Question about Magic Chef (CSD2610KRW) Top Freezer Refrigerator
Magic chef side by side heating instead of cooling :-(
Okay so the water inlet valve busted, so I found a place in the US to order a new one, meantime intended to use fridge without ice maker BUT after hours of humming away I find inside of fridge is WARM ... do I just chuck it away? Model is GS2121SDEW
  • 3 Answers
Gee, I hope you didn't throw this one away. The cooling settings between the two sides are out of balance, or something is blocking the airflow between the freezer and the refrigerator. Make sure the ducts that blow air are not blocked, set both sides on a medium setting, and give it some time (12-24 hours) to equilibrate. Also make sure the fans are running and the coils are free of dust. I have to clear the coils of my current refrigerator once a week from accumulated cat toys. Generally the cat alerts me long before the fridge does.
Posted on Jun 26, 2009
IC MAKER WORKS BUT NO WATER OUT OF WATER DISPENSER?
There are two sides to the Dual Water Control Valve. The ice maker side is still working but the water dispenser side is possibly defective. Sea Breeze Model Number?
Magic Chef Refrigerator Parts
Dec 15, 2013 | Magic Chef Refrigerators
Dish washer wont spray water
water inlet valve same as washing machine inlet
Aug 01, 2012 | Magic Chef Built-In Dishwasher
Magic Chef fridge, freezer compartment leaks water (side by side). Can't find a drip pan anywhere on fridge.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Magic Chef Refrigerators
Water not entering dishwasher. Worked fine one
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at http://appliancehelponline.com/dishfloatwaterinletvideo.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Jul 21, 2010 | Magic Chef Dishwashers
We have a ice maker and water dispenser on our magic chef refrigerator. Water has been turned off due to leakage on floor under unit. what is the problem?The unit is a side by side.
I see a lot of cracked lines and cracked inlet valves take back off turn water on and find leak dont be scared just unplug it 1st any questions we are here for you Allbrand appliance lou,ky
Jan 29, 2010 | Refrigerators
Washer will not operate in cold water
sounds like the water inlet valve solenoid is burnt out on the cold side, hot side is ok. if you have the machine set for a cold water rinse, and the solenoid is burnt out it is calling for cold water and it will not come into the machine. change the water valve.
Mar 02, 2009 | Magic Chef CAV2000AWW Top Load Washer
Ariston micro genus combi boiler central heating works okay but domestic hotwater fails to rise but burners seem to be lit and the boiler doesnt appear to cycle dhw temp gets to about 30 degrees instead of...
having found a circuit diagram, realised that the divertor valve was electrically operated.i unplugged this then unclipped the motor from the valve body,the diverter valve is spring loaded and once i'd removed the motor the spring raised the valve to divert water through the dhw heat exchanger,giving us hot water but no heating, if i refit the motor the problem comes back heating no dhw.ordered new motorised valve assembly £30 next day order .
this was a simple fix without having to drain the system down.
Dec 07, 2008 | Heating & Cooling
Magic Chef MCWC8DSCT Wine Cooler
the magic chef is probably the ptc relay.to the left of compressor is a shield with 1 screw behind it .on top is the relay with 1 wire.wiggle it off .go to repairclinic.com...part#1206838
Nov 07, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
Water squirting from ice maker
Does it do it all the time or only when the ice maker call for water... you may have a bad water valve 67006531 VALVE, DUAL WATER or a ice dam in you icemaker let me know
Aug 25, 2007 | Magic Chef (CSD2610KRW) Top Freezer...
Magic Chef (CSD2610KRW) Top Freezer Refrigerator Logo
184 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
