Question about AEG Washing Machines
My frontloader has stopped and has an error code c9 the model number is oko lavamat746000
    Brigadier General:
  • 3,614 Answers
try to unplug the unit for an hour.
please post back again
Posted on Mar 04, 2009
  • micromaster
    micromaster Mar 04, 2009
    MOTOR
    BRUSHES WORN OUT. After replacement, you will need to clear the fault
    indication held in the PROGRAMMER PCB logic: With the Switch in the OFF
    position - Press and hold PRE-WASH and SOAKING buttons in at the same time, then turn the control knob to Short Spin.
    Wait one or two seconds and all the indicators should illuminate. Then
    turn the control knob to OFF. All the indicators should go out. Then
    try and use your machine as normal. This should clear the C9 error
    code. If it does NOT – there may be another fault present
SF-P95JJ GIVE ERROR C9
Not "hitachi washing machine error code c9 what to do"
electronicsfurnitureinfo.com/.../hitachi-washing-machine-error-code-c9-...
Info about hitachi washing machine error code c9 what to do in Electronics ... What do you think about this washer Electrolux ZWT-61M, do you like the design?
Jul 28, 2015 | Washing Machines
I have a AEG oko-lavamat 75520 update. It stopped and the code C9 showes on the display. What does the code mean, and is this something I can fix my selfe?
Hi Mrs Willems from retired Englishman in SW France,
According to my list, AEG Lavamat 8*** Series Onwards C9 stands for 'tacho fault' (monitoring the motor speed) requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 16, 2011 | Washing Machines
My washing machine stops and shows C9...what's wrong??? (it's an aeg oko lavamat caresse) Who can help me?? cheers Jan
AEG Lavamat 'C9' decodes as 'tacho fault' i.e. something wrong with the motor/speed/sensing. Sorry but that looks like an engineer call is required;-0(
If this has clarified the situation and/or assisted you please consider a 4 thumbs up for the rating.
John C
Apr 29, 2011 | Washing Machines
AEG oko Diplomat E Update frontloader. Error message blinks E20. What should I do?
Error code E20 indicates that water cannot be pumped out of the machine. Possible causes:
  1. Sieve filter is blocked. Open the sieve lid, (lower right of machine) and clean.
  2. Drain tube bent or blocked. Check for bends and straighten the tube, open hose band clips and check inside for objects or dirt.
  3. Some small object (coin, children's toy, ...) blocks the drain pump. Pump needs to be dismantled and cleaned.
#1 and #2 you should be able to do yourself. With a little aptitude for repairs, you can do the fix #3 yourself, too. If you don't trust yourself to get all parts back together, let a service technician do the repair for you.
Dec 23, 2010 | AEG L86800 Front Load Washer
Error C9
Hello, to cancel the error C9 try to reset the machine by holding the start Button whilst turning the dial through 360 (from Off-2-Off).
Thanks
Jun 04, 2010 | Washing Machines
What means error code "C9" ? AEG Lavamat 76669
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 28, 2010 | AEG Lavamat 88840 Front Load Washer
My AEG OKO-Lavamat 72600 shows error code C9 what does this mean?
My ariston aqualtic has finnish as language how to change to for ex english
Oct 30, 2009 | AEG Washing Machines
AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
Jul 04, 2009 | AEG Washing Machines
Aeg oko lawamat
c9 means the motor is not turning the drum. check carbon brushes in the motor.
Oct 29, 2008 | AEG Lavamat 88840 Front Load Washer
AEG OKO LAVAMAT 86741 UPDATE. WASHING MACHINE
I have washing machine AEG 62800 model.
When I tried to start a washing the error E60 was displayed on screen.
The following actions were done:
1. Turning knob to right to first position "COTTON LINES 95"
2. Pressing on all 5 functions except START button (Rinse Hold, Rinse+, Time Saver, Pre Wash, Stain).
Red lights will flash .
3. Pressing on Start button and simultaneously starting to turn clockwise till OFF position.
It will reset error and will release machine.
I'm hoping it will help.
Boris.
Feb 25, 2008 | Washing Machines
Washing Machines Logo
20 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
