitor is the problem. If you determine that your monitor is working fine, you should check your video card to make sure it's installed, seated, and connected properly. If that doesn't fix your problem, try plugging your video card into a different slot.
It's also possible that your keyboard isn't plugged in properly, or that you have some other internal problem that causes your system to halt during start-up. Check all your connections before you try rebooting. good luck hope i helped you.
Posted on Mar 04, 2009
Davhdx275 home theater sony dvd not working how to clean lens
hello if you have some knowlegde you can do it if not dont even try it
take it to the nearest electronic repair shop
forget about those magic cleaners wich are sold by a few dollars the only screw it up ...................
Aug 23, 2014 | Sony Dav-hdx275 5.1 Channel Home Theater...
I have a 2001 C180 Classic Mercedes Benz, the problem is the right front window wont go down. I have checked the Fuse, Opened and checked the electric controll box, all the lights come on, is it possible...
I have a Mercedes Benz C180 1996 Model, but I cant locate the Computer Box.. Anyone please with knowlegde of where I can see the Computer Box..
Thank You
Apr 16, 2013 | 2001 Mercedes-Benz C-Class
My daughter was playing with my coolpics camera and banged it up now the shutter lense wont close and the camera doesnt work can someone help me
try the following:
1.- TURN ON the camera and Push softly the lens
2. Turn OFF the camera and pull softly the lens
if don``t work. Try disassembly the front cover and look if they are an piece or obstruction.
If the information is helpful write a comments
Say thanks is ivery important to people who share knowlegde
Sep 16, 2011 | Nikon COOLPIX S60 Digital Camera
Upgrade Ubuntu Desktop to Server
You would need to reformat and create a fresh install. You cannot upgrade one from the other, because there are too many changes. I suggest that you backup all of your files and then reformat the computer and install the server version.
Apr 04, 2011 | Canonical Ltd. Ubuntu
My AC has not worked for a couple years now and I have taken it in to my mechanic recently and he is telling me I need a EVP valve replaced and he said he got a price from lexus for about $800.00 but i...
To my knowlegde there is a relay a high and low pressure switch an expansion valve a compressor evaporator and condensor in an a/c system. I have'nt heard of the evp valve. if you talking about the expansion valve it starts out for about $2.00 at the parts store. try another mechanic
Jun 22, 2010 | 1990 Lexus LS 400
Get a message saying ,Cannot connect to windows imap12 CD engine, What should i do
What are you trying to do when you recieve this message. The imapi2 is what allows windows burns cds ect.
This can usually be solved by ensuring all relevant updates from microsoft are installed. Have a look at their knowlegde base article 932716
also it is worth searching for the files cdrom.sys, imapi2.dll and imap12fs.dll and ensuring there are SP2
Oct 23, 2009 | Dell Computers & Internet
1997 nissan maxima
That was happening to my 97 GLE as well. I wound up having to replace the alternator. Good thing I did my mechanic said it could have gone up in flames if I'd waited. I'd ask a knowlegdable mechanic or dealer first, it was $200+.
Jul 04, 2008 | 1997 Nissan Maxima
My laptop cannot locate my network
I can not open my labtop on my wireless, it ask me for my password, I give it and it tells me it is the wrong one. I have 2 computers on it with know problems..
Feb 25, 2008 | SMC Barricade g SMC2804WBRP-G Wireless...
Not pickin up signal
Upgrading the firmware (which forced a software reset) solved a similar problem I had with an SMC router. Have you tried logging into your router via an ethernet cable and doing a software reset? If you try this, be sure you have all the information you need to set up your wireless network again because the reset will wipe out all this information.
Nov 12, 2007 | Belkin (F5D7230-4) Router (587009)
P4vmm2 doesnt boot,Y?
Hi yansky, When you turn the computer on do you see or hear any of the following: -Does the power LED turn on and if so for how long? -When you turn you power on listen closely for any sounds like hard drives or fans starting up. -Does anything show on your monitor, if yes what exactly? -When turned on do you hear any beeping sounds from the computer? If you do listen for the pattern of long and short beeps and let us know what they are. If you see absolutely nothing you should try testing the socket the computer is plugged into. Fuses blow, power strips die cords develop shorts so unplug the computer and plug in a lamp to verify you?re getting power. If that doesn?t turn up anything let us know the answers to the questions above plus any other observations and we?ll try to help.
Jan 13, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
313 people viewed this question
David Payne
David Payne
