Question about HTC Touch Diamond Smartphone
Touchflo doesn't appear under today, items - HTC Touch Diamond Smartphone
    Scholar:
  • 93 Answers
Do a hard reset. Hold power, volume down, and ok/enter button at the same time, and the reset button under the back cover as well. Once it reboots you can let go of the reset button, but keep holding the other three until you get a message to revert to manufacturers original settings, etc etc..
Next time don't install a program that modifies touchflo or the os unless you really understand what it does..
Posted on Mar 07, 2009
  • Denis K. Mar 07, 2009
    os- operating system
I am using HTC Touch P3452 model.The main screen always shows "Tap here to Launch TouchFLO" but never launches TouchFLO. I have tried a reboot and also taken out battery before rebooting but no...
My HTC HD2 had the same trouble. Runmunng windows would work ok.
The solution for me was to reset the phone to original specs.
The downside is you have to re-laod all your stuff. Make sure it's backed up before you start if you do re-set the phone to factory specs.
Al
Feb 11, 2011 | HTC Touch P3452 Smartphone
Htc touch viva touchflo not working
Try to delete all unwanted SMS + Clear your call log and than open TODAY tab and check Touchflow tab....Cheers
Jan 31, 2011 | HTC Touch Viva Cell Phone
Battery problem
Try upgrading the firmware on it. It depends mostly on what you are using on the device. If you do a lot of data-centric things like constant emailing, surfing the web, YouTube, etc. then you are going to use more battery. Applications running in the background also eat up battery life to keep active. Bluetooth uses more battery compared to using the phone itself. Lots of texting eats up battery life as well, both incoming and outgoing. Wi-Fi eats up battery like there is no tomorrow on just about any device. The TouchFlo 3D interface also uses more battery due to the graphics acceleration. You can turn off the TouchFlo interface to save battery power and go back to the regular Today screen. The device was tested for battery life with TouchFlo enabled however so that's more of an icing on the cake type of change for more power.
You may also want to try deep cycling the battery to see if that helps. Run the battery completely dead so it won't turn on the device anymore. The let it charge for 10-12 hours without the device on. That should cycle the battery and recalibrate the meter.
There are many diffferent reasons you could have lower battery life, it's always different for different people. HTC managed to keep the Touch Pro's battery life around the same as the Mogul even with the graphics acceleration and everything running. So simply turning off TouchFlo will probably increase total battery life by a bit.
you could upgrade to a higher MAH battery too.
(gsm version if you unlocked to use a sim chip)
here
(cdma if it has no sim chip)
here
Jan 10, 2011 | HTC Touch Cell Phone (Unlocked) - Soft...
Touchflo not working
Goto Start, settings, Personal Tab, Today icon, then Items Tab. In the list of items to appear on the Today screen, find the item called TouchFlo 3D and check the box. Then hit OK.
Apr 18, 2010 | HTC Touch Pro Smartphone
Touch Pro2 won't go past the htc load up screen
Make sure your TouchFlo app is turned on. Goto Start, settings, Personal TAB, Today icon, Items Tab. Scroll down the list of items and check the TouchFlo 3D item then click OK.
Apr 14, 2010 | HTC Touch Pro Smartphone
TOUCHFLO IS NOT LAUNCHING. AFTER CHARGING, I JUST SAW ON THE SCREEN "TAP HERE TO LAUNCH TOUCHFLO" AFTER TAPPING, IT SAYS "LAUNCHING TOUCHFLO" BUT IT DOESN'T PROCEED. INSTEAD, IT GOES BACK TO "TAP HERE TO...
This can be an indication of a Out-Dated Firmware. In this matter, you need to download the Software Updater tool from the Official HTC Website. If not available, take it to a Service Center of HTC and tell then to install the upgraded version.
Thank you Sir, Have a nice day.
Oct 16, 2009 | HTC Touch™ 3G Cell Phone
Touchflo of HTC Touch 3G won't launch
Hi. TouchFlo is the special today plugin for the HTC devices, and as you realized, you can still use all functions of your PDA without. I think there is an error in the installation of TouchFlo (There can be a bunch of reasons, we have to know everything you did with your PDA in order to guess them), but there is a safe solution for that problem, you can backup all your personal data and software to your PC, then you can hard reset your PDA to its factory default settings. That way both your phone and the TouchFlo will work. In order to hard reset your PDA (after the backup of your personal data), you can follow the steps in this link: (http://www.hardreset.eu/htc_touch_diamond_hard_reset_soft_reset_en.html). Hope this helps.
May 27, 2009 | HTC Touch Diamond Smartphone
TouchFlo aint launcing on my HTC Viva
I had the similar problem. And the clue is given by AnLIo himself :-).
I got this problem when i recieved a SMS. Even after deleting the SMS the problem persisted. Then i realized may be the message box is full (could be a bug in TouchFLO). So I started deleting all un-Important messages and reduced the number of messages to 10. And once i did this, I was able to launch my TouchFLO even after Restarting the mobile :-) ....
Jan 21, 2009 | HTC Cell Phones
Touchflo does not appear to be working on new Touch diamond
TouchFlo is an application that needs to run on top of Windows. It is quite well hidden in the menus....
To start with, I assume you get the normal Windows Mobile 'Today' screen? If not, you have bigger problems!
If so, hit "Start" --> Settings
Then on the 'Personal' tab, go to 'Today'
Then look at the 'Items' tab and make sure that TouchFLO 3D is the only checked item.
Hit 'OK' top right, then 'X' top right and you should get back to find it activated.
@deepak - TouchFLO 3D is standard on the HTC Diamond. If you have TouchFLO then I guess you have a HTC Touch (different phone).
Dec 02, 2008 | HTC Touch Diamond Smartphone
HTC Touch Diamond Smartphone Logo
159 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
