Question about Whirlpool Washing Machines
The washing machine is full of water and wont drain! rang the whirlpool tech line and was informed it was the filter and before sending a maintence guy to fix it at a cost of 114 euro ( thats the call out fee) to check the filter! guy had no idea wear the filter was! nor do we?? anyone help?
  • 1,294 Answers
Plug off the wall. Would be good to siphon out maximum water from inside the washer first.
The filter is in the front, remove 3 screws under the front panel, remove the filter cap by turning to the left. (Right of the filter is the pump motor.) To collect the water when removing the filter cap you need a wet vac or a good plastic garbage bag, there could be a lot. Clear out the junk. Replace as you dismantled. If you still have a problem, you have to check the pump to see if anything is clogging it. The cover twists off.
Posted on Mar 04, 2009
How do you actually remove the screw plug to access filter to clean (instructions are vague & worried I'll break it)? Water is still in drum after draining.
How to Check to See if the Drain Pump Filter on a Whirlpool ... > Landlords & Tenants > Tenant Credit Checks
When your Whirlpool washing machine won't drain, there's a possibility that ... drain pump filter are easy to disassemble so that you can access and check it. ... Unscrew the three screws at the bottom of the panel, using a Phillips screwdriver. ... Hold a bucket in front of the pump while you remove the knob to catch the water.
How To Fix Whirlpool Duet Front Load Washer Not Draining ...
Dec 2, 2013 - If the washing machine does not drain, then it will not spin. ... To gainaccess to the drain pump and filter you will need either a 1/4 ... Removing the screws will allow the front panel to drop down giving access to ... I have seen where once you clean the filter and test the machine it ... Really ridiculous design.
How to clean the pump filter and coin trap on a Bosch washing
? 5:30
Mar 2, 2013 - Uploaded by whichwasher2007
Feb 03, 2016 | Whirlpool Washing Machines
My whirlpool washer seems to be letting water back flow from the drain line.
sounds like the drain line is too low it needs to be higher than the water level when running a full can check this buy filling with water and stoping the cycle and see where the water stops draining im sure it will stop at the level of your drain line in the back of the washer. the drain line in the back of your washer should come out of the bottom of the washer and then go up to a drain pipe..if its lower than the full water level of the washer then gravity will take over and drain the water... i hope this helps
Sep 09, 2011 | Whirlpool Estate TAWS750PQ 27-Inch Washer
My washer is full of water that wont drain and keeps saying "sd" and "ld" and wont let me change cycles..
Your machine is taking too long to drain. Check the outlet, pump inlet and filter for obstructions. Press STOP/CANCEL to clear the display.
Feb 17, 2011 | Whirlpool Washing Machines
How do you service Mitsubishi split airco MS-09NV?
What type of service? if it's just cleaning and regular maintence, remove filters and depending on how dirty it is, sparay and brush down eveporator coil, flush out drain line, check all electrical connectios, wash outdoor coil with hose, If you are having problems call a service tech. oh yea wash filter and shake out then re-install
Jan 27, 2010 | Heating & Cooling
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Whirlpool washing machine wont stop all lights
Check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out.
While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
How abt a nice rating for the free help? Thnks
Jan 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine does not wash just fill and drain
hI my name is joyce , you need to get a service tech to fix problem the machine has got a piece of trash in valve that controls the cut off of the water and its stuck. check the filter in the water line to make sure it is in good shape and has no trash in it, this usually happens when you are on well system with no filter on line.
Feb 06, 2009 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool Washing Machine AWM 029 is not draining
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Nov 25, 2008 | Whirlpool Washing Machines
Whirlpool awm 5145-2
The filter area permanantly holds water, this is correct,suggest that you have a faulty inlet valve. Regards Engineer
Jul 26, 2007 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
116 people viewed this question
Dan Webster
Dan Webster
Sal De
