Question about Sony EverQuest: Legacy of Ykesha for Windows
I need sky remote control codes for my OKISH/okp42f tv
  • 49 Answers
You can find all the available codes for the remote control here.
http://www.hamradio-badarc.co.uk/skycodes.htm
Posted on Mar 13, 2009
NEED SKY CODE FOR AKURA APL3221W-HDID
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed see:New Remote Control Prices . To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state 'Sky rev' (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 1: August 1998
Version 2: December 1999
Version 4: May 2001 (Sky+ introduced)
Version 6: March 2004
Version 8: January 2006 (includes all current Sky+HD remote controls)
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at: Sky please remember to use your back button.
Akura 0042 246, 292, 397, 065, 440
Apr 09, 2011 | Televison & Video
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
We have loads of codes for sky remote control. Do you know which code will enable us to switch the tv off and do the sound control. At present we have to use two controls. TV remote to switch on and...
OK,
This really depends on which brand/model of TV you have and which Sky remote version. The code you need is specific to the brand/model of TV.
The Sky remote version is printed on a sticker inside the battery compartment. The older Sky remotes will have "RC1600/00" on the sticker. Newer versions will also have either "Rev 4", "Rev 6", or "Rev 8" on the sticker.
If you have a new TV and an older Sky remote (i.e. before Rev 8) your remote may not work with your TV and you will need to buy a new Sky remote if you want to operate TV and Sky box with one remote.
Please post back with your Sky remote version number and your TV brand and EXACT model number. I will then be able to provide codes for your remote and programming instructions.
Thanks.
Nov 03, 2010 | Televison & Video
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Need a code so that i can operate my LG tv. model no. 37LG5010 using my sky remote.
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Codes are 0065, or 0405,or 0037
Code are 0065, or 0405, or 0037
Code are 1293, or 1206, or 0206
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Apr 25, 2010 | LG 37LG50 37 in. LCD HDTV
I NEED A CODE FOR SKY REMOTE
Hi.
Here available codes for Sky Remote: sky remote codes
Nov 05, 2009 | Televison & Video
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Oct 17, 2008 | Philips HDD065 MP3 Player
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press tv guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
Feb 13, 2008 | Televison & Video
Sony EverQuest: Legacy of Ykesha for Windows Logo
75 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
