When I select print all that happene is - sending data.
  • 564 Answers
Mail me @     apremkuma@gmail.com
Posted on Mar 04, 2009
  • 530 Answers
Hi im josh in cebu phils. may i help you? friend try to check this: The first item to check is whether your printer is connected correctly to your computer. Check the connecting cable to make sure that the connections are tight. You also should unplug each end of the cable to ensure that none of the connecting wires are bent, making a bad connection. You might also want to change the printer cable. Cables can get old, and the wires inside can break; try a new cable and see whether this change fixes the problem.
good luck hope i helped you.
We have a Zebra 105SL thermal printer. When I print to it with any application, the data light comes on, but it doesn't print. It has ribbon, media, calibrated, no error lights
The data light indicates that the printer is receiving data. Hold the cancel key for 10 seconds while powering on. This will print printer configuration. Use to troubleshoot. If the data or format is wrong it will not print as you send data. Make sure you are using the 105SL printer driver. To test the printer functionality you can go to www.teklynx.com and download a demo copy of labelveiw, select the 105SL printer and try to print a simple label. If you can print with labelveiw then it is not a printer problem. Double check your driver and label format.
Nov 12, 2010 | Zebra 105SL Thermal Label Printer
Printing to Winfax Pro
HI,
Are you using a trial version of this software or a full version?Please let me know.
Sep 13, 2008 | Symantec WinFax Pro for PC
Tip
Tips for camera
Using the camera:
Your phone has a flash to help you to take pictures in different lighting environments. The flash is on by default, but you can turn it off or use the automatic setting. To set the desired mode when using the camera, select Options > Flash and Flash off, Flash on or Automatic.
Fast viewing with memory card To view your images and video clips quicker, use your memory card as the main memory for storing them.
In the camera application, select Options > Settings > Image / video storage > Memory card.
Capture and send You can send the picture immediately after you have taken it when you are previewing it. To display a picture immediately after you take it, select Options > Settings > Image preview time and the preview time. During the preview time, select Back to take another picture, or Send to send the picture as a multimedia message.
Print your images Your phone supports Nokia XpressPrint to print images that are in .jpg format. To print your pictures, connect your phone to a compatible printer using a data cable or send the image by Bluetooth to a printer supporting Bluetooth technology. Select the image you want to print from the Gallery, and when viewing the picture, select Options > Print.
on Jun 13, 2010 | Nokia 6500 Slide Cellular Phone
Canon i9900 - have to restart every time in order to print
reinstall the printer driver and restart the printer spooler service also . make sure that c drive have more then 3GB memory to run the services .......
Oct 23, 2009 | Canon i9900 InkJet Photo Printer
EPSON POS PRINTER does not print receipt
Try to clear your printer's queues up messages of all print commands that failed to print. See, what happens it when you send a document to printer, if it fails to print, and you send another, it queues up behind the first that failed to print. So instead of printing the second document it prints what you are seing, special characters etc.
Solution:
Go to start/priners and faxes and right click on your printer and select open. You will all the documents for print so far queued up. select and delete them. Restart your system and the printing should be Ok.
Sep 17, 2009 | POS X POS-X XR210 Thermal Printer
The printer is issuing blank sheets - every other sheet being dispensed by printer is blank - i.e. without printed data
This could happen if the text you are sending to the printer spills over slightly onto a new page. To test for this, press Ctrl-P and select "Current Page." This will insure that only one page is being sent.
Aug 12, 2009 | Lexmark Office Equipment & Supplies
Hp 4350 - Manually feed not printing on its own
from the configuration menu you most select the manual tray and keep it first
Mar 12, 2008 | HP LaserJet 4350 Printer
Laserjet 5L Hangs on Single Sheet Input Jobs
This probably means that the document you printed is set to manual and the printer is waiting for input
try this:
print the document, when the data light is on, press the button on the printer, does it print? if yes go into word and under page setup set the printer to "Auto select" for the paper tray.
or remove paper, print, when the data light comes on, insert the paper into the single sheet tray
hope this helps
thanks for rating
Jan 16, 2008 | HP LaserJet 5L Printer
Mac os 10.5
I think the problem is that lexmark never made this printer mac os compatible. I have one and the disk it came with was for windows only, while i have a 3300 series and that came with a disk for both windows and mac.
Jan 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Long wait time
Hi there just check that within the properties of the print drive located in printers and faxes right hand click on the printer select the Advance tab at the top then make sure that the spool is either set to start printing after last or after first. Click on the print processor button at the bottom and change the graphic output to one of the other option then close and try the machine.. Once you have selected all of the options and you still have mo joy try a different data cable or connect via another port.
Hope this helps you
Thanks J
Jan 09, 2008 | HP LaserJet 2420 Printer
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
