Question about IBM 4230 Model 1S2 Matrix Printer
Printer shows the following message:- "022 - Unit address not recieved Check printer address"
    Scholar:
  • 111 Answers
Your error message is telling me that you are running twinax. You might want to check your address selection,cable or t-connectot.
If any parts are needed or if you have any questions please call.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alisp IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Posted on Jul 07, 2009
We need to get the printer to recognize the network server name or IP address. At present it says "Unable to connect to (DC-260-795622). The server name or IP address may be invalid.
Ensure that all your network settings on the printer are correct, especially the DNS settings. Are you able to ping the printer from a workstation? Maybe you have a bad cable connecting the printer.
Jan 21, 2015 | Xerox Office Equipment & Supplies
Printer TX550W has message "A printer error has occurred. Turn off and then on. See your documentation".
Hi, this error message usually caused by jammed papers or foreign objects inside your printer. To resolve this issue, please try the following steps.
1. Turn off the printer.2. Open the scanner unit.3. Check for any jammed papers or foreign objects then remove it.4. Check the ink cartridges and lids if push down fully.5. Close the scanner unit.6. Turn on the printer.
If the same error reappears, try the following.
1. Turn off the printer.2. Open the scanner unit.3. Remove all the ink cartridges.4. Turn on the printer >> your printer will display install ink cartridges.5. Install all the ink cartridges, make sure it clicks into place and also the lids should be push down fully.5. Close the scanner unit.6. Press the Start or OK button to charge the cartridges.
If the issue persists, your unit will require service. Please contact Epson so they can check if your printer is still under warranty or ask them for the nearest service center in your area.
Nov 23, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Error; Oxc18a0106
Solution 1:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
Solution 2:
ACTION Allow Unit to Warm Up AND Reset IDS Hardware Failure by downloading update patch
from the link given below.
http://h10025.www1.hp.com
NOTE: Clicking the links may give an error indicating it is invalid. If this occurs, copy the portion of the address on the remaining line(s) and paste it at the end of the address showing in your browser until the complete address is displayed in the Address box.
After opening the above webpage, click on "download only" and save the file to your desktop
NOTE: try only ONCE to recover the unit
Perform the below steps from the front panel of the All-in-one.
1. Get the unit into the Support Menu by following the steps below according with the product,Perform the steps from the front panel of the All-in-one.
A. - Press and hold the left arrow key.
B. - Press the Setup key and release both keys.
Display should say Enter Special Key Combo
C. - Press and release the OK button
Display should say Support and display the FW rev (something like R0616R)
2. Press and release the right arrow button until the display says System Configuration Menu.
3. Press and release the OK button.
4. Display should say Hardware failure status. If not there already, Arrow Key over to Hardware failure status,
5. Press and release the OK button.
6. Display should say Hardware failure status: Clear. Press OK to clear.
7. Press and release the OK Button. Message changes to Hardware failure status Cleared. Press Cancel to continue.
8. Press and release the CANCEL button as many times as necessary, so that, either the Welcome to Photosmart Express screen appears, or, the Ink System Failure screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message USE POWER BUTTON TO SHUTDOWN THE PRINTER followed by PRESS OK TO CONTINUE. Press OK. The Printer will start the ONE TIME INK INITIALIZATION PROCESS. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
13. If the error is still there, or reoccurs the unit need to be serviced.
Aug 21, 2011 | HP Photosmart 3310 Printer
Where blackberry t mobile service centers in india-mumbai located??
You have the blackberry service center in mumbai in following address with phone numbers provided:
1) Unit No 2, Sona Villa, 113, S V Road, Khar West, Mumbai-400052.
Phone 91-022-31920452,91-022-31920051
2) F-11, Eternity Mall, Teen Haath Naka, Thane-West,Mumbai-400601.
Phone 91-022-40242604
3) 13/14, Sharda Bhavan, Station Road, Kandivali (west), Mumbai-40067.
Phone 91-022-42763636
Hope this helps.
Shane
Feb 01, 2011 | RIM BlackBerry Bold 9700 Smartphone
My HP Photosmart C6380 is connected wirelessly, but won't print
Hi
The problem that you're facing can happen due to many reasons; you have not told whether it shows you any messages or not...
So please click on the following link to check if any of the links given below helps or not.
Wireless & Network Issues
If not then please let me know if these links don't relate to your issue, then please mail me with the answers to the following questions: - Do you get any error message when you print? - Which operating system are you using? - Print a configuration page, follow these instructions to print it: 1. Press the setup button (Wrench button) on the printer. 2. Go to Network option and press 'Ok' 3. Go to 'Print Configuration page' and press 'Ok' - Once you print it, provide the answer to the following from that page: * Active connection type * Status * Ip Address (Note: You would find this informations under General Information or IPv4)
Email Address: upvansh@yahoo.com
Hope all would work for you All the best!!
Regards
Dec 26, 2010 | HP Photosmart C6380 All-In-One InkJet...
Network printer shows offline on computers but no error message on printer itself
Hi;
Usually when a printer show offline it is either because windows does not recongnize the driver, or the printer is not set to be the default printer, I suggest you try reinstalling the driver first, and check printer settings to make sure the check is there for default printer. IF all else fails try going to control panel and printers icon and click, then click add printer choose the option add a network wireless or bluetooth printer. It should list your printer if not then click The printer i want was'nt listed, then click add printer by TCP/IP address or hostname, At this point you will need the IP address for the printer on the network you are trying to use. Enter the address then click enter, the system should find the printer on the network.
Jun 01, 2010 | HP LaserJet 4250n Printer
My printer says offline and files are in the queue
This issue occurs due to the change in IP address of the unit (Most of the IP addresses are Dynamic and it may change time to time. So the computer is unable to locate the previously set IP address and this leads to a message printer offline). I request you to set a static IP address for your printer and verify the result.
:) Dr Tony
May 25, 2010 | HP Photosmart C4580 All-in-One InkJet...
OKI colour printer 5600 shows fatal error 003
hi friend,
003
ISI Exception
When the program has attempted to look up an invalid address
Note the 24-digit addresses (usually 3), then restart the printer. Check reproducibility if possible. Repeat the same operation after restarting the printer and check if the same service call message appears
thank u for using fixya
regards,
sivaranjini
Aug 12, 2009 | Office Equipment & Supplies
Fax not working
Thank you for using FIXYA.
Lexmark International (India) Private Limited
REGISTERED OFFICE
Apeejay Business Centre
12, Haddows Road
Chennai TN 600 006 INDIA
Phone : (9144) 2842 2090
Fax : (9144) 826 2447
Lexmark Technical Service & Support
Help Desk
Phone: 1600 114 488
Lexmark International (India) Pvt Ltd
3rd Floor Centre Point, SV Rd-Juhu Rd Junction
Santacruz (West), MUMBAI - 400 054
Tel - 022-26057744/45/55
Fax-022-26054678
May 22, 2009 | Lexmark X4270 All-In-One InkJet Printer
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
IBM 4230 Model 1S2 Matrix Printer Logo
162 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
