Question about iLO DVDR05 DVD Recorder
Disk error message appear when i turn on my pc.. it can't recognize the system files to boot the windows.. i made repair for the windows and that didn't solve the problem.. Then i installed another version of windows but i didn't reach to the solution.. And so my pc can't turn on except after i made restart more than almost 6 times... And sometimes i can't see the cd/dvd driver on pc .. plz help me... And Thanks a lot
  • Anonymous May 18, 2009
    when i turn on my pc it says disc error press any key when i press a key it says the same message.
    Scholar:
  • 93 Answers
Sounds like you have yourself a hard drive failure, or at least one in progress if it works now and then. Replace the hard drive, and install windows to the new drive. This should make it boot.
Once you have it booting, fit the old drive as the slave, and hopefully you should be able to copy any work from the old drive to the new one.
Posted on Mar 05, 2009
Disc load problem
DVD players need a finilized disk. When the program finilizes the disk, it's writing the TOC which is where the players go to find the files.
Mar 12, 2014 | Toshiba RD-XS34 DVD Player/HDD Recorder
When attempting to burn project in MY DVD8 an error appears 800402007 while encoding. I am therefor unable to burn disc
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
      Tip: Either of the above options are a great way to not only back up your projects, but make multiple copies to reduce encoding time!
Mar 03, 2008 | Televison & Video
Error message when my Blue Rays reads dvds
It's a software issue. you need to ring the manufacturer to get files and instructions on how to upgrade your machine so it can play the newer blu ray movies. Quite a common problem.
Feb 25, 2014 | LG BD550 Blu-Ray Player
Panasonic sa pt860
Check your USB memory to make sure that it comply with the points below:
1) USB standard USB 2.0 full speed
2) Media file format support MP3 (.mp3) WMA (.wma) JPEG (.jpg) (.jpeg) MPEG4 (.asf)
3) USB device file system FAT12, FAT16, FAT32
4) USB Port power Max. 500 mA
As you can see
1) You should format your USB in windows format (FAT system)
2) The files on your USB should be those mentioned above on point 2.
3) 2.5" hard drives most likely do not work without an external power supply.
you can download the manual from HERE !
Please don't forget to rate me!
Best Regards
XyFinx
Dec 14, 2013 | Televison & Video
I WAS COPYING A VHS TO A DVD..WHEN FINISHED A MESSAGE APPEARED SAYING BIT WAS COPYING FILE INFO..THIS MESSAGE ALWAYS APPEARS AT THE END OF COPYING..THIS TIME IT DIDN'T GO OFF. AFTER ABOUT 1/2 HOUR, I...
One of two things have happened.
1) Either it's system board has has gone bad or
2) The dvd laser block has gone bad.
May cost more to service it than to purchase a new one?
Call around to a trusted service shop to get an estimate of repair.
Feb 03, 2010 | GoVideo Go Video DVD/VCR Combo
Every disk i put in tells me disk error.
Hello my friend
  1. Make sure that you connect right the disk(check cables and jumpers(master-slave)) and that there are boot-able files inside (operating system with the boot.ini,command.com or another boot-able file
  2. Make sure that BIOS/CMOS settings are correct(i reccomend load default settings) and they are recognize your hard drive(in system/hardware information)
Jan 23, 2010 | Philips Televison & Video
Incorrect disk error
CHECK REGION ON YOUR DVD PLAYER THEN CHECK REGION ON THE DVD'S SOME DVD PLAYERS ONLY PLAY SERTON REGIONS
Jul 03, 2008 | Pioneer Televison & Video
Error message - incompatible disc
I BUT A JVC EVERIO BURNER AND I CANT BURN MY VIDEOS FILES I insert the Disc in the Burner, it tries to recognize the disc and then comes up with , DISC ERROR CHANGE DISK
Jan 29, 2008 | JVC CU-VD10
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
iLO DVDR05 DVD Recorder Logo
129 people viewed this question
Top iLO Televison & Video Experts
AFcityboy
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
