Question about HP 1300 - Q1334A Printer
I have a printer hp 1300 that it is not fixing toner in the copy. somebody can help me. Thanks
  • luiz alexandre joao dias
    Dear friend, the printer does not have fusing. He has resistance and film of transference. I wait aid. Thanks
    Friends, I found the solution in similar forum. The set of gears of the left side of the machine has a gear great e inside of it exists a metal bolt with a spring, this set was stopped without making the contact with the cartridge of toner. therefore the same it did not turn and the light was blinking orange. I help I am thankful it of all.
    Luiz Alexandre
    Sergeant:
  • 199 Answers
Check teflon, and helogen lamp inside the fixing assambly also
Posted on Mar 04, 2009
My hp laserjet 1300 is is producing faint copies
Usually cause by dirty transfer roller, if your transfer roll look kind of white recommend replace it. Make sure you are using a HP toner cartridge also.
Jun 08, 2014 | HP LaserJet 1300 Printer
I have hp laserjet 1300 printer that was not come to ready position. I can check there is no paper jam or no other matter. Please help about the matter
if the toner is not seated properly the orage light will blink
open the door remove the toner fix it back and close the door forcely.this will solve the problem
Aug 12, 2011 | HP LaserJet 1300 Printer
If my printer is squeaking what could be the problem besides the toner cartridge?
Squeaking noise is usually caused by the toner cartridge, expecially after market ones. But if its not the toner, I've seen the mirror motor cause a rotation noise in the 1300/1200 series printers.
Nov 18, 2010 | HP LaserJet 1300 Printer
Question
To avoid damaging your printer please download the User's Manual. I gives you the step-by-step procedures in replacing the printer's toner properly. It included illustrations to aid you in replacing the toner.
http://cob.fsu.edu/tech/printermanuals/laserprinters/HP1300.pdf
Feb 11, 2010 | HP LaserJet 1300 Printer
HP Laserjet 1300 yellow light STILL flashing
Re-installing the print driver will not solve a flashing light. If the printer is functionally ok, it will come to ready simply by plugging into the wall. It sounds to me like a fatal error at this point.....could be a long list of things, but I would lean towards a formatter board. bottom line with this printer at this point in it's life is, if it doesn't work, it's not worth fixing. Replaceable for about $100.
Jan 29, 2009 | HP LaserJet 1300 Printer
HP LASERJEY 1300 YELLOW LIGHT FLASHING
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
I am getting verticle black streaks when I print, please help.
This is the test to determine toner or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Hope this helps
Nov 21, 2008 | HP LaserJet 1300 Printer
Installer of hp laserjet 1300
dear all
i need install of laser jet 1300 printer urgently
please help me
May 09, 2008 | HP LaserJet 1300 Printer
23 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
