Question about Siemens SpeedStream Modem (4100) (SS4100)
"Can't find a certificate to log on to wireless network"
I have been having problems with my Compaq Pressario V3000 laptop for the last couple of days. Wireless network button won't turn on - I think I have 'fixed' the problem - but now, I can't log onto the network - it is giving me the above error. Can anyone help? I can't ring my ISP, as the modem is from my last ISP & my current provider doesn't support Speed Stream modems. Is anyone able to tell me what I have to do?
  • 41 Answers
If you are getting certificate error message when pulling up a website, check on your date and time set on the computer. Make sure it is correct. If it is and you still are getting the same error, try resetting the internet explorer settings. Do this:
  1. Open Internet Explorer.
  2. Click on Tools->Internet Options.
  3. Go to the Advanded Tab.
  4. In the bottom right hand corner there is a box that says Reset. A dialog box will appear, click on Reset.
  5. Close then restart Internet Explorer.
Posted on Jul 08, 2009
Wireless
I don't know what OS you are using ... below is the process to solve your problem in Win xp.
When you try to logon the wireless network, you may end up getting this error message: "Windows was unable to find a certificate to log you on to the network xxxx".
This particular error is normally related to the authentication on a wireless network, usually because the Windows is looking for 802.1x connection by mistake. We can fix it with the following steps.
Step 1
Click on the Start Menu --> Control panel.
Step 2
Double click on Network Connections in the pop-up window.
Step 3
Right click on wireless network connection, then click on Properties.
Step 4
Now click on the Wireless Networks tab and select the network in the list at the bottom. Click on Properties once you select the wireless network that is having problems.
Step 5
Click on the Authentication tab and now uncheck the Enable IEEE 802.1x authentication for this network box. If the box was checked, then that was why you were getting the "unable to find a certificate to log you on to the network" message because Windows is looking for one, but your wireless router is not setup for certificate security.
Step 6
Click on the Connection taband check the Connect when this network is in range box.
Step 7
Click on the Association tab and uncheck the 'The key is provided for me automatically' box, then choose Network Authentication & Data encryption and type in the Network key according to the wireless settings on your wireless router. Please contact the technician of your wireless router if you have no idea about the information.
Step 8
Click on OK and Click on OK again to save your settings.
As yet, this problem has been successfully fixed, Windows can log you on to the network automatically at once.
Mar 23, 2014 | HP Compaq nc6400 Notebook
Dvd drive is not reading in my computer on compaq pressario v3000 notebook
Try re-seating the DVD drive so it makes proper connection to the motherboard, then go into the BIOA setting to see if the DVD drive is detected. If the DVD drive is not detected in the BIOS then most likely the DVD drive is faulty and needs replacing.
Mar 02, 2013 | HQRP 90W Laptop/Notebook AC...
I cant connect to my home wireless broadband after i format my laptop, how can i down load network driver for COMPAQ PRESARIO V3000 notebook.
You can download the LAN and device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Feb 11, 2013 | HP Compaq for Presario V3000 Motherboard
Wireless Network Adapter -------------------------------------------------------------------------------- I have a Compaq Pressario A900 which was running Windows Vista with wireless networking...
First things first go to start/controlpanel/system/devicemanager and select network adapters if there is a yellow light thing that means no drivers were installed go to compaq and download the for the version of windows you have
second go to control panel and select network connections and where you see the wireless card icon click the right mouse button and enable it
hope it helps dont forget to rate ty
Jan 07, 2011 | Compaq Presario Notebook
Windows unable find certificate log network
Most times your laptop will still connect to your wireless network even if you don't have a valid certifcate.
Apr 05, 2010 | Compaq Computers & Internet
Can this HP Pavilion DV9000 adapter fit Presario V3000 laptop
just see it from http://www.udtek.com/hp-pavilion-dv9000-ac-adapter-90w-185v-49a-p-2970.html.may this is good for you.
Jan 15, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
Network adapter not working
your network adapter driver is not installed. Install it and then have a look . open device manager and in that look for network adapters if u can see there then ur driver is installed successfully..
Aug 26, 2009 | Compaq Network adapter
Hello i do have compaq v3000 but wasnt able to connect in wireless connections. how can i resolve it?
Shut down your laptop and your modem.Turn on the modem first then the laptop.Go to start accessories,communications.Click on create a wireless connection.Follow the directions.Make sure you have your WEP key ready.Does the laptop show the network at all?If it doesn't,It sounds like you will need a new wireless card.
Nov 12, 2008 | Compaq Network adapter
Compaq pressario X1000
yes. when the switch is turned on it activates the built in wireless card in your laptop. you can then connect to a wireless router
Jun 10, 2008 | Compaq Presario X1000 Notebook
Siemens SpeedStream Modem (4100) (SS4100) Logo
367 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
